    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    103 Posts 39 Posters 124.9k Views 39 Watching
      Buckyman
      I have used Visuhole successfully to stamp a logo into my model
      I noticed after converting to STEP file with FreeCAD that there are many hidden lines after the stamping, see "after carve.jpg"
      After the carve operation my model is no longer solid. I used CleanUp3 to clean up the model, after that there were a few lines I deleted manually.
      SolidInspector2 says it is a solid
      Solid Solver says it is not
      I am just wondering if the extra lines are to be expected after a carve operation or is there some setting in Visuhole that would avoid this?
      thx
      • fredo6F Offline
        Because of the two holes, the front face will become quite busy with edges when you carve the logo. If your model is at small scale, this can generate issues with the shape being manifold.
        Possibly, you may try by putting rectangular edges around the holes over the main face to isolate them.
          Buckyman
          Or do the carve first, Holes after??
          • H Offline
            Hannahdesigns88
            When I try to download this visuhole plug in, it says its not a sketchup model and wont let me download it...or even begin to download. I have sketch up pro 2022 windows.
              Extensions cannot be opened by SketchUp. You need to use Extensions > Extension Manager to install the .RBZ file
              • BoxB Offline
                To follow on from Rich's comment, it sounds like you have the download dialog set to 'Open with' rather than 'Save File' You need to set it to save file to get the RBZ to your computer to then get the extension manager to use it.
                  ploniman
                  it doesnt work as it should. tried several fonts but, always with little errors. see picure
                  what to do?
                  • BoxB Offline
                    Scale is the first most likely issue, how small is your model.
                    Scale up by 100 and see if it works.
                      what to do?
                      [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
                      Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
                      • ezyuzinE Offline
                        ezyuzin Extension Creator
                        Hello,
                        Is it possible to create holes with specific depth in multilayer objects
                        For sample, I was unable to find correct results
                        using drill and carve commands
                          To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
                          But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
                          • ezyuzinE Offline
                            It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
                            I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
                              mac13517a
                              Great Plugin, I love it a LOT!!!
                              I have a question: How can I remove a stencil???
                              Sometime I just require upgrade the stencil or simply remove the old stencil.
                              Kind regards,
                              • F Offline
                                faustcan
                                Hello, where is the download link to Visuhole, please? I bought the licence for 8 plugins including this. Many thanks
                                  Open ExtensionStore dialog in SketchUp
                                  Click the Paste URL icon
                                  https://i.imgur.com/glZOdES.png
                                  In the input put pln=visuhole and click Install
                                  https://i.imgur.com/URWwE2D.png
                                  Restart SketchUp
                                  • fredo6F Offline
                                    NEW RELEASE: VisuHole v1.5a - 01 Apr 24
                                    Requirements:
                                    • LibFredo6 v14.3b
                                    • Sketchucation Plugintore v4.4.0
                                    VisuHole 1.5a is a maintenance release for
                                    • Future compatibility
                                    Home Page of VisuHole for information and Download.
                                    Main post of this VisuHole thread.
                                    • I Offline
                                      ivansmirnov333 Newcomers
                                      Visuhole.
                                      Hello! I'm trying to make a hole in the selection component. What do I do wrong?
                                      Screen Video: link
                                      TIGT 1 Reply Last reply Reply Quote 1
                                        TIG Moderator @ivansmirnov333
                                        @ivansmirnov333
                                        You give too much AND not enough information…
                                        Can you explain what the carious bits are, and what you are trying to do, and preferably attached a simple SKP showing the problem, with steps if necessary - currently your movie is unclear…
                                        I 1 Reply Last reply Reply Quote 0
                                        • I Offline
                                          ivansmirnov333 Newcomers @TIG
                                          @TIG Sorry. New video with my explanations is here: link
                                          SKP is attached.
                                            @ivansmirnov333
                                            This really needs @fredo6 's expertise, but as far as I can see the vertical component with the holes is nested inside a component of several pieces.
                                            If you do not edit and select the appropriate context then the hole cutting doesn't occur in the component ?
                                            • 6 / 6
