    More Fredo6 plugins becoming paid extensions
    165 Posts 56 Posters 94.3k Views 56 Watching
    • N Offline
      NF_TM
      I would like to purchase a license, but a page error prevents me from proceeding.
      Obtain License↓.
      ERROR: Unknown plugin identer.
      I am having trouble using it in my work.
      I have been able to activate other fredo tools.
        Please explain the steps you go through to end up with this message, in more detail...
          MarkDuncan1966
          Adios
          it crashes/freezes my system far too much, so much so it was ok to put up with this inconvenience when it was free but not as a paid plug-in, at least i know to know uninstall any/all plug-ins from this user now, i am NOT prepared to pay for a plug-in that crashes my system.
            Fredo6's extensions don't crash systems for the vast majority of systems. What's different on yours?
              MarkDuncan1966
              You key words are "a vast majority of systems".....
              As for what is different on mine, well sorry, my crystal ball is in the shop..
              A PC running win 10, sketch-up pro 2021.
              periodically upon selecting an edge to round off, the plug-in would grey out sketchup and display "program is not responding" this would become indefinite, requiring me to end the process which 9 times out of 10 resulted in a loss of project progress as the Recovered file usually rolled back around 10 minutes.
              So as i said this "inconvenience" was acceptable to put up with as a free plug-in but not acceptable for a paid product with an issue/problem that in all likely-hood would be attributed to my system (as has been intimated) and in reality never get rectified. so no sorry no sale.
              In real terms it just means i have to not be as lazy and do it manually.
                My apologies. I replied to you with an honest wish to help. Evidently you don't really want help with this so I'll leave you to it.
                  MarkDuncan1966
                  no not at all, But as an engineer I run on pure logic.
                  So lets dissect what you said logically, with it comprising of two parts : "Fredo6's extensions don't crash systems for the vast majority of systems. What's different on yours?"
                  Part one stated that Fredo6's extensions don't crash systems for the vast majority of systems, which might be true, the key word for me to pick up on is "majority" which intimates there might well be instances of which it can happen.
                  Part two asked a question which is realistically and logically unanswerable by me, my system spec and file structure might be a contributing factor, but again how am i expected to know what is right and what is wrong without a known benchmark to work from, i cant just pull what is different out of my bottom?
                  realistically the only person who could have half a chance of answering that question would be the extension developer and possibly only after they interrogated the system in question.
                  • fredo6F Offline
                    The first thing is to describe what is the problem, which plugin, etc.... and also to tell us which version of Sketchup you run.
                    The second thing is to make sure you have the latest version of
                    • LibFredo6
                    • Sketchucation ExtensionStore
                    • The plugins you use
                    If you can, go to menu Window > LibFredo6 Settings... > Check Fredo6 Plugins for Update.
                    This will tell you if my plugins are up to date.
                      MarkDuncan1966
                      • LibFredo6
                      ERM...........
                      "A PC running win 10, sketch-up pro 2021.
                      periodically upon selecting an edge to round off, the plug-in would grey out sketchup and display "program is not responding" this would become indefinite, requiring me to end the process which 9 times out of 10 resulted in a loss of project progress as the Recovered file usually rolled back around 10 minutes."
                      And as an engineer, trust me when i tell you i religiously keep EVERYTHING up-to-date, and again from reading the already provided symptoms, logic would be work out that we are discussing one of the "round corner" plug-ins
                        Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and paste the ruby console output into your reply.
                        Example:
                        Fredo6 Plugins Information on 2023-04-11 11;30;02 +0100
                        - Platform; x64-mswin64_140 - Ruby; 2.7.2
                        - Sketchup; 23.0.367
                        - LibFredo6; v13.9a
                        - LibFredo6 Binary loaded
                        - Sketchucation ExtensionStore; 4.3.1
                        - SCFLicense; v6.1a - 72
                          As well as the info Rich asked for, could you also post a screen-shot of the extensions tool-bar which should appear across the top of your main screen, including the geometry you want to modify.
                          If you have some odd combo of settings leading to a 'loop-of-death', then Fredo might be able to spot something in that screen-shot...
                          Most user-induced disasters are trapped in the extension's code, but some can sneak through, especially if it's some obscure combo of settings and model form that hadn't been anticipated...
                            TonyAU
                            Where can I find the bundle, and whats included.
                            It's really hard to find info on this and how to pay etc.
                            any help would be great
                            Cheers.
                            • BoxB Offline
                              SketchUcation | Cart
                              (sketchucation.com)
                              • F Offline
                                filatelik
                                Hello guys, anyone to share multi-license by sharing the cost too? I need only one license(seat) of bundle of 8 plugins. Thank you in advance guys. f
                                  adrianapsn Newcomers
                                  Hello! 😄
                                  I've bought the 40$ bundle as a company expense. There are a few of the plugins that I've been using/discovering recently and they are just amazing, so I've decided to buy them all. Sadly, in the past, I've bought independently FredoPushPull as a student, so I currently own 2 licenses for it.
                                  Is there any way I can get a refund or I'd gladly be happy if at least it can be swapped for another product/plug-in like FredoCorner?
                                  Thank you in advance!
                                  here you can see it
                                    @adrianapsn said:
                                    Hello! 😄
                                    Its not possible to refund as the original purchase is ~11 months ago(2022-11-23).
                                      @rich o brien said:
                                      @adrianapsn said:
                                      Hello! 😄
                                      I understand. It is also not possible to swap with a different product/plug-in?
                                      Thank you for the answer!
                                      A 1 Reply Last reply Reply Quote 0
                                        bigbeltrame
                                        I bought curviloft in 2022. Is it possible to get a discount on the bundle?
                                          bigbeltrame
                                            ramonbastos
                                            How do I release all seats from my fredo plugins? I want to restart everything.
                                            • 7 / 9
