    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
      LibFredo6 13.3a includes:
      • Major bug fixing (error about wdlg_from_key undefined)
      • Bug fixing for FredoSpline (when drawing splines over an image)
      • Gus RG Offline
        Gus R
        Thanks Fredo.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          Dayton28
          @fredo6 said:
          LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
          The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
          /pluginrepo/rbz/
          /var/www/html/pluginrepo/rbz/LibFredo6.rbz
          File does not exist. Make sure you specified correct file name.
            That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
            from where you can then download its RBZ.
            It's perhaps more sensible to go directly through the PluginStore, via two clicks...
            https://sketchucation.com/pluginstore?pln=LibFredo6
            Or even easier... use the SketchUcation Toolset's ExtensionStoreÂł ??
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
              LibFredo6 13.4a includes:
              • bug fixing
              • Support for ThruPaint v2.1a
                art900
                I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
                  art900
                  well never mind, it works now i just needed to restart my computer i guess..
                    kpbarbee
                    The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
                    Help!
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
                      LibFredo6 13.5a includes:
                      • bug fixing for potential problems at startup
                      • support for future compatibility
                      • fredo6F Offline
                        Could you do the following, assuming you have Sketchup 2021 or 2022.
                        1. Open the Ruby Console (menu Extension > Developer)
                        2. Close Sketchup
                        3. Open Sketchup - The Ruby console should open automatically and potentially display error messages.
                        4. Keep the Ruby console opened when launching my plugins.
                        • I Offline
                          igorassis
                          Still having the same issues with this version,i cant use most of your plugins, im having this problem
                          path=C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware
                          no language file.
                          tb_mode,single
                          tb_Settingout,true
                          tb_Draw,true
                          tb_Edit,true
                          tb_Array,true
                          tb_Wall,true
                          tb_Staircase,true
                          tb_Win,true
                          tb_Roof,true
                          point_on_face,true
                          divide,true
                          align,true
                          perpendicular_line,true
                          fonplane,true
                          bestface,true
                          extrude1,true
                          extrude2,true
                          move_vertex,true
                          fillet,true
                          chamfer,true
                          extend,true
                          offset_edge,true
                          hline_faces,true
                          slopeedges,true
                          linear_array,true
                          rect_array,true
                          polar_array,true
                          vx_wall,true
                          opening,true
                          hgroove,true
                          staircase1,true
                          staircase2,true
                          staircase3,true
                          staircase4,true
                          spiralstair,true
                          escalator,true
                          wframe,true
                          dframe,true
                          paneldivide,true
                          screen1,true
                          hlouvres,true
                          vlouvres,true
                          rafter1,true
                          roof1,true
                          hiproof,true
                          revsurf,true
                          rgrille,true
                          cgrille,true
                          loading 1001bitmenu >> true
                          "English"
                          I, [2022-11-11T09;26;56.049506 #6024]  INFO -- datasmith; Loading 'C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'...
                          I, [2022-11-11T09;26;56.053087 #6024]  INFO -- datasmith; Loading plugin binary module from C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so
                          I, [2022-11-11T09;26;56.063538 #6024]  INFO -- datasmith; Engine Path; 'C;\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI; true
                          I, [2022-11-11T09;26;56.436781 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                          License expiration; 2022-09-15 15;21;59 UTC, Left; -57 days
                          INFO; container(features) created... [Plugin.Application]
                          INFO; app created... [Plugin.Application]
                          IsLoaded; false
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;17; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;18; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;19; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;20; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;21; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;22; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;23; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;24; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;25; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;26; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;27; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;28; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;29; warning; encountered \r in middle of line, treated as a mere space
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;30; warning; encountered \r in middle of line, treated as a mere space
                          true
                          E;/2022/Tools/RubyStdLib/SecureRandom.rb;309; warning; already initialized constant Random;;Formatter;;ALPHANUMERIC
                          E;/2022/Tools/RubyStdLib/securerandom.rb;309; warning; previous definition of ALPHANUMERIC was here
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe;4362; warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                          [D5 Converter] light data restored from attribute.
                          I, [2022-11-11T09;27;02.901161 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe;358; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe;374; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          Error; #<ArgumentError; wrong number of arguments (given 1, expected 0)>
                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb;148;in `load'
                          eval;1;in `block in use_libraries'
                          eval;1;in `each'
                          eval;1;in `use_libraries'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `general_init'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `use_libraries'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe;73;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `initialize__'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;160;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `show'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;66;in `time_for_check?'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;453;in `block in after_startup'
                          Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;445;in `invoke_quick_launcher'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;291;in `block in configure'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                          LAUNCHER TEM 9196708826.464672
                          "Add help menu!"
                          "create new"
                          "created"
                          #<Sketchup;;Menu;0x00000234debaa670>
                          (eval);23; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          "Add help menu!"
                          "created"
                          Error; #<NoMethodError; undefined method `add_item' for nil;NilClass>
                          (eval);40;in `block in <module;Help>'
                          "created"
                          (eval);199;in `block in <module;Notification>'
                          LAUNCHER TEM 9196708866.898788
                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfe10cd0>>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;876;in `param_load'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;366;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;240;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `launch'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;176;in `action__mapping'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;103;in `launch_action'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;119;in `block in startup'
                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bdc51a90>>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;246;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `launch'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;120;in `block in startup'
                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfbc7b40>>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;132;in `invoke_quick_launcher'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;103;in `block in startup'
                          LAUNCHER TEM 9196708988.201132
                          Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234c007c820>
                          Did you mean?  validate_current_selection>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;553;in `notify_action'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;584;in `terminate_current_selection'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;745;in `notify_from_vbox'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `call'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `onLButtonUp'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;2486;in `onLButtonUp'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;1152;in `onLButtonUp'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;508;in `onLButtonUp'
                          LAUNCHER TEM 9196709028.635246
                          Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234bf204068>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;279;in `execute_validate'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;450;in `onReturn'
                          LAUNCHER TEM 9196710848.170437
                          Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                            Do you have the newest versions of LibFredo and the SketchUcation toolset installed and SketchUp restarted ?
                            Other extensions loading seem to be having issues, so they could be causing problems with Fredo's files loading subsequently...
                            Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ?
                            • I Offline
                              igorassis
                              it worked, thanks
                              • Stephane_14S Offline
                                Stephane_14
                                Bonjour,
                                Les plugins de Fredo6 n’affiches plus les icĂŽnes puis j'ai remarquĂ© que ExtensionStore V.429 n’ Ă©tĂ© plus branchĂ© Ă  internet avec mes identifiants, Cela est rĂ©solu mais c'est Ă©tonnant.
                                Autre soucis depuis la mise à jour de FredoLib V3.5a l'utilisation de Curviloft provoque un Plantage systématique de Sketchup.
                                Avez vous des explications ?
                                Cordialement
                                Hello,
                                The Fredo6 plugins no longer display the icons then I noticed that ExtensionStore V.429 was no longer connected to the internet with my credentials, This is resolved but it's surprising.
                                Another concern since the update of FredoLib V3.5a the use of Curviloft causes a systematic crash of Sketchup.
                                Do you have any explanations?
                                Cordially
                                Stéphane HENRY
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v13.6a - 29 Nov 22
                                  LibFredo6 13.6a includes:
                                  • Bug fixing about selection contextual menu (for LOTT and FredoSpline)
                                  It is strongly advised to upgrade to this version
                                    Bilinmez
                                    Hello,
                                    PayPal is forbidden in our country, Turkey. How can I buy these plugins with another payment method?
                                    Thank you.
                                      See https://sketchucation.com/forums/viewtopic.php?f=323&t=75165
                                        rhelton
                                        If we now have to PAY for the extensions could we at least get Automatic Updates to the Extensions so I Do Not have to keep logging in and updating Lib Fredo manually every time I turn around !!!!!
                                          https://i.imgur.com/ZXGP3tn.png
                                          You turn around once every ~2 weeks?
                                            tibooobit
                                            Thanks for the update of LibFredo6- v13.6a, but I got a problem with the update, or maybe because of my new laptop -> macbook 16" M1 2021.
                                            I use a Sketchup Pro 2019 licence.
                                            Sketchup 2019 + Uptodate Libfredo plugins are installed on my old macbook pro 2010 Intel i7 and my new macbook 2021 M1 both.
                                            Only my old macbook is able to launch Libfredo plugins 😕
                                            In my new macbook : Libfredo window is not showing, and plugin button are not clickable.
                                            [attachment=0:1g7i275x]<!-- ia0 -->Capture d’écran 2023-01-09 Ă  10.57.25.png<!-- ia0 -->[/attachment:1g7i275x]
                                            I really like LibFredo Plugin (animator, round corner, push pull...). Do you think that a futur update will resolve the problem ?
                                            Ruby console (when I launch Libfredo window) on M1 macbook :
                                            Error: #<NameError: uninitialized constant G6::G6B>
                                            /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4952:in mouse_init' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4995:in option_down?'
                                            /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5016:in ctrl_down?' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:2117:in animation_navigate_allowed?'
                                            /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:2121:in animation_navigate_or_play' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatorpalette.rbe:227:in block in palette_button_play'
                                            /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4076:in execute_button' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3830:in onLButtonUp'
                                            /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp' /users/tibo/library/application support/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe:1283:in onLButtonUp'
                                            Error: #<NoMethodError: undefined method `wdlg_from_key' for Traductor::Wdlg:Class>
                                            Thanks for your answer !
                                            Tibo
                                            Ruby console - Libfredo
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 108
                                            • 109
                                            • 12 / 109
