    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    441 Posts 106 Posters 432.3k Views 106 Watching
    • panixiaP Offline
      panixia
      Hi there, thank you for this wonderful plugins.
      I tryed it a bit and looks pretty robust and useful.
      Do you think could be possible to have a feature to preserve quads in obj and fbx import as per thomthom convention of pseudo-quads in sketchup (mark the diagonal with "soft" "smooth" "don't cast shadows")?
      That would be perfect!
      • samuel_tS Offline
        samuel_t
        I don't think it's possible. πŸ˜•
        • panixiaP Offline
          panixia
          Thomthom has an obj importer in quadface tools which does that in the proper way, but is noway near as fast as your plugin and it also doesn't manage the textures this good.. but it got quads, which makes further poligon editing better and easier.
          Having those two importers merged togheter with the best of each one would be an absolute dream and I would buy that at any price because I could then edit, unwrap and export quad/sub-d models back and forth beetween sketchup and 3dsmax. β˜€
          Thank you anyway.. this is a great tool.
          • samuel_tS Offline
            samuel_t
            There's a plugin named Quadrilateralizer. It converts faces to quad faces. Maybe it could help you.
            • panixiaP Offline
              panixia
              No sir, that's not what I'm talking about.. that plugin just splits existing geometry in quads.
              I rather need the existing non-planar quads in obj coming from 3dsmax, blender, maya etc to be preserved.
              most of those softwares have an option to preserve quads in obj and fbx exporters, here is 3dsmax
              https://help.autodesk.com/cloudhelp/2019/ENU/3DSMax-Data-Exchange/images/GUID-1137FB0B-61E0-443D-8724-01DEDE7E2488.png
              here are some good reasons to care about this in objects and characther modeling workflow
              https://www.turbosquid.com/3d-modeling/training/modeling/quad-based-topology/
              https://topologyguides.com/
              Thomthom wrote an implementation of non-planar quads in sketchup wich is really handy for modeling complex stuff and makes for a better integration of sketchup with most 3d-modeling packages used to produce fbx and obj files
              Home
              Suite of tools for manipulating quad faces in SketchUp. - Home Β· thomthom/quadface-tools Wiki
              GitHub (github.com)
              maybe there is a way to read the "quad property" set from those eporters and translate it to thomthom's diagonals while converting obj and fbx files?
              • E Offline
                Einstein
                I support your request, panixia. I would also buy this plugin with ability to read quad-based topology. Then we wouldn't probably need Transmutr, which is an expensive tool.
                There's a toolbar called AMS Soften Edges. I don't know if you know about it. It has a smart button "Reveal quadrants" that can sometimes be helpful. It finds quads automatically, though often not the way you wish.
                Here you can watch how it works:
                https://www.youtube.com/watch?v=JHc4ySzEhxs
                • panixiaP Offline
                  panixia
                  I don't know how expensive this tool is, but as far as I saw, this doesn't supports quads from other modeling pakages.
                  If it does, I would pay for it no problem at all. Now. The "shut up and take my moneys!" style.
                  If you look at the example of the car, in the video you linked, looks like it has an auto-detect for quads, like other algorithms do. Let'say the "original" quadface tool's "convert triangulated mesh to quads" wich is really similar to 3dsmax quadrify or similar tool i saw in c4d.
                  All of this tools work fine on pretty regular meshes, but when they find lot of poles, as in the car example, they are not able to predict properly where the next quad should be.
                  Moreover, they tend to ruin uv's of meshes.
                  What I'm talking about is to just preserve the quads already present in the obj created in other apps, marking quad diagonals in obj with soft + smooth + don't cast shadows when rebuilding the model in sketchup.
                  Not to create or find new quads, just "preserve".
                  As The importer in quadface tools already does, but with the speed and the textures mangement that this importer has.
                    Khai
                    eh?
                    I'm importing mesh made in trueSpace... in Quads. also OBJs... again in Quads..
                    not sure why your not getting Quads preserved...
                    the only thing I'm losing is Grouping... it all comes in as one mesh... which is a pain but I can work round it... getting the old tS models back is enough..
                      pibuz
                      Hi! First of all thanks for your wonderful plugin and great work!
                      I have issues trying to import objs....
                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                      • samuel_tS Offline
                        samuel_t
                        https://sketchucation.com/forums/download/file.php?id=158592
                        Hi! Try to run SketchUp as Administrator then import a model again. Let me know if problem persists.
                          pibuz
                          πŸ˜’ THAT WORKED..
                          Is there the hell of a way to tell sketchup to ALWAYS run as admin?
                          I thought I already did this but seems like I couldn't do it.....
                          • samuel_tS Offline
                            samuel_t
                            @pibuz said:
                            :roll: THAT WORKED..
                            There is a way... Check this guide.
                            • Z Offline
                              zuzca
                              Helo,
                              unfortunatelly for me does not work, I dont know why, bug screenshot attached..
                              Thank you for any help.
                              Zuzana
                              • samuel_tS Offline
                                samuel_t
                                @zuzca said:
                                Helo,
                                Zuzana
                                Hello,
                                I don't see screenshot.
                                • jujuJ Offline
                                  juju
                                  @zuzca said:
                                  Helo,
                                  Zuzana
                                  Below a certain number of posts you cannot attach anything.
                                  • samuel_tS Offline
                                    samuel_t
                                    @juju Thanks for the info.
                                    @zuzca Could you please upload screenshot to an image hoster or copy (CTRL + C) error msg as text?
                                      pibuz
                                      ...sorry Samuel another question: when I try and import a model, the plugin asks me the "height" of the model, and scales it to that dimension. Problem is that most of the time I don't know the original height of the model and I just want to keep the original size. Is there a way to do this?
                                      Thanks in advance!!!
                                      • samuel_tS Offline
                                        samuel_t
                                        I don't know... Maybe with an external viewer.
                                          To allow the user to NOT scale the imported geometry could there be a possibility to enter 0 when prompted, and if so you skip that step ??
                                            pibuz
                                            i was asking kind of the same thing πŸ˜„
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
