    Overhead Line Shaft Detail
    44 Posts 12 Posters 9.2k Views 12 Watching
      Thank you sir.
      @tuna1957 said:
      Side note I recall seeing pictures where workers would use a wooden stick to pop the belts off and on the pulleys….
      Yes. There should be a sort of fork with a long wooden handle to shift the belt back and forth between fast and loose pulleys. I have yet to find dimensioned drawings or even really good photos of the belt shifter.
        db11
        Really cool Dave.
        I've enjoyed seeing the evolution of your vintage lathe model and look forward to seeing it hooked up to your newly-modelled line shaft!
        Makes me think of the Hancock Shaker Village shop:
        (beautiful vintage shop and great video of this type of system in action for those who aren't familiar)
        • HornOxxH Offline
          HornOxx
          @rich o brien said:
          I wish you would share larger images 👍 ...
          also for me please !!! 😄
          And again a beautiful work which shows that accurate work and details pay off! 👍
          never trust a skinny cook
            db11
            Dave — it's not a dimensioned drawing or even a photo, but at 2:45 in the video linked above there's a good shot of the belt shifter you describe shifting between the two pulleys. (and again at around 4:00 showing the shift of power to the bandsaw)
            Maybe you could contact them for good stills of the mechanism(s)? (Perhaps they also have drawings?)
            Just a thought.
              Thanks Doug. I'll look.
              Hornoxx and Rich, if you click on the last two images you should see the full size version of them. And thank you!
                Another very fine piece. Cracking result. 👊
                • Bryan KB Offline
                  Always great work! 👍
                    Very nice work Dave 👍 there is something particularly appealing to me about that model.
                      @l i am said:
                      ...there is something particularly appealing to me about that model.
                      It's bananas!
                        Thank you gentlemen.
                          Here's a detail showing some of the screw threads. Added some color in the render.
                          https://live.staticflickr.com/65535/52353430344_f195dc6558_o.png
                          • tuna1957T Offline
                            tuna1957
                            The detail in your mechanical models just slays me 👍 👍
                              Thank you sir. Maybe it makes up for my lack of skill with rendering that you have. 😉
                                The best renders are the ones that convey the right amount of details.
                                This is one of those renders where you appreciate the accuracy and level of modelling involved.
                                Not one where errors are disguised using texture maps etc
                                Cannot wait for you to animate it 😛
                                • tuna1957T Offline
                                  tuna1957
                                  Dave your rendering skills are more than “just fine”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                                  • tuna1957T Offline
                                    tuna1957
                                    @tuna1957 said:
                                    Dave your rendering skills are well above “average”. We just generally do different types of modeling….. my craziness just allows for weirder results 👍 😆
                                      Thank you Rich and Charles.
                                      Rich, I expect I'll need to build out the shop more before I try to animate it. 😉
                                      • Bryan KB Offline
                                        Top notch details and illustration! 👍
                                          Thank you Bryan.
                                          Not sure where I'll add this but I was doodling some more.
                                          https://live.staticflickr.com/65535/52368551002_f216e35d3e.jpg
                                          • Bryan KB Offline
                                            Spline gears! Nice! 👍
                                            • 1 / 3
