    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 643.9k Views 161 Watching
    • 1 Offline
      13thRebel
      @anton_s said:
      When you purchase, PayPal is not required. You can pay with your credit/debit card directly. As far as additional payment alternatives, that is for SketchUcation to decide upon and integrate. What payment option do you have in mind?
      Hi. Yes, I meant a credit / debit card. When I check out, I end up always being redirected to PayPal. How exactly can I pay by card without using PayPal in any form?
        Anton_S
        Have you seen this option? See attached screenshot.
        • 1 Offline
          13thRebel
          Yes. I attached a few screenshots.
          As a result, payment by card, but through the PayPal service =(
          • H Offline
            hydboxhydbox
            Hi Anton,
            It's sorted.
            I updated my system to MacOS 10.13. and tried again. The validating message went through.
            Maybe there should be some reminder on the download page for those who still using the older macOS system.
            Thanks again.[/quote]
            Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience![/quote]
            NO problem. Thanks for the great extension.
            I am now following the menu to give it a try and I got this exposed table edge.
            The parameter setting is exactly the same as the ones on the example in the menu.
              Try the settings shown here.
              Correct the face orientation first, though. Make sure the front faces are up.
              • H Offline
                hydboxhydbox
                Thanks, it fixed it.
                Is that because I use Quadrilateral Grid + adaptive remeshing? But that is what is said in the menu. Or in simpler cases, the Quadrilateral Grid will be enough?
                  I doubt it. At least I don't get the same result you show when I use those settings.
                    s870887s
                    已購買ClothWorks的授權,但始終沒有收到許可信件
                    [mod=:15j0fr8j]Translated by Google:
                    I have purchased a license for ClothWorks, but never received a license letter[/mod:15j0fr8j]
                      s870887s
                      已購買ClothWorks 的授權,但始終沒有收到授權信件,
                      我的收件信箱是hengzuan168@gmail.com,
                      請看到回覆後,寄授權檔給我,謝謝,
                      因為已經超過24小時了 😢
                        gazzato70
                        Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
                          請看到回覆後,寄授權檔給我,謝謝,
                          因為已經超過24小時了 😢
                          Check inbox for email from support@sketchucation.com
                          https://i.imgur.com/IYTDuIm.png
                            The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
                            https://i.imgur.com/QgKtExV.png
                              請看到回覆後,寄授權檔給我,謝謝,
                              因為已經超過24小時了 😢
                              https://i.imgur.com/8JpztAy.png
                                rodman100
                                Email address?
                                  @rodman
                                  Looks like it. The logs show this as what the user requested as address to send license to. Explains why it wasn't received.... 😐
                                  https://i.imgur.com/2hUOT9w.png
                                  • H Offline
                                    hydboxhydbox
                                    Hi there,
                                    I have another technical question.
                                    If I want to draw a model of an inflated object without air ( only small bulbs left inside), like the ones in the picture. It’s much thinner comparing to the pillow example in instruction.
                                    So which ones of the parameters do I have to adjust?
                                    the Thickness of the object (Cloth tab —Thickness)
                                    the bubble inside (?)
                                    the slightly puffy edge (?)
                                    I have only used SketchUp for 3 months. And I was recommended Clothworks for this particular purpose. Or maybe it is not the best solution?
                                    Please help.
                                    Much appreciated.
                                    Yida
                                    • H Offline
                                      hydboxhydbox
                                      @hydboxhydbox said:
                                      Hi there,
                                      Please help.
                                      Much appreciated.
                                      Yida
                                      This is what I get...never be able to get it quite even
                                      Or should I do the other way around, like draw a rectangle with thickness and then make the bubles separately? Use sandbox? But I tried sandbox, it can only create rectangle face not some puffy effect. I still want the most part of the object to look slightly puffy so it can be recognized as a flattened inflated object.
                                        gazzato70
                                        Thanks for the reply, so since I don't have release the licenses before formatting, nothing can be done? Did I get it right ? If this works I will be careful with the latest license actually in use (2021-10-08). However, the license of 2020-02-16 was of the old Laptop that I sold with only Windows 10 and the drivers installed while the license of 2021-05-25 is of the current Laptop that I purchased at the end of May 2021.
                                        One last question, in case of hard disk failure or computer theft (I hope it never happens !!) I would also lose the last available license and I would be forced to buy it again ??? Many thanks for the help even if I think there must be a solution, you should be able to see if the license is actually in use on some pc and not rely on the installation. Only in this way do I consider it right to impose such a strict rule. Thanks
                                        • ArisA Offline
                                          Aris
                                          Hello,
                                          I bought clothworks some time ago but at some point I started having a problem with the license. I cannot find who to contact to solve this problem. Does anybody know?
                                          thanks!
                                          Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                                            Firstly install the latest version of the SketchUcation Toolset from the PluginStore.
                                            Restart SketchUp... any better ? ...
                                            If not, then someone more experienced will post what to try next........
                                            • 34
                                            • 35
                                            • 4 / 35
