    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.3k Views 166 Watching
      @hydboxhydbox said:
      I am now following the menu to give it a try and I got this exposed table edge.
      The parameter setting is exactly the same as the ones on the example in the menu.
      Try the settings shown here.
      Correct the face orientation first, though. Make sure the front faces are up.
      • H
        hydboxhydbox
        Thanks, it fixed it.
        Is that because I use Quadrilateral Grid + adaptive remeshing? But that is what is said in the menu. Or in simpler cases, the Quadrilateral Grid will be enough?
          I doubt it. At least I don't get the same result you show when I use those settings.
            s870887s
            已購買ClothWorks的授權,但始終沒有收到許可信件
            [mod=:15j0fr8j]Translated by Google:
            I have purchased a license for ClothWorks, but never received a license letter[/mod:15j0fr8j]
              s870887s
              已購買ClothWorks 的授權,但始終沒有收到授權信件,
              我的收件信箱是hengzuan168@gmail.com,
              請看到回覆後,寄授權檔給我,謝謝,
              因為已經超過24小時了 😢
              • G
                gazzato70
                Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
                  請看到回覆後,寄授權檔給我,謝謝,
                  因為已經超過24小時了 😢
                  Check inbox for email from support@sketchucation.com
                  https://i.imgur.com/IYTDuIm.png
                    The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
                    https://i.imgur.com/QgKtExV.png
                      請看到回覆後,寄授權檔給我,謝謝,
                      因為已經超過24小時了 😢
                      https://i.imgur.com/8JpztAy.png
                        rodman100
                        Email address?
                          @rodman
                          Looks like it. The logs show this as what the user requested as address to send license to. Explains why it wasn't received.... 😐
                          https://i.imgur.com/2hUOT9w.png
                          • H
                            hydboxhydbox
                            Hi there,
                            I have another technical question.
                            If I want to draw a model of an inflated object without air ( only small bulbs left inside), like the ones in the picture. It’s much thinner comparing to the pillow example in instruction.
                            So which ones of the parameters do I have to adjust?
                            the Thickness of the object (Cloth tab —Thickness)
                            the bubble inside (?)
                            the slightly puffy edge (?)
                            I have only used SketchUp for 3 months. And I was recommended Clothworks for this particular purpose. Or maybe it is not the best solution?
                            Please help.
                            Much appreciated.
                            Yida
                            • H
                              hydboxhydbox
                              @hydboxhydbox said:
                              Hi there,
                              Please help.
                              Much appreciated.
                              Yida
                              This is what I get...never be able to get it quite even
                              Or should I do the other way around, like draw a rectangle with thickness and then make the bubles separately? Use sandbox? But I tried sandbox, it can only create rectangle face not some puffy effect. I still want the most part of the object to look slightly puffy so it can be recognized as a flattened inflated object.
                              • G
                                gazzato70
                                Thanks for the reply, so since I don't have release the licenses before formatting, nothing can be done? Did I get it right ? If this works I will be careful with the latest license actually in use (2021-10-08). However, the license of 2020-02-16 was of the old Laptop that I sold with only Windows 10 and the drivers installed while the license of 2021-05-25 is of the current Laptop that I purchased at the end of May 2021.
                                One last question, in case of hard disk failure or computer theft (I hope it never happens !!) I would also lose the last available license and I would be forced to buy it again ??? Many thanks for the help even if I think there must be a solution, you should be able to see if the license is actually in use on some pc and not rely on the installation. Only in this way do I consider it right to impose such a strict rule. Thanks
                                • ArisA
                                  Aris
                                  Hello,
                                  I bought clothworks some time ago but at some point I started having a problem with the license. I cannot find who to contact to solve this problem. Does anybody know?
                                  thanks!
                                  Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                                    Firstly install the latest version of the SketchUcation Toolset from the PluginStore.
                                    Restart SketchUp... any better ? ...
                                    If not, then someone more experienced will post what to try next........
                                    • ArisA
                                      Aris
                                      Yes, that was the first thing I did.
                                        Did you try the steps in this parallel thread ?
                                        https://sketchucation.com/forums/viewtopic.php?p=675083#p675083
                                          So running the latest SketchUcation Tools and removing the signature from...
                                          C;\Users\[YOURNAME]\AppData\Local\SCF Licenses
                                          ...still results in this error?
                                          What does querying your license allocation return?
                                          https://i.imgur.com/0cNYZwL.png
                                          https://i.imgur.com/aBEgf6O.png
                                          Is it the error message you get when you query?
                                          The A-0C error means your computer name and the computer name in your signature file are not the same. So the license cannot be validated.
                                          • ArisA
                                            Aris
                                            Ok, it is now active.The steps I followed:
                                            1. uninstall clothworks
                                            2. manually removed everything in SCF licenses folder
                                            3. reinstaled clothworks and validated license.
                                            The only problem is that two of the 3 seats are taken when I only have one pc. (It's not actually a problem but I fear I'm going to have issues again and the seats will run out...
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 35
                                            • 36
                                            • 29 / 36
