    Overhead Line Shaft Detail
    44 Posts 12 Posters 8.1k Views 12 Watching
      Very nice work Dave 👍 there is something particularly appealing to me about that model.
        @l i am said:
        ...there is something particularly appealing to me about that model.
        It's bananas!
          Thank you gentlemen.
            Here's a detail showing some of the screw threads. Added some color in the render.
            https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
            • tuna1957T Offline
              tuna1957
              The detail in your mechanical models just slays me 👍 👍
                Thank you sir. Maybe it makes up for my lack of skill with rendering that you have. 😉
                  The best renders are the ones that convey the right amount of details.
                  This is one of those renders where you appreciate the accuracy and level of modelling involved.
                  Not one where errors are disguised using texture maps etc
                  Cannot wait for you to animate it 😛
                  • tuna1957T Offline
                    tuna1957
                    Dave your rendering skills are more than “just fine”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                    • tuna1957T Offline
                      tuna1957
                      @tuna1957 said:
                      Dave your rendering skills are well above “average”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                        Thank you Rich and Charles.
                        Rich, I expect I'll need to build out the shop more before I try to animate it. 😉
                        • Bryan KB Offline
                          Top notch details and illustration! 👍
                            Thank you Bryan.
                            Not sure where I'll add this but I was doodling some more.
                            https://live.staticflickr.com/65535/52368551002_f216e35d3e.jpg
                            • Bryan KB Offline
                              Spline gears! Nice! 👍
                              • marked001M Offline
                                marked001
                                This is getting better and better. I was going to say, when is the animation coming but Rich beat me to it.
                                http://www.revision21vis.com
                                instagram: revi21on
                                  Thank you.
                                  I got a little sidetracked.
                                  Front axle I-beam from around 1905.
                                  https://live.staticflickr.com/65535/52396162465_cf3573874f_z.jpg
                                  https://live.staticflickr.com/65535/52395333604_d8f90025bf_z.jpg
                                  And a wheel for a rail car from around 1895.
                                  https://live.staticflickr.com/65535/50190447637_dff8fa12e2_z.jpg
                                    That's some delicious modelling in the axle. Especially the top of the neck as it tapers and bends.
                                      Thank you very much my friend. That was fun to work out.
                                      • Bryan KB Offline
                                        Excellent modeling as always!
                                        • HornOxxH Offline
                                          HornOxx
                                          @dave r said:
                                          Front axle I-beam from around 1905...and a wheel for a rail car from around 1895
                                          wunderbar Dave!
                                          never trust a skinny cook
                                            I'm not exactly sure what this is used for but I made a model of it anyway. The handle drives the ratchet wheel which drive the pointy bit on top upward. There's a tapered squre hole on the bottom of the handle which would appear to allow the handle to sit on something. I presume the pointing bit is used to split something.
                                            https://live.staticflickr.com/65535/52404988741_b98d69b420_c.jpg
                                            And a cut-away view showing the threads and the rachet wheel and pawl.
                                            https://live.staticflickr.com/65535/52405494888_f96b82d3eb_c.jpg
                                            • 2 / 3
