    Overhead Line Shaft Detail
    44 Posts 12 Posters 9.6k Views 12 Watching
    • HornOxxH
      HornOxx
      @rich o brien said:
      I wish you would share larger images 👍 ...
      also for me please !!! 😄
      And again a beautiful work which shows that accurate work and details pay off! 👍
      never trust a skinny cook
        db11
        Yes. There should be a sort of fork with a long wooden handle to shift the belt back and forth between fast and loose pulleys. I have yet to find dimensioned drawings or even really good photos of the belt shifter.
        Dave — it's not a dimensioned drawing or even a photo, but at 2:45 in the video linked above there's a good shot of the belt shifter you describe shifting between the two pulleys. (and again at around 4:00 showing the shift of power to the bandsaw)
        Maybe you could contact them for good stills of the mechanism(s)? (Perhaps they also have drawings?)
        Just a thought.
          Thanks Doug. I'll look.
          Hornoxx and Rich, if you click on the last two images you should see the full size version of them. And thank you!
            Another very fine piece. Cracking result. 👊
            • Bryan KB
              Always great work! 👍
              • L
                Very nice work Dave 👍 there is something particularly appealing to me about that model.
                  @l i am said:
                  ...there is something particularly appealing to me about that model.
                  It's bananas!
                    Thank you gentlemen.
                      Here's a detail showing some of the screw threads. Added some color in the render.
                      https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
                      • tuna1957T
                        tuna1957
                        The detail in your mechanical models just slays me 👍 👍
                          Thank you sir. Maybe it makes up for my lack of skill with rendering that you have. 😉
                            The best renders are the ones that convey the right amount of details.
                            This is one of those renders where you appreciate the accuracy and level of modelling involved.
                            Not one where errors are disguised using texture maps etc
                            Cannot wait for you to animate it 😛
                            • tuna1957T
                              tuna1957
                              Dave your rendering skills are more than “just fine”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                              • tuna1957T
                                tuna1957
                                @tuna1957 said:
                                Dave your rendering skills are well above “average”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                                  Thank you Rich and Charles.
                                  Rich, I expect I'll need to build out the shop more before I try to animate it. 😉
                                  • Bryan KB
                                    Top notch details and illustration! 👍
                                      Thank you Bryan.
                                      Not sure where I'll add this but I was doodling some more.
                                      https://live.staticflickr.com/65535/52368551002_f216e35d3e.jpg
                                      • Bryan KB
                                        Spline gears! Nice! 👍
                                        • marked001M
                                          marked001
                                          This is getting better and better. I was going to say, when is the animation coming but Rich beat me to it.
                                          http://www.revision21vis.com
                                          instagram: revi21on
                                            Thank you.
                                            I got a little sidetracked.
                                            Front axle I-beam from around 1905.
                                            https://live.staticflickr.com/65535/52396162465_cf3573874f_z.jpg
                                            https://live.staticflickr.com/65535/52395333604_d8f90025bf_z.jpg
                                            And a wheel for a rail car from around 1895.
                                            https://live.staticflickr.com/65535/50190447637_dff8fa12e2_z.jpg
                                            • 1 / 3
