    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 246.2k Views 84 Watching
    • ntxdaveN
      ntxdave
      Well, all of a sudden it seems to be gone and I cannot reinstall it for some silly reason.
      Here is what I see when I try to add in using the nomal routine.
      Press F1...thank me later
        What is gone? The Sketchucation toolbar?
        [attachment=1:289s9zdu]<!-- ia1 -->SkecthUpPreferences.jpg<!-- ia1 -->[/attachment:289s9zdu]
        What do you mean by "normal routine"? There's nothing about displaying toolbars in Preferences>Workspace. The normal way to select and show toolbars in SketchUp is to go to View>Toolbars and tick the boxes for the toolbars you want to see.
        [attachment=0:289s9zdu]<!-- ia0 -->Screenshot - 1_9_2022 , 4_41_39 PM.png<!-- ia0 -->[/attachment:289s9zdu]
        • ntxdaveN
          ntxdave
          Sorry for the confusion. I was in a hurry before I left the house. I thought I Had to reinstall the SketUcations Tools because the icons were missing from the toolbar I was trying to reinstall it but as my screenshot shows, there is no Extensions option in the Windows Preferences setting. I did not stop to think about the screen for putting the tool back on my toolbar.
          Too many things (not related to the technology) and I seem to be making one stupid mistake after another lately. I hope you guys will not give up on me.
            @ntxdave said:
            ...but as my screenshot shows, there is no Extensions option in the Windows Preferences setting.
            There's not supposed to be an Extensions "option" in Preferences. Extension Warehouse and Extension Manager have been separate from Preferences for a few versions of Sketchup. You'll find them at the top of the Extensions menu.
            So did you find the toolbar in the Toolbars list?
            • ntxdaveN
              ntxdave
              Got to wait until I get back home to look at the toolbars,
              • ntxdaveN
                ntxdave
                @dave r said:
                No, here is what I did find....
                I am having problems finding the SketchUcation stuff.........I think I clicked something that made it disappear and now I can not find the right way to get it back.
                  Maybe disabled it in the Extension Manager?
                  If the answer is no you're going to have to let me see your computer.
                  • ntxdaveN
                    ntxdave
                    OK - I finally got things back to normal.
                    1. I went to the Extension Manager and uninstalled SketchUcation.
                    2. I shut dow SketchUp and then reloaded it.
                    3. I went back to the Extension Manager and clicked on the Install Extension
                    4. When the extension finished installing, I drug the SketchUcation toolbar back up where it used to be.
                    So, I think I am back up and running the way it should be...........
                    • OxerO
                      Oxer
                      Hi, I installed the last version 4.2.3 in Sketchup 2017 & macOS 10.13.6 and when I select Extensions Menu > SketchUcation > SFCLicence : Global Status, it appears this console message:
                      Error; #<LoadError; dlopen(/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9); no suitable image found.  Did find;
                      	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
                      	/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
                      /Applications/SketchUp 2017/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb;54;in `require'
                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
                      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
                      SketchUp;1;in `call'
                      This is the content of the SketchUcation folder in my computer:
                      With ExtensionStore v4.0.0b works fine, I didn't test with other versions (v4.0.0c to 4.2.2)
                        ramohn
                        Hello All,
                        I need assistance as I can't log into ExtensionStore v4.2.3 (inside Sketchup) to authenticate the FredoScale I recently purchased.
                        I use MacOs 10.14 and Sketchup 2017 Make.
                        Can someone help me ?
                        Thanking you in advance.
                        Ramon Asensi
                          v4.2.4 is now available through the PluginStore / ExtensionStore³
                          https://sketchucation.com/pluginstore?pln=SketchUcationTools
                          It fixes the UNzip error reported when installing RBZ files in v2017/18...
                            ramohn
                            @ramohn said:
                            Hello All,
                            [attachment=1:5h8n8gf6]<!-- ia1 -->Captura de Tela 2022-03-08 às 01.41.54.png<!-- ia1 -->[/attachment:5h8n8gf6]
                            Ramon Asensi
                            Please,
                            I beg anyone could help me with my issue or I'll request refund of plugin purchased recently
                            [attachment=0:5h8n8gf6]<!-- ia0 -->Captura de Tela 2022-03-16 às 09.14.08.png<!-- ia0 -->[/attachment:5h8n8gf6]
                              Have you cleared your browser cache? [Safari for MAC]
                              • OxerO
                                Oxer
                                With the new version 4.2.4 the issue persists when I select Extensions Menu > SketchUcation > SCF License : Global Status...
                                	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
                                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
                                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
                                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
                                macOS 10.13.6 & Sketchup 2017
                                  ramohn
                                  I don't know if you're talking to me... Yes, I have cleared.
                                  • W
                                    wozabee
                                    Hi guys
                                    Have been away for some Sketchup for a few years and went to install SketchUcation Tools into my Sketchup 2016.
                                    It's telling me this latest version of the plugin is incompatible with 2016, and to install v3~
                                    Is there an archive I can download earlier versions from?
                                    Also, I hear there was a possible slow-down problem with 3.0~??
                                    Would v3.1.8 be better?
                                    Cheers,
                                    Woz B.
                                      For v2016 use the newest version 3 of the toolset [v3.1.8]
                                      • Miner_JeffM
                                        Miner_Jeff
                                        Hi @Tig,
                                        I am looking to download version 3.1 that will work with SU 2016. (I know it's well behind the current SU version. It's what I have...)
                                        Do you have a link for V3.1?
                                        Or a trick to download it?
                                        Many thanks,
                                        Miner_jeff
                                          I've sent you a PM...
                                          • V
                                            valerostudio
                                            This plugin is being blocked by our Sonic Wall due to being behind an IP in Russia. I've used this extension for years and never had this issue. Did something change recently?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
