    2.3k Posts 515 Posters 2.3m Views 520 Watching
      The pay by PayPal and pay by card are powered by PayPal. If your country forbids PayPal then there's no other option at present.
      We are looking at Stripe but if you have friends outside of Turkey I would get them to purchase on your behalf.
      • N Offline
        natejesus
        I want to use the plugin I paid for. I activate it. Activation is successful. I try to use the plugin (round corners), it says not activated. This is a loop, no matter how many times I do it.
        I just want to round some corners. I hate all of this. I'll never buy a SketchUp plugin again. 😞
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support command in Sketchup and copy/paste the output here
          • TIGT Online
            @natejesus
            Do what Rich advises...
            However, your issue might relate to a mismatch between the Extension and License.
            Fredo has two extensions - RoundCorner and FredoCorner.
            They are different and need the matching license to work...
            Please check your downloaded license's name and your installed extension's name - unless they match you can't validate...
              danygico
              Hi fredo6
              After having formatted the pc for SDD problems I can't free these licenses
              RoundCorner
              Seat ID: 33994; HW ID: ME1651994382.0W; Date of activation: 08/05/2022
              Curviloft
              Seat ID: 25877; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
              VisuHole
              Seat ID: 25882; HW ID: TN1648232773.0X; Date of activation: 25/03/2022
              I would really appreciate it if you can remove them
              Thank you
                kmatloc
                I purchased the license for fredo plugings i used the for a bit in one of my laptops now its not leting me use the plugings and i try to put in the license but it says there is an error in the communication i have the latest version of sketchucation plugin i have a good wifi conection i think everything is right Help!
                • W Offline
                  wlybe
                  heelp. can not activate my license for joint pushpull plugin. Got a message: "Sorry - an error occured in the communication with Sketchucation"
                    What version of SketchUp are you using? Your profile says 2022 Free/Make which does not exist.
                    Do you have the latest version of the Sketchucation ExtensionStore tool installed? Latest version of LibFredo6?
                      Replying to both above...
                      That error occurs when either software or hardware is stopping your device making a connection.
                      Something like an antivirus app or similar related to your network security.
                      If you can identify what is blocking you can whitelist *.sketchucation.com and it will not occur.
                      Or disable the app and run the activation and then re-enable the app.
                      On rare occasion it could be the permissions that SketchUp has from install. If you have the installer you can right click and choose Run as Admin and then Repair to give SketchUp the permisssions it needs.
                        manoamo
                        Hi, I'm trying to "reset" license.
                        because it says "License seats exceeded"
                        but, I don't know how
                        please help
                          please help
                          You can download our licensing guide...
                          https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                          It has instructions for releasing seats.
                          Also make sure your devices are running Sketchucation Tools 4.3.1
                          Sketchucation Tools | SketchUcation
                          (sketchucation.com)
                          This allows online seat releasing at https://sketchucation.com/webshop/my-licences.php
                            junphuc17945
                            please help me deactive 3 stucked seated of JointPushPull, this is 3rd time but still not solve
                            Seat ID: 27969; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
                            Seat ID: 27981; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
                            Seat ID: 28446; HW ID: BR1622557468.0S; Date of activation: 08/04/2022
                            • fredo6F Offline
                              This is done.
                              What is the issue exactly?
                                danygico
                                Hi fredo6
                                RoundCorner
                                Curviloft
                                VisuHole
                                Thank you
                                • fredo6F Offline
                                  @danygico said:
                                  Hi fredo6
                                  RoundCorner
                                  Curviloft
                                  VisuHole
                                  Thank you
                                  This is done.
                                    GameP
                                    Hi fredo6,
                                    I'm not able to release this license.
                                    RoundCorner
                                    Seat ID: 34352; HW ID: WR1652171373.0N; Date of activation: 10/05/2022
                                    Could you please remove it?
                                    Thank you
                                      Seat released. Please make sure your devices are running the latest releases of Sketchucation Tools
                                      (sketchucation.com)
                                        delta215
                                        Hi I purchased this set of extensions a while ago now. several years and computers later I am trying to validate on yet another system but cant release seats there is no tick box.....is there a way to release all seats? Thanks in advance
                                          delta215
                                          Fredo please can you help by releasing these seats for me
                                          round corner
                                          Seat ID: 34603; HW ID: EC1652264750.0U; Date of activation: 11/05/2022
                                          Seat ID: 73379; HW ID: VZ1673014436.0T; Date of activation: 06/01/2023
                                          joint push pull
                                          Seat ID: 35321; HW ID: PX1652459509.0U; Date of activation: 15/05/2022
                                          Seat ID: 75833; HW ID: VZ1673014436.0T; Date of activation: 19/01/2023
                                          Seat ID: 104792; HW ID: QV1682535928.0L; Date of activation: 17/06/2023
                                          curviloft
                                          Seat ID: 52861; HW ID: PX1652459509.0U; Date of activation: 28/08/2022
                                          Seat ID: 98356; HW ID: VZ1673014436.0T; Date of activation: 12/05/2023
                                          fredo scale
                                          Seat ID: 34608; HW ID: EC1652264750.0U; Date of activation: 11/05/2022
                                          Seat ID: 41456; HW ID: PX1652459509.0U; Date of activation: 19/06/2022
                                          topo
                                          Seat ID: 72523; HW ID: PX1652459509.0U; Date of activation: 02/01/2023
                                          Seat ID: 98363; HW ID: VZ1673014436.0T; Date of activation: 12/05/2023
                                          tools on surface
                                          Seat ID: 58821; HW ID: PX1652459509.0U; Date of activation: 06/10/2022
                                          Seat ID: 74267; HW ID: VZ1673014436.0T; Date of activation: 11/01/2023
                                          thanks in advance
                                          • fredo6F Offline
                                            I have released the seats for all your licenses.
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 115
                                            • 116
                                            • 82 / 116
