    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
    • OxerO
      Oxer
      Hi, I installed the last version 4.2.3 in Sketchup 2017 & macOS 10.13.6 and when I select Extensions Menu > SketchUcation > SFCLicence : Global Status, it appears this console message:
      Error; #<LoadError; dlopen(/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9); no suitable image found.  Did find;
      	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
      	/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
      /Applications/SketchUp 2017/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb;54;in `require'
      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
      /users/user/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
      SketchUp;1;in `call'
      This is the content of the SketchUcation folder in my computer:
      With ExtensionStore v4.0.0b works fine, I didn't test with other versions (v4.0.0c to 4.2.2)
        ramohn
        Hello All,
        I need assistance as I can't log into ExtensionStore v4.2.3 (inside Sketchup) to authenticate the FredoScale I recently purchased.
        I use MacOs 10.14 and Sketchup 2017 Make.
        Can someone help me ?
        Thanking you in advance.
        Ramon Asensi
          v4.2.4 is now available through the PluginStore / ExtensionStore³
          https://sketchucation.com/pluginstore?pln=SketchUcationTools
          It fixes the UNzip error reported when installing RBZ files in v2017/18...
            ramohn
            @ramohn said:
            Hello All,
            [attachment=1:5h8n8gf6]<!-- ia1 -->Captura de Tela 2022-03-08 às 01.41.54.png<!-- ia1 -->[/attachment:5h8n8gf6]
            Ramon Asensi
            Please,
            I beg anyone could help me with my issue or I'll request refund of plugin purchased recently
            [attachment=0:5h8n8gf6]<!-- ia0 -->Captura de Tela 2022-03-16 às 09.14.08.png<!-- ia0 -->[/attachment:5h8n8gf6]
              Have you cleared your browser cache? [Safari for MAC]
              • OxerO
                Oxer
                With the new version 4.2.4 the issue persists when I select Extensions Menu > SketchUcation > SCF License : Global Status...
                	/Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/User/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;54;in `license_dialog_global'
                /users/User/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;2123;in `block (2 levels) in <module;SCFLicense>'
                macOS 10.13.6 & Sketchup 2017
                  ramohn
                  I don't know if you're talking to me... Yes, I have cleared.
                  • W
                    wozabee
                    Hi guys
                    Have been away for some Sketchup for a few years and went to install SketchUcation Tools into my Sketchup 2016.
                    It's telling me this latest version of the plugin is incompatible with 2016, and to install v3~
                    Is there an archive I can download earlier versions from?
                    Also, I hear there was a possible slow-down problem with 3.0~??
                    Would v3.1.8 be better?
                    Cheers,
                    Woz B.
                      For v2016 use the newest version 3 of the toolset [v3.1.8]
                      • Miner_JeffM
                        Miner_Jeff
                        Hi @Tig,
                        I am looking to download version 3.1 that will work with SU 2016. (I know it's well behind the current SU version. It's what I have...)
                        Do you have a link for V3.1?
                        Or a trick to download it?
                        Many thanks,
                        Miner_jeff
                          I've sent you a PM...
                          • V
                            valerostudio
                            This plugin is being blocked by our Sonic Wall due to being behind an IP in Russia. I've used this extension for years and never had this issue. Did something change recently?
                              [attachment=0:19o3pqh1]<!-- ia0 -->blocked.JPG<!-- ia0 -->[/attachment:19o3pqh1]
                              The IP indicated in the message is shown as being in Germany. I'm not getting the same message when I open it.
                              • G
                                Gábor
                                Nothing has changed on our side. More than likely your Sonic Wall misidentified the location of our server,
                                  Published v4.3.0 with the following changes:
                                  • Protection against decrypting RBE
                                  • Adjustment in the binary to manage seat release
                                  • Refresh of GUI
                                  Other memory handling, error handling and bugfixes under the hood.
                                  Make sure you update and Happy New Year!
                                    rutpin
                                    I downloaded the most updated version ExtensionStore v4.3.0, and it still doesn't allow me to download extensions from there, I get a message like this
                                      You shouldn't be putting extensions into Program Data. The extensions you add should be going into User/App Data/Roaming/SketchUp/.../Plugins. Program Data should have security settings to prevent you from putting files into it.
                                        @rutpin said:
                                        Hello, thanks for the help, I don't understand what I should do - when I ask to download the file I have 2 options where to save it, and in both it doesn't let me, what should I do? Can you tell me more?
                                        Thank you.
                                        First, make sure you've installed SketchUp correctly. That requires right clicking on the downloaded installer and choosing Run as administrator. If you didn't do that, or don't know, do it now and when presented with the options, choose Repair.
                                        When you are installing extensions, choose the User/App Data location. If SketchUp was installed correctly you should have permission to install into that folder.
                                        FWIW, you don't want to add anything to any Program Data folders. There is a huge potential to lose anything you add if you need to reinstall the program because the folders can be overwritten.
                                          @rutpin said:
                                          I did that, and it still doesn't give me the option to install in a folder, is there anything else that can be done?
                                          Go to the User/AppData/.../Plugins folder and delete the Sketchucation plugin file and the associated folder. Download the extension from Resources at the top of this page. Reboot your computer and then open SketchUp and use Extension Manager to install the Sketchucation Tool.
                                          @rutpin said:
                                          Hope I'm not bothering you...
                                          No. You aren't but there's no need to be sending me PMs. That's limiting your options for help.
                                          • I
                                            intara
                                            sorry I will activate license and this pop up is appear."Sorry-An error occured in the communication with Sketchucation " How can i fixed it.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
