    Sketchup 2023 is out!
    31 Posts 16 Posters 1.6k Views 16 Watching
    • panixiaP Offline
      panixia
      Sketchup 2023 is out.
      It features a dark mode, customizable toolbars, a new 3d kernel which can manage tons of geometry, an inbuilt chamfer and loft system, native primitives such as spheres, cubes, cylinders, pyramids and many others, new powerful uv-mapping tools, native quads support, a brand new inbuilt rendering engine with RTX support and many other incredible new features.
      • ntxdaveN Offline
        ntxdave
        Can you give a link to this info? I saw something earlier on the SketchUp forum but the link I went did not mention some of the things you mention.
        Press F1...thank me later
        • panixiaP Offline
          panixia
          Actually there's only a flip tool similar to Curic Mirror and a couple of minor improvements. ๐Ÿ˜›
          https://media.tenor.com/Bv3cdY_KItsAAAAC/joke-missed.gif
            rv1974
            and 72 Norwegian virgins..
              Great reporting! Fact checking.....
              • ntxdaveN Offline
                ntxdave
                That is what I had read on this link ShetchUp Help it did mention all of those other things. ๐Ÿ˜ฎ
                • panixiaP Offline
                  panixia
                  Well, I believe those will be added in su 2024. Don't ask too much for a single update.
                  • SektaS Offline
                    Sekta
                    I was hoping for more development of live Components function??
                      The Live Components thing is separate from SketchUp proper. It's still in beta and getting ongoing development that won't wait for another release of SkethUp.
                        "incredible new features"
                        Yup.......incredible
                        • ntxdaveN Offline
                          ntxdave
                          What did I miss?
                          • soloS Offline
                            So what is actually new?
                            All I see are some extensions we already pretty much had been bundled with SU and released as a new version.
                            Yet another year I'll opt out of updating I guess, I already can do all this with SU 2018 and a few extensions.
                            • N Offline
                              numerobis
                              Unbelievable.
                              Once again...
                                (help.sketchup.com)
                                Faster saving on large models, revit importing, mirroring changes, overlay capabilities when using extensions.
                                • Increased Eraser Sensitivity
                                  Do you know how the Eraser can sometimes annoyingly miss edges you are trying to scrub, hide, or smooth? We've increased the sensitivity of Eraser so you get a truer feel and outcome to your eraser strokes.
                                • Deselect Edges/Faces
                                  You can now remove faces or edges from a selection set using Deselect Edges or Deselect Faces. These new commands can be found through a Search or in the Select submenu.
                                • Double-Click Drawing Axes
                                  Moving the axes in your model just got easier! When moving the drawing axes with the Axes tool you can now double-click to instantly place them, skipping all the other alignment steps.
                                • Freehand Segments
                                  You can now modify your line segments using Ctrl + or Ctrl -, the same way you would increase or decrease segments for circles, arcs, or polygons.
                                • Three-point Drawing Tools Measurements
                                  The measurements input for the 2-Point Arc, 3-Point Arc, and Rotated Rectangle tools are now standardized. After setting the second point for these tools you can input and repeat values into the measurement box, defining the initial distance of a drawing operation.
                                • Section Planes in Reloaded Components
                                  Occasionally, components with section planes load into a model, and the active style conflicts with the saved section plane visibility properties of the component. We've made sure your model's settings take precedence and the current style settings are respected when importing those components.
                                • Search Results Shortcuts
                                  When searching for a command using Search you'll now see the assigned shortcut, if available, for your result.
                                Also the installer has changed to allow separate app installs. No more Stylebuilder if you don't want it.
                                • panixiaP Offline
                                  panixia
                                  @rich o brien said:
                                  revit importing
                                  Sketchup studio only. ๐Ÿ‘Ž
                                  • Gus RG Offline
                                    Gus R
                                    I gave it a quick shot and it looks fine. Then I had to change my default program back to SU 2022 and instead of opening the skp file directly from Windows Explorer it opened up the Welcome screen first. Then I uninstalled SU 2023 and it's no longer opening my skp files directly Explorer and instead continues to open the Welcome screen first. Now I have to troubleshoot this.
                                    www.instagram.com/gusrobatto/
                                    www.facebook.com/gusrobatto
                                      kaas
                                      Underwhelming but not unexpected. I see no reason to update to 2023.
                                      Now that everybody is on the subscription train, its no more letting your wallet speak for you by skipping a year (or two) until actual good improvements are added. Its pay up or you will loose access to your SketchUp files and you can't edit them anymore-time now.
                                      • panixiaP Offline
                                        panixia
                                        You can still revert back to your old perpetual license (as long as it's >Su2014) and use the Eneroth plugin to open newer files.
                                        I feel I can happily go on with my SU2021 perpetual and rather invest my moneys in useful plugins.
                                        • Gus RG Offline
                                          Gus R
                                          OK, fixed that by re-setting the "open with" in Windows and now it's all back to normal.
                                            MtnArch
                                            Which plugin is this one?
                                            Highest Regards,
                                            Alan T. Hendry, RA
                                            Architect
