    2.2k Posts 487 Posters 928.5k Views 492 Watching
    • N Offline
      natejesus
      I want to use the plugin I paid for. I activate it. Activation is successful. I try to use the plugin (round corners), it says not activated. This is a loop, no matter how many times I do it.
      I just want to round some corners. I hate all of this. I'll never buy a SketchUp plugin again. 😞
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in Sketchup and copy/paste the output here
          @natejesus
          Do what Rich advises...
          However, your issue might relate to a mismatch between the Extension and License.
          Fredo has two extensions - RoundCorner and FredoCorner.
          They are different and need the matching license to work...
          Please check your downloaded license's name and your installed extension's name - unless they match you can't validate...
            danygico
            Hi fredo6
            After having formatted the pc for SDD problems I can't free these licenses
            RoundCorner
            Seat ID: 33994; HW ID: ME1651994382.0W; Date of activation: 08/05/2022
            Curviloft
            Seat ID: 25877; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
            VisuHole
            Seat ID: 25882; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
            I would really appreciate it if you can remove them
            Thank you
              kmatloc
              I purchased the license for fredo plugings i used the for a bit in one of my laptops now its not leting me use the plugings and i try to put in the license but it says there is an error in the communication i have the latest version of sketchucation plugin i have a good wifi conection i think everything is right Help!
              • W Offline
                wlybe
                heelp. can not activate my license for joint pushpull plugin. Got a message: "Sorry - an error occured in the communication with Sketchucation"
                  What version of SketchUp are you using? Your profile says 2022 Free/Make which does not exist.
                  Do you have the latest version of the Sketchucation ExtensionStore tool installed? Latest version of LibFredo6?
                    Replying to both above...
                    That error occurs when either software or hardware is stopping your device making a connection.
                    Something like an antivirus app or similar related to your network security.
                    If you can identify what is blocking you can whitelist *.sketchucation.com and it will not occur.
                    Or disable the app and run the activation and then re-enable the app.
                    On rare occasion it could be the permissions that SketchUp has from install. If you have the installer you can right click and choose Run as Admin and then Repair to give SketchUp the permisssions it needs.
                      manoamo
                      Hi, I'm trying to "reset" license.
                      because it says "License seats exceeded"
                      but, I don't know how
                      please help
                        please help
                        You can download our licensing guide...
                        https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                        It has instructions for releasing seats.
                        Also make sure your devices are running Sketchucation Tools 4.3.1
                        Sketchucation Tools | SketchUcation
                        (sketchucation.com)
                        This allows online seat releasing at https://sketchucation.com/webshop/my-licences.php
                          junphuc17945
                          please help me deactive 3 stucked seated of JointPushPull, this is 3rd time but still not solve
                          Seat ID: 27969; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
                          Seat ID: 27981; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
                          Seat ID: 28446; HW ID: BR1622557468.0S; Date of activation: 08/04/2022
                          • fredo6F Offline
                            This is done.
                            What is the issue exactly?
                              danygico
                              Hi fredo6
                              RoundCorner
                              Curviloft
                              VisuHole
                              Thank you
                              • fredo6F Offline
                                @danygico said:
                                Hi fredo6
                                RoundCorner
                                Curviloft
                                VisuHole
                                Thank you
                                This is done.
                                  GameP
                                  Hi fredo6,
                                  I'm not able to release this license.
                                  RoundCorner
                                  Seat ID: 34352; HW ID: WR1652171373.0N; Date of activation: 10/05/2022
                                  Could you please remove it?
                                  Thank you
                                    Seat released. Please make sure your devices are running the latest releases of Sketchucation Tools
                                    (sketchucation.com)
                                      delta215
                                      Hi I purchased this set of extensions a while ago now. several years and computers later I am trying to validate on yet another system but cant release seats there is no tick box.....is there a way to release all seats? Thanks in advance
                                        delta215
                                        Fredo please can you help by releasing these seats for me
                                        round corner
                                        Seat ID: 34603; HW ID: EC1652264750.0U; Date of activation: 11/05/2022
                                        Seat ID: 73379; HW ID: VZ1673014436.0T; Date of activation: 06/01/2023
                                        joint push pull
                                        Seat ID: 35321; HW ID: PX1652459509.0U; Date of activation: 15/05/2022
                                        Seat ID: 75833; HW ID: VZ1673014436.0T; Date of activation: 19/01/2023
                                        Seat ID: 104792; HW ID: QV1682535928.0L; Date of activation: 17/06/2023
                                        curviloft
                                        Seat ID: 52861; HW ID: PX1652459509.0U; Date of activation: 28/08/2022
                                        Seat ID: 98356; HW ID: VZ1673014436.0T; Date of activation: 12/05/2023
                                        fredo scale
                                        Seat ID: 34608; HW ID: EC1652264750.0U; Date of activation: 11/05/2022
                                        Seat ID: 41456; HW ID: PX1652459509.0U; Date of activation: 19/06/2022
                                        topo
                                        Seat ID: 72523; HW ID: PX1652459509.0U; Date of activation: 02/01/2023
                                        Seat ID: 98363; HW ID: VZ1673014436.0T; Date of activation: 12/05/2023
                                        tools on surface
                                        Seat ID: 58821; HW ID: PX1652459509.0U; Date of activation: 06/10/2022
                                        Seat ID: 74267; HW ID: VZ1673014436.0T; Date of activation: 11/01/2023
                                        thanks in advance
                                        • fredo6F Offline
                                          I have released the seats for all your licenses.
                                            @delta215 said:
                                            I am trying to validate on yet another system ...
                                            Are you still using SketchUp 2015 Make?
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 109
                                            • 110
                                            • 75 / 110
