    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      DCDP
      @fredo6 said:
      @dcdp said:
      But today everything is ok. It seems that the computer relaunch did be more efficient than a simple Sketchup relaunch.
      There may be problems when you install LibFredo6 and have several instances of Sketchup open. You need to close them all.
      I have closed entirely Sketchup.
      • fredo6F
        NEW RELEASE: LibFredo6 v13.2a - 16 Sep 22
        LibFredo6 13.2a includes:
        • Various fixes for my plugins
        • Support for future plugins
        Note that the problem with Mac M1 platform, present in v13.1a, has been solved.
        • Gus RG
          Gus R
          Fredo,
          When I click on check for updates nothing happens.
          Window: Libfredo6 Setting: Check Fredo6 Plugins for Updates. Nothing under there works until I click on Default Parameters and then is starts working.
          This is the error from the Ruby Console:
          Error: #<NoMethodError: undefined methodwdlg_from_key' for Traductor::Wdlg:Class>
          c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:in check_instance_displayed' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:58:in top_dialog'
          c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:336:in block in populate_support_menu' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'`
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • Gus RG
            Gus R
            Fredo,
            Never mind. I uninstalled and reinstalled the Fredo6 library and it's all back to normal.
            • Gus RG
              Gus R
              Fredo,
              This is happening again with the same Ruby console errors and work around only this time uninstalling and reinstalling LibFredo didn't work. The rest of your plugins are working fine.
              @gus r said:
              Fredo,
              • fredo6F
                This bug is normally fixed in LibFredo6 v13.3a, just published.
                • fredo6F
                  NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
                  LibFredo6 13.3a includes:
                  • Major bug fixing (error about wdlg_from_key undefined)
                  • Bug fixing for FredoSpline (when drawing splines over an image)
                  • Gus RG
                    Gus R
                    Thanks Fredo.
                      Dayton28
                      @fredo6 said:
                      LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
                      The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
                      /pluginrepo/rbz/
                      /var/www/html/pluginrepo/rbz/LibFredo6.rbz
                      File does not exist. Make sure you specified correct file name.
                        That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
                        from where you can then download its RBZ.
                        It's perhaps more sensible to go directly through the PluginStore, via two clicks...
                        https://sketchucation.com/pluginstore?pln=LibFredo6
                        Or even easier... use the SketchUcation Toolset's ExtensionStore³ ??
                        • fredo6F
                          NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
                          LibFredo6 13.4a includes:
                          • bug fixing
                          • Support for ThruPaint v2.1a
                            art900
                            I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
                              art900
                              well never mind, it works now i just needed to restart my computer i guess..
                              • K
                                kpbarbee
                                The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
                                Help!
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
                                  LibFredo6 13.5a includes:
                                  • bug fixing for potential problems at startup
                                  • support for future compatibility
                                  • fredo6F
                                    Could you do the following, assuming you have Sketchup 2021 or 2022.
                                    1. Open the Ruby Console (menu Extension > Developer)
                                    2. Close Sketchup
                                    3. Open Sketchup - The Ruby console should open automatically and potentially display error messages.
                                    4. Keep the Ruby console opened when launching my plugins.
                                    • I
                                      igorassis
                                      Still having the same issues with this version,i cant use most of your plugins, im having this problem
                                      path=C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware
                                      no language file.
                                      tb_mode,single
                                      tb_Settingout,true
                                      tb_Draw,true
                                      tb_Edit,true
                                      tb_Array,true
                                      tb_Wall,true
                                      tb_Staircase,true
                                      tb_Win,true
                                      tb_Roof,true
                                      point_on_face,true
                                      divide,true
                                      align,true
                                      perpendicular_line,true
                                      fonplane,true
                                      bestface,true
                                      extrude1,true
                                      extrude2,true
                                      move_vertex,true
                                      fillet,true
                                      chamfer,true
                                      extend,true
                                      offset_edge,true
                                      hline_faces,true
                                      slopeedges,true
                                      linear_array,true
                                      rect_array,true
                                      polar_array,true
                                      vx_wall,true
                                      opening,true
                                      hgroove,true
                                      staircase1,true
                                      staircase2,true
                                      staircase3,true
                                      staircase4,true
                                      spiralstair,true
                                      escalator,true
                                      wframe,true
                                      dframe,true
                                      paneldivide,true
                                      screen1,true
                                      hlouvres,true
                                      vlouvres,true
                                      rafter1,true
                                      roof1,true
                                      hiproof,true
                                      revsurf,true
                                      rgrille,true
                                      cgrille,true
                                      loading 1001bitmenu >> true
                                      "English"
                                      I, [2022-11-11T09;26;56.049506 #6024]  INFO -- datasmith; Loading 'C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'...
                                      I, [2022-11-11T09;26;56.053087 #6024]  INFO -- datasmith; Loading plugin binary module from C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so
                                      I, [2022-11-11T09;26;56.063538 #6024]  INFO -- datasmith; Engine Path; 'C;\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI; true
                                      I, [2022-11-11T09;26;56.436781 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                      License expiration; 2022-09-15 15;21;59 UTC, Left; -57 days
                                      INFO; container(features) created... [Plugin.Application]
                                      INFO; app created... [Plugin.Application]
                                      IsLoaded; false
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;17; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;18; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;19; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;20; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;21; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;22; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;23; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;24; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;25; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;26; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;27; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;28; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;29; warning; encountered \r in middle of line, treated as a mere space
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;30; warning; encountered \r in middle of line, treated as a mere space
                                      true
                                      E;/2022/Tools/RubyStdLib/SecureRandom.rb;309; warning; already initialized constant Random;;Formatter;;ALPHANUMERIC
                                      E;/2022/Tools/RubyStdLib/securerandom.rb;309; warning; previous definition of ALPHANUMERIC was here
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe;4362; warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                                      [D5 Converter] light data restored from attribute.
                                      I, [2022-11-11T09;27;02.901161 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe;358; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe;374; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                      Error; #<ArgumentError; wrong number of arguments (given 1, expected 0)>
                                      C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb;148;in `load'
                                      eval;1;in `block in use_libraries'
                                      eval;1;in `each'
                                      eval;1;in `use_libraries'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `general_init'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `use_libraries'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe;73;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `initialize__'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;160;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `show'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;66;in `time_for_check?'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;453;in `block in after_startup'
                                      Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;445;in `invoke_quick_launcher'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;291;in `block in configure'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                                      LAUNCHER TEM 9196708826.464672
                                      "Add help menu!"
                                      "create new"
                                      "created"
                                      #<Sketchup;;Menu;0x00000234debaa670>
                                      (eval);23; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                      "Add help menu!"
                                      "created"
                                      Error; #<NoMethodError; undefined method `add_item' for nil;NilClass>
                                      (eval);40;in `block in <module;Help>'
                                      "created"
                                      (eval);199;in `block in <module;Notification>'
                                      LAUNCHER TEM 9196708866.898788
                                      Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfe10cd0>>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;876;in `param_load'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;366;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;240;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `launch'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;176;in `action__mapping'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;103;in `launch_action'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;119;in `block in startup'
                                      Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bdc51a90>>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;246;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `launch'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;120;in `block in startup'
                                      Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfbc7b40>>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;132;in `invoke_quick_launcher'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;103;in `block in startup'
                                      LAUNCHER TEM 9196708988.201132
                                      Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234c007c820>
                                      Did you mean?  validate_current_selection>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;553;in `notify_action'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;584;in `terminate_current_selection'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;745;in `notify_from_vbox'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `call'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `onLButtonUp'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;2486;in `onLButtonUp'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;1152;in `onLButtonUp'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;508;in `onLButtonUp'
                                      LAUNCHER TEM 9196709028.635246
                                      Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234bf204068>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;279;in `execute_validate'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;450;in `onReturn'
                                      LAUNCHER TEM 9196710848.170437
                                      Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                                      c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                                        Do you have the newest versions of LibFredo and the SketchUcation toolset installed and SketchUp restarted ?
                                        Other extensions loading seem to be having issues, so they could be causing problems with Fredo's files loading subsequently...
                                        Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ?
                                        • I
                                          igorassis
                                          it worked, thanks
                                          • Stephane_14S
                                            Stephane_14
                                            Bonjour,
                                            Les plugins de Fredo6 n’affiches plus les icônes puis j'ai remarqué que ExtensionStore V.429 n’ été plus branché à internet avec mes identifiants, Cela est résolu mais c'est étonnant.
                                            Autre soucis depuis la mise à jour de FredoLib V3.5a l'utilisation de Curviloft provoque un Plantage systématique de Sketchup.
                                            Avez vous des explications ?
                                            Cordialement
                                            Hello,
                                            The Fredo6 plugins no longer display the icons then I noticed that ExtensionStore V.429 was no longer connected to the internet with my credentials, This is resolved but it's surprising.
                                            Another concern since the update of FredoLib V3.5a the use of Curviloft causes a systematic crash of Sketchup.
                                            Do you have any explanations?
                                            Cordially
                                            Stéphane HENRY
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
