    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.1m Views 582 Watching
    • fredo6F Offline
      There are problems which seems to be exclusive to the MacOS M1 platforms.
      So, I published a Rollback to
      • LibFredo6 v12.9a
      • JointPushPull v4.4e
      I hope this will be temporary, although I don't know yet what is the problem.
      For users of other Platforms (Windows and Mac non-M1), you can safely keep LibFredo6 v13.1 and JointPushPull v4.6a.
      Sorry for inconvenience.
        DCDP
        @fredo6 said:
        @dcdp said:
        I installed the latest version of LibFredo6. But Curviloft does not work and I can't open any setup window (Purge; Check for updates).
        What I must to do ? Must I uninstall all your plugins and reinstall them ?
        Before launching Curviloft, could you open the Ruby Console. Then Launch Curviloft, and what the console for any error message.
        By the way, do you have a Mac M1?
        No, I'm working on iMac with Intel Processor.
        But today everything is ok. It seems that the computer relaunch did be more efficient than a simple Sketchup relaunch.
        Thanks for your help (even by mind)
        • fredo6F Offline
          There may be problems when you install LibFredo6 and have several instances of Sketchup open. You need to close them all.
            DCDP
            I have closed entirely Sketchup.
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v13.2a - 16 Sep 22
              LibFredo6 13.2a includes:
              • Various fixes for my plugins
              • Support for future plugins
              Note that the problem with Mac M1 platform, present in v13.1a, has been solved.
              • Gus RG Offline
                Gus R
                Fredo,
                When I click on check for updates nothing happens.
                Window: Libfredo6 Setting: Check Fredo6 Plugins for Updates. Nothing under there works until I click on Default Parameters and then is starts working.
                This is the error from the Ruby Console:
                Error: #<NoMethodError: undefined methodwdlg_from_key' for Traductor::Wdlg:Class>
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:in check_instance_displayed' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:58:in top_dialog'
                c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:336:in block in populate_support_menu' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'`
                www.instagram.com/gusrobatto/
                www.facebook.com/gusrobatto
                • Gus RG Offline
                  Gus R
                  Fredo,
                  Never mind. I uninstalled and reinstalled the Fredo6 library and it's all back to normal.
                  • Gus RG Offline
                    Gus R
                    Fredo,
                    This is happening again with the same Ruby console errors and work around only this time uninstalling and reinstalling LibFredo didn't work. The rest of your plugins are working fine.
                    @gus r said:
                    Fredo,
                    • fredo6F Offline
                      This bug is normally fixed in LibFredo6 v13.3a, just published.
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
                        LibFredo6 13.3a includes:
                        • Major bug fixing (error about wdlg_from_key undefined)
                        • Bug fixing for FredoSpline (when drawing splines over an image)
                        • Gus RG Offline
                          Gus R
                          Thanks Fredo.
                            Dayton28
                            @fredo6 said:
                            LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
                            The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
                            /pluginrepo/rbz/
                            /var/www/html/pluginrepo/rbz/LibFredo6.rbz
                            File does not exist. Make sure you specified correct file name.
                              That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
                              from where you can then download its RBZ.
                              It's perhaps more sensible to go directly through the PluginStore, via two clicks...
                              https://sketchucation.com/pluginstore?pln=LibFredo6
                              Or even easier... use the SketchUcation Toolset's ExtensionStore³ ??
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
                                LibFredo6 13.4a includes:
                                • bug fixing
                                • Support for ThruPaint v2.1a
                                  art900
                                  I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
                                    art900
                                    well never mind, it works now i just needed to restart my computer i guess..
                                      kpbarbee
                                      The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
                                      Help!
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
                                        LibFredo6 13.5a includes:
                                        • bug fixing for potential problems at startup
                                        • support for future compatibility
                                        • fredo6F Offline
                                          Could you do the following, assuming you have Sketchup 2021 or 2022.
                                          1. Open the Ruby Console (menu Extension > Developer)
                                          2. Close Sketchup
                                          3. Open Sketchup - The Ruby console should open automatically and potentially display error messages.
                                          4. Keep the Ruby console opened when launching my plugins.
                                          • I Offline
                                            igorassis
                                            Still having the same issues with this version,i cant use most of your plugins, im having this problem
                                            path=C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware
                                            no language file.
                                            tb_mode,single
                                            tb_Settingout,true
                                            tb_Draw,true
                                            tb_Edit,true
                                            tb_Array,true
                                            tb_Wall,true
                                            tb_Staircase,true
                                            tb_Win,true
                                            tb_Roof,true
                                            point_on_face,true
                                            divide,true
                                            align,true
                                            perpendicular_line,true
                                            fonplane,true
                                            bestface,true
                                            extrude1,true
                                            extrude2,true
                                            move_vertex,true
                                            fillet,true
                                            chamfer,true
                                            extend,true
                                            offset_edge,true
                                            hline_faces,true
                                            slopeedges,true
                                            linear_array,true
                                            rect_array,true
                                            polar_array,true
                                            vx_wall,true
                                            opening,true
                                            hgroove,true
                                            staircase1,true
                                            staircase2,true
                                            staircase3,true
                                            staircase4,true
                                            spiralstair,true
                                            escalator,true
                                            wframe,true
                                            dframe,true
                                            paneldivide,true
                                            screen1,true
                                            hlouvres,true
                                            vlouvres,true
                                            rafter1,true
                                            roof1,true
                                            hiproof,true
                                            revsurf,true
                                            rgrille,true
                                            cgrille,true
                                            loading 1001bitmenu >> true
                                            "English"
                                            I, [2022-11-11T09;26;56.049506 #6024]  INFO -- datasmith; Loading 'C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'...
                                            I, [2022-11-11T09;26;56.053087 #6024]  INFO -- datasmith; Loading plugin binary module from C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so
                                            I, [2022-11-11T09;26;56.063538 #6024]  INFO -- datasmith; Engine Path; 'C;\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI; true
                                            I, [2022-11-11T09;26;56.436781 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                            License expiration; 2022-09-15 15;21;59 UTC, Left; -57 days
                                            INFO; container(features) created... [Plugin.Application]
                                            INFO; app created... [Plugin.Application]
                                            IsLoaded; false
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;17; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;18; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;19; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;20; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;21; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;22; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;23; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;24; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;25; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;26; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;27; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;28; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;29; warning; encountered \r in middle of line, treated as a mere space
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;30; warning; encountered \r in middle of line, treated as a mere space
                                            true
                                            E;/2022/Tools/RubyStdLib/SecureRandom.rb;309; warning; already initialized constant Random;;Formatter;;ALPHANUMERIC
                                            E;/2022/Tools/RubyStdLib/securerandom.rb;309; warning; previous definition of ALPHANUMERIC was here
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe;4362; warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                                            [D5 Converter] light data restored from attribute.
                                            I, [2022-11-11T09;27;02.901161 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe;358; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe;374; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                            Error; #<ArgumentError; wrong number of arguments (given 1, expected 0)>
                                            C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb;148;in `load'
                                            eval;1;in `block in use_libraries'
                                            eval;1;in `each'
                                            eval;1;in `use_libraries'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `general_init'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `use_libraries'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe;73;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `initialize__'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;160;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `show'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;66;in `time_for_check?'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;453;in `block in after_startup'
                                            Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;445;in `invoke_quick_launcher'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;291;in `block in configure'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                                            LAUNCHER TEM 9196708826.464672
                                            "Add help menu!"
                                            "create new"
                                            "created"
                                            #<Sketchup;;Menu;0x00000234debaa670>
                                            (eval);23; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                            "Add help menu!"
                                            "created"
                                            Error; #<NoMethodError; undefined method `add_item' for nil;NilClass>
                                            (eval);40;in `block in <module;Help>'
                                            "created"
                                            (eval);199;in `block in <module;Notification>'
                                            LAUNCHER TEM 9196708866.898788
                                            Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfe10cd0>>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;876;in `param_load'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;366;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;240;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `launch'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;176;in `action__mapping'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;103;in `launch_action'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;119;in `block in startup'
                                            Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bdc51a90>>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;246;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `launch'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;120;in `block in startup'
                                            Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfbc7b40>>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;132;in `invoke_quick_launcher'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;103;in `block in startup'
                                            LAUNCHER TEM 9196708988.201132
                                            Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234c007c820>
                                            Did you mean?  validate_current_selection>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;553;in `notify_action'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;584;in `terminate_current_selection'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;745;in `notify_from_vbox'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `call'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `onLButtonUp'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;2486;in `onLButtonUp'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;1152;in `onLButtonUp'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;508;in `onLButtonUp'
                                            LAUNCHER TEM 9196709028.635246
                                            Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234bf204068>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;279;in `execute_validate'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;450;in `onReturn'
                                            LAUNCHER TEM 9196710848.170437
                                            Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                                            c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 111
                                            • 112
                                            • 94 / 112
