    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      DCDP
      @fredo6 said:
      @dcdp said:
      I installed the latest version of LibFredo6. But Curviloft does not work and I can't open any setup window (Purge; Check for updates).
      What I must to do ? Must I uninstall all your plugins and reinstall them ?
      Before launching Curviloft, could you open the Ruby Console. Then Launch Curviloft, and what the console for any error message.
      By the way, do you have a Mac M1?
      No, I'm working on iMac with Intel Processor.
      But today everything is ok. It seems that the computer relaunch did be more efficient than a simple Sketchup relaunch.
      Thanks for your help (even by mind)
      • fredo6F
        There may be problems when you install LibFredo6 and have several instances of Sketchup open. You need to close them all.
          DCDP
          I have closed entirely Sketchup.
          • fredo6F
            NEW RELEASE: LibFredo6 v13.2a - 16 Sep 22
            LibFredo6 13.2a includes:
            • Various fixes for my plugins
            • Support for future plugins
            Note that the problem with Mac M1 platform, present in v13.1a, has been solved.
            • Gus RG
              Gus R
              Fredo,
              When I click on check for updates nothing happens.
              Window: Libfredo6 Setting: Check Fredo6 Plugins for Updates. Nothing under there works until I click on Default Parameters and then is starts working.
              This is the error from the Ruby Console:
              Error: #<NoMethodError: undefined methodwdlg_from_key' for Traductor::Wdlg:Class>
              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:in check_instance_displayed' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:58:in top_dialog'
              c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:336:in block in populate_support_menu' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'`
              www.instagram.com/gusrobatto/
              www.facebook.com/gusrobatto
              • Gus RG
                Gus R
                Fredo,
                Never mind. I uninstalled and reinstalled the Fredo6 library and it's all back to normal.
                • Gus RG
                  Gus R
                  Fredo,
                  This is happening again with the same Ruby console errors and work around only this time uninstalling and reinstalling LibFredo didn't work. The rest of your plugins are working fine.
                  @gus r said:
                  Fredo,
                  • fredo6F
                    This bug is normally fixed in LibFredo6 v13.3a, just published.
                    • fredo6F
                      NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
                      LibFredo6 13.3a includes:
                      • Major bug fixing (error about wdlg_from_key undefined)
                      • Bug fixing for FredoSpline (when drawing splines over an image)
                      • Gus RG
                        Gus R
                        Thanks Fredo.
                          Dayton28
                          @fredo6 said:
                          LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
                          The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
                          /pluginrepo/rbz/
                          /var/www/html/pluginrepo/rbz/LibFredo6.rbz
                          File does not exist. Make sure you specified correct file name.
                            That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
                            from where you can then download its RBZ.
                            It's perhaps more sensible to go directly through the PluginStore, via two clicks...
                            https://sketchucation.com/pluginstore?pln=LibFredo6
                            Or even easier... use the SketchUcation Toolset's ExtensionStore³ ??
                            • fredo6F
                              NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
                              LibFredo6 13.4a includes:
                              • bug fixing
                              • Support for ThruPaint v2.1a
                                art900
                                I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
                                  art900
                                  well never mind, it works now i just needed to restart my computer i guess..
                                  • K
                                    kpbarbee
                                    The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
                                    Help!
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
                                      LibFredo6 13.5a includes:
                                      • bug fixing for potential problems at startup
                                      • support for future compatibility
                                      • fredo6F
                                        Could you do the following, assuming you have Sketchup 2021 or 2022.
                                        1. Open the Ruby Console (menu Extension > Developer)
                                        2. Close Sketchup
                                        3. Open Sketchup - The Ruby console should open automatically and potentially display error messages.
                                        4. Keep the Ruby console opened when launching my plugins.
                                        • I
                                          igorassis
                                          Still having the same issues with this version,i cant use most of your plugins, im having this problem
                                          path=C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware
                                          no language file.
                                          tb_mode,single
                                          tb_Settingout,true
                                          tb_Draw,true
                                          tb_Edit,true
                                          tb_Array,true
                                          tb_Wall,true
                                          tb_Staircase,true
                                          tb_Win,true
                                          tb_Roof,true
                                          point_on_face,true
                                          divide,true
                                          align,true
                                          perpendicular_line,true
                                          fonplane,true
                                          bestface,true
                                          extrude1,true
                                          extrude2,true
                                          move_vertex,true
                                          fillet,true
                                          chamfer,true
                                          extend,true
                                          offset_edge,true
                                          hline_faces,true
                                          slopeedges,true
                                          linear_array,true
                                          rect_array,true
                                          polar_array,true
                                          vx_wall,true
                                          opening,true
                                          hgroove,true
                                          staircase1,true
                                          staircase2,true
                                          staircase3,true
                                          staircase4,true
                                          spiralstair,true
                                          escalator,true
                                          wframe,true
                                          dframe,true
                                          paneldivide,true
                                          screen1,true
                                          hlouvres,true
                                          vlouvres,true
                                          rafter1,true
                                          roof1,true
                                          hiproof,true
                                          revsurf,true
                                          rgrille,true
                                          cgrille,true
                                          loading 1001bitmenu >> true
                                          "English"
                                          I, [2022-11-11T09;26;56.049506 #6024]  INFO -- datasmith; Loading 'C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'...
                                          I, [2022-11-11T09;26;56.053087 #6024]  INFO -- datasmith; Loading plugin binary module from C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so
                                          I, [2022-11-11T09;26;56.063538 #6024]  INFO -- datasmith; Engine Path; 'C;\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI; true
                                          I, [2022-11-11T09;26;56.436781 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                          License expiration; 2022-09-15 15;21;59 UTC, Left; -57 days
                                          INFO; container(features) created... [Plugin.Application]
                                          INFO; app created... [Plugin.Application]
                                          IsLoaded; false
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;17; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;18; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;19; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;20; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;21; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;22; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;23; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;24; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;25; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;26; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;27; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;28; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;29; warning; encountered \r in middle of line, treated as a mere space
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb;30; warning; encountered \r in middle of line, treated as a mere space
                                          true
                                          E;/2022/Tools/RubyStdLib/SecureRandom.rb;309; warning; already initialized constant Random;;Formatter;;ALPHANUMERIC
                                          E;/2022/Tools/RubyStdLib/securerandom.rb;309; warning; previous definition of ALPHANUMERIC was here
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe;4362; warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                                          [D5 Converter] light data restored from attribute.
                                          I, [2022-11-11T09;27;02.901161 #6024]  INFO -- datasmith; Activate DirectLink exporter for Model; 'boidior'('D;\SKETCHUPMODEL\boidior.skp')
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe;358; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe;374; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                          Error; #<ArgumentError; wrong number of arguments (given 1, expected 0)>
                                          C;/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb;148;in `load'
                                          eval;1;in `block in use_libraries'
                                          eval;1;in `each'
                                          eval;1;in `use_libraries'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `general_init'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe;87;in `use_libraries'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe;73;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe;837;in `initialize__'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;160;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;153;in `show'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe;66;in `time_for_check?'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;453;in `block in after_startup'
                                          Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;445;in `invoke_quick_launcher'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe;291;in `block in configure'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                                          LAUNCHER TEM 9196708826.464672
                                          "Add help menu!"
                                          "create new"
                                          "created"
                                          #<Sketchup;;Menu;0x00000234debaa670>
                                          (eval);23; warning; calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                                          "Add help menu!"
                                          "created"
                                          Error; #<NoMethodError; undefined method `add_item' for nil;NilClass>
                                          (eval);40;in `block in <module;Help>'
                                          "created"
                                          (eval);199;in `block in <module;Notification>'
                                          LAUNCHER TEM 9196708866.898788
                                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfe10cd0>>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;876;in `param_load'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;366;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;240;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;196;in `launch'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;176;in `action__mapping'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;103;in `launch_action'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;119;in `block in startup'
                                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bdc51a90>>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;246;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe;198;in `launch'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe;120;in `block in startup'
                                          Error; #<NoMethodError; private method `load' called for #<Traductor;;ParameterManager;0x00000234bfbc7b40>>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;132;in `invoke_quick_launcher'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe;103;in `block in startup'
                                          LAUNCHER TEM 9196708988.201132
                                          Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234c007c820>
                                          Did you mean?  validate_current_selection>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;553;in `notify_action'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;584;in `terminate_current_selection'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;745;in `notify_from_vbox'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `call'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;3987;in `onLButtonUp'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;2486;in `onLButtonUp'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe;1152;in `onLButtonUp'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;508;in `onLButtonUp'
                                          LAUNCHER TEM 9196709028.635246
                                          Error; #<NameError; undefined local variable or method `accept_current_selection' for #<Traductor;;EdgePicker;0x00000234bf204068>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;279;in `execute_validate'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe;450;in `onReturn'
                                          LAUNCHER TEM 9196710848.170437
                                          Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                                          c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                                            Do you have the newest versions of LibFredo and the SketchUcation toolset installed and SketchUp restarted ?
                                            Other extensions loading seem to be having issues, so they could be causing problems with Fredo's files loading subsequently...
                                            Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ?
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 115
                                            • 116
                                            • 94 / 116
