    Overhead Line Shaft Detail
    44 Posts 12 Posters 7.1k Views 12 Watching
    • tuna1957T Online
      tuna1957
      @tuna1957 said:
      @dave r said:
      Maybe it makes up for my lack of skill with rendering that you have. πŸ˜‰
      Dave your rendering skills are well above β€œaverage”. We just generally do different types of modeling….. my craziness just allows for weirder results πŸ‘ πŸ˜†
        Thank you Rich and Charles.
        Rich, I expect I'll need to build out the shop more before I try to animate it. πŸ˜‰
        • Bryan KB Offline
          Top notch details and illustration! πŸ‘
            Thank you Bryan.
            Not sure where I'll add this but I was doodling some more.
            https://live.staticflickr.com/65535/52368551002_f216e35d3e.jpg
            • Bryan KB Offline
              Spline gears! Nice! πŸ‘
              • marked001M Offline
                marked001
                This is getting better and better. I was going to say, when is the animation coming but Rich beat me to it.
                http://www.revision21vis.com
                instagram: revi21on
                  Thank you.
                  I got a little sidetracked.
                  Front axle I-beam from around 1905.
                  https://live.staticflickr.com/65535/52396162465_cf3573874f_z.jpg
                  https://live.staticflickr.com/65535/52395333604_d8f90025bf_z.jpg
                  And a wheel for a rail car from around 1895.
                  https://live.staticflickr.com/65535/50190447637_dff8fa12e2_z.jpg
                    That's some delicious modelling in the axle. Especially the top of the neck as it tapers and bends.
                      Thank you very much my friend. That was fun to work out.
                      • Bryan KB Offline
                        Excellent modeling as always!
                        • HornOxxH Offline
                          HornOxx
                          @dave r said:
                          Front axle I-beam from around 1905...and a wheel for a rail car from around 1895
                          wunderbar Dave!
                          never trust a skinny cook
                            I'm not exactly sure what this is used for but I made a model of it anyway. The handle drives the ratchet wheel which drive the pointy bit on top upward. There's a tapered squre hole on the bottom of the handle which would appear to allow the handle to sit on something. I presume the pointing bit is used to split something.
                            https://live.staticflickr.com/65535/52404988741_b98d69b420_c.jpg
                            And a cut-away view showing the threads and the rachet wheel and pawl.
                            https://live.staticflickr.com/65535/52405494888_f96b82d3eb_c.jpg
                            • Bryan KB Offline
                              Another excellent machine model!
                                Mill3rLuke
                                @dave r said:
                                Here's a detail showing some of the screw threads. Added some color in the render.
                                https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
                                Do you do this for a living?
                                  Do what? Make 3D models in SketchUp? Yes. This model is an assembly of a bunch of separate parts I modeled mostly for my own entertainment and to practice using SketchUp.
                                    Mill3rLuke
                                    No i mean are you a designer by profession? do you make you income from designing etc?
                                      I do some design work, mostly furniture design.
                                        https://live.staticflickr.com/65535/52432984724_50577dc3c7_k.jpg
                                        • Bryan KB Offline
                                          Small pipe cutter!
                                          Another excellent model. πŸ‘
                                          • ntxdaveN Offline
                                            ntxdave
                                            @bryan k said:
                                            Small pipe cutter!
                                            Ditto πŸ‘ πŸ‘
                                            Press F1...thank me later
                                            • 2 / 3
