    Overhead Line Shaft Detail
    44 Posts 12 Posters 9.6k Views 12 Watching
      Thank you Bryan.
      Not sure where I'll add this but I was doodling some more.
      https://live.staticflickr.com/65535/52368551002_f216e35d3e.jpg
      • Bryan KB
        Spline gears! Nice! πŸ‘
        • marked001M
          marked001
          This is getting better and better. I was going to say, when is the animation coming but Rich beat me to it.
          http://www.revision21vis.com
          instagram: revi21on
            Thank you.
            I got a little sidetracked.
            Front axle I-beam from around 1905.
            https://live.staticflickr.com/65535/52396162465_cf3573874f_z.jpg
            https://live.staticflickr.com/65535/52395333604_d8f90025bf_z.jpg
            And a wheel for a rail car from around 1895.
            https://live.staticflickr.com/65535/50190447637_dff8fa12e2_z.jpg
              That's some delicious modelling in the axle. Especially the top of the neck as it tapers and bends.
                Thank you very much my friend. That was fun to work out.
                • Bryan KB
                  Excellent modeling as always!
                  • HornOxxH
                    HornOxx
                    @dave r said:
                    Front axle I-beam from around 1905...and a wheel for a rail car from around 1895
                    wunderbar Dave!
                    never trust a skinny cook
                      I'm not exactly sure what this is used for but I made a model of it anyway. The handle drives the ratchet wheel which drive the pointy bit on top upward. There's a tapered squre hole on the bottom of the handle which would appear to allow the handle to sit on something. I presume the pointing bit is used to split something.
                      https://live.staticflickr.com/65535/52404988741_b98d69b420_c.jpg
                      And a cut-away view showing the threads and the rachet wheel and pawl.
                      https://live.staticflickr.com/65535/52405494888_f96b82d3eb_c.jpg
                      • Bryan KB
                        Another excellent machine model!
                          Mill3rLuke
                          @dave r said:
                          Here's a detail showing some of the screw threads. Added some color in the render.
                          https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
                          Do you do this for a living?
                            Do what? Make 3D models in SketchUp? Yes. This model is an assembly of a bunch of separate parts I modeled mostly for my own entertainment and to practice using SketchUp.
                              Mill3rLuke
                              No i mean are you a designer by profession? do you make you income from designing etc?
                                I do some design work, mostly furniture design.
                                  https://live.staticflickr.com/65535/52432984724_50577dc3c7_k.jpg
                                  • Bryan KB
                                    Small pipe cutter!
                                    Another excellent model. πŸ‘
                                    • ntxdaveN
                                      ntxdave
                                      @bryan k said:
                                      Small pipe cutter!
                                      Ditto πŸ‘ πŸ‘
                                      Press F1...thank me later
                                      • boofredlayB
                                        boofredlay
                                        πŸ‘
                                        • marked001M
                                          marked001
                                          Great stuff.
                                          instagram: revi21on
                                            Very sharp. πŸ‘
                                            • 2 / 3
