    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 144.1k Views 39 Watching
      Hello
      You must click a single face or a group or a component of something planed to the XY axes for make a stencil! 😉
      Can be of course at any z but must be // to xy plane! ❗
      So your vertical one is impossible! 🤓
      • fredo6F
        Actually, you can pick the stencil in any plane, which is given by the face you click.
        But don't click-drag, when you do that. Just click-release
          Cool! ☀ So I was half wrong! 💚
            ACWN
            It doesnt show it very well, but I was actually doing just that right at the beginning of the video. Right around 12 - 14 seconds, when I put the mouse to the center of the group and suddenly get the demo shapes. If I click-release, nothing happens. Uploaded a new movie to show.
            However when I flip it so its laying flat like Pilou says to, I get it right away. 😕
            Visuhole2.wmv
            • fredo6F
              When the stencil is based on a group or component, I was lazy to assume that the Z axis was to be sued as the plan for the stencil.
              I made a change in LibFredo6 v9.5f to treat more general cases.
              • G
                Gildaspaspro
                Bonjour,
                Tout d'abord merci Fredo pour tout ces plugins extraordinaires qui me font tout les jours gagner des heures de dessin. On a du te le dire pleins de fois mais c'est vrai, t'es le boss!!!
                Petite suggestion sur celui-ci. Il me semblerait intéressant d'ajouter des marquages sur l'axe des perçage (ou des extrusions également). On pourrait de cette facon non seulement les déplacer/copié + facilement (notamment, lorsqu'on "perce" un trou cylindrique simple, on perd l'intégrité du cercle et donc son centre) mais également de coter et de mettre en plan beaucoup plus rapidement.
                Si j'ai pu faire avancer modestement le shmilblick....
                • O
                  odd Byberg
                  I have yet to find the way to cut through my outer wall that is made of 3 solids going all around the building.
                  So if I cut through my first wall ( 6 faces), I will also make an opening at the back ( 6 more faces to o through). And I find I can limit it to only the first cut, but then Im only 1/3 through my wall.
                  Is there a way to set max drill depth, so it goes all the way through my wall, but does not reach the back walls.?
                  • B
                    Buckyman
                    I have used Visuhole successfully to stamp a logo into my model
                    I noticed after converting to STEP file with FreeCAD that there are many hidden lines after the stamping, see "after carve.jpg"
                    After the carve operation my model is no longer solid. I used CleanUp3 to clean up the model, after that there were a few lines I deleted manually.
                    SolidInspector2 says it is a solid
                    Solid Solver says it is not
                    I am just wondering if the extra lines are to be expected after a carve operation or is there some setting in Visuhole that would avoid this?
                    thx
                    • fredo6F
                      Because of the two holes, the front face will become quite busy with edges when you carve the logo. If your model is at small scale, this can generate issues with the shape being manifold.
                      Possibly, you may try by putting rectangular edges around the holes over the main face to isolate them.
                      • B
                        Buckyman
                        Or do the carve first, Holes after??
                        • H
                          Hannahdesigns88
                          When I try to download this visuhole plug in, it says its not a sketchup model and wont let me download it...or even begin to download. I have sketch up pro 2022 windows.
                            Extensions cannot be opened by SketchUp. You need to use Extensions > Extension Manager to install the .RBZ file
                            • BoxB
                              To follow on from Rich's comment, it sounds like you have the download dialog set to 'Open with' rather than 'Save File' You need to set it to save file to get the RBZ to your computer to then get the extension manager to use it.
                              • P
                                ploniman
                                it doesnt work as it should. tried several fonts but, always with little errors. see picure
                                what to do?
                                • BoxB
                                  Scale is the first most likely issue, how small is your model.
                                  Scale up by 100 and see if it works.
                                    what to do?
                                    [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
                                    Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
                                    • ezyuzinE
                                      ezyuzin Extension Creator
                                      Hello,
                                      Is it possible to create holes with specific depth in multilayer objects
                                      For sample, I was unable to find correct results
                                      using drill and carve commands
                                        To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
                                        But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
                                        • ezyuzinE
                                          It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
                                          I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
                                            mac13517a
                                            Great Plugin, I love it a LOT!!!
                                            I have a question: How can I remove a stencil???
                                            Sometime I just require upgrade the stencil or simply remove the old stencil.
                                            Kind regards,
                                            • 5 / 6
