    Ferrari F40 Wheel Re-Render
    16 Posts 9 Posters 1.0k Views 9 Watching
    • Gus RG
      Gus R
      An old model from 2011 that I originally rendered in Kerkythea. It's a wheel for the Ferrari F40 that I never made. The wheel spokes were made using SubD. The raised lettering on the tire is a normal map and the treads are made up of a single component.
      This was the Kerkythea render.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        Very sharp, you could make sales off the back of that. ๐Ÿ‘ ๐Ÿ‘
        • Gus RG
          Gus R
          Thanks Mike. Maybe I could get new and different work. I keep telling myself that might happen but it never happens.
          I increased the tread depth.
          I go back to some of my old SU models and scratch my head at what I was doing back then. For instance there's a component for each tread segment yet the only component that shows up "in model" is the entire tire/wheel. At least it wasn't a group or loose geometry.
          • ntxdaveN
            ntxdave
            These tires are incredible to me. I could not come up with detail like that. I do not know how you accomplish things like the tread and all of the details on the side of the tires.
            Can you educate some of us!
            Press F1...thank me later
            • Gus RG
              Gus R
              Dave,
              The sidewall is just a normal map I created with Nvidia Texture Tools (free) from this image.
              The tread is a radial array then mirrored of this component.
              The Ferrari horse looks something like this. I imported the linework into SU to create the horse outline. I forgot what I used back then but you can use Inkscape to trace the image to create an svg file that you can import into SU with another free plugin. Inkscape is also free.
              The spoke work looked like this.
              And I guess I did use Artisan for this. It's been over 10 years.
              The rest is just basic SU shapes. The etching along the outer rim is another normal map. The tiny Ferrari horse in the air pressure cap is just an image.
              • Gus RG
                Gus R
                With the tire I projected the non normal image onto the side wall so it's centered. The normal map is created with the same image. In Thea Render I changed the material of the regular image to a rubber material and then added the normal map to the rubber material.
                • ntxdaveN
                  ntxdave
                  @gus r said:
                  Dave,
                  Is that a plugin or a standalone tool?
                  OK, I went and found the tool. Do I have to Adobe Photoshop to use the textures?
                  I โ€œgetโ€ the rest of the stuff now that i see what you did. Thanks for sharing and educating me.
                  • Gus RG
                    Gus R
                    Dave,
                    The Nvidia Texture Tools has a standalone which I'm using which you can get here.
                    I only use a couple of features with that to create normal maps.
                    • ntxdaveN
                      ntxdave
                      Yes, that was the site I found. I will have to take a look. ๐Ÿ˜„
                      • boofredlayB
                        boofredlay
                        These look wheely great! ๐Ÿ˜Ž
                        • tuna1957T
                          tuna1957
                          Indeed ๐Ÿ‘
                          • L
                            Crazy good Gus ๐Ÿ˜Ž ๐Ÿ‘
                            • ntxdaveN
                              ntxdave
                              Amazing work. ;thumb:
                              • HornOxxH
                                HornOxx
                                ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜ฒ Boahh !!! ๐Ÿ‘ Respect!
                                never trust a skinny cook
                                • panixiaP
                                  panixia
                                  Cool!
                                  • Bryan KB
                                    @gus r said:
                                    Dave,
                                    This looks interesting. Thanks!
