    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 577.2k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      @einstein said:
      I pasted the library as you advised, relaunched SketchUp (maybe I should restart my PC) but still the same error pops up as I press the violet swan ๐Ÿ˜ž
      Do you use SketchUp through a remote desktop? ๐Ÿ˜ฎ
      @einstein said:
      How do you specify textures? If I pick them one by one during import, only one texture is put onto whole chair. Surely, I can manually repaint a part of it but it looks like no UV map is assigned. If I pick the other texture from "In Model" material palette, say leather, and paint the chair top, the texture has wrong scale and orientation.
      I specify textures during import process (dialog box).
      • OxerO Offline
        Oxer
        macos 10.13.6 & SU2017
        The v1.1.5 gives an error when I try to import an obj format model, with previous version v1.1.4 the model was imported right.
        • samuel_tS Offline
          samuel_t
          https://sketchucation.com/forums/download/file.php?id=158504
          ๐Ÿ˜ฎ Could you please upload your model here or to a file hoster?
          • samuel_tS Offline
            samuel_t
            About remesher, you can try to reinstall your graphics card driver. Let me know if problem persists.
            Also, be sure to import FBX version of "Rudolf Chair" model since OBJ version is badly textured. ๐Ÿ˜‰
            • OxerO Offline
              Oxer
              Excuse me, the problem was that the obj.mtl file was missing, I deleted it accidentally, the Plugin works fine. ๐Ÿ˜ณ
              • E Offline
                Einstein
                OK, I managed to import FBX model properly textured ๐Ÿ˜„ Thank you for your help!
                You mean I should totally reinstall NVIDIA drivers? (I'm actually afraid to do it because NVIDIA does problems with driver installation. Plus I'm an amateur and don't want to mess up with my computer.) Or should I just reinstall one of MS Visual C++ Redistributables or some other package?
                • samuel_tS Offline
                  samuel_t
                  ๐Ÿ˜‰ ๐Ÿ‘
                  Yes, you should totally reinstall NVIDIA drivers.
                  • panixiaP Offline
                    panixia
                    Hi there, thank you for this wonderful plugins.
                    I tryed it a bit and looks pretty robust and useful.
                    Do you think could be possible to have a feature to preserve quads in obj and fbx import as per thomthom convention of pseudo-quads in sketchup (mark the diagonal with "soft" "smooth" "don't cast shadows")?
                    That would be perfect!
                    • samuel_tS Offline
                      samuel_t
                      I don't think it's possible. ๐Ÿ˜•
                      • panixiaP Offline
                        panixia
                        Thomthom has an obj importer in quadface tools which does that in the proper way, but is noway near as fast as your plugin and it also doesn't manage the textures this good.. but it got quads, which makes further poligon editing better and easier.
                        Having those two importers merged togheter with the best of each one would be an absolute dream and I would buy that at any price because I could then edit, unwrap and export quad/sub-d models back and forth beetween sketchup and 3dsmax. โ˜€
                        Thank you anyway.. this is a great tool.
                        • samuel_tS Offline
                          samuel_t
                          There's a plugin named Quadrilateralizer. It converts faces to quad faces. Maybe it could help you.
                          • panixiaP Offline
                            panixia
                            No sir, that's not what I'm talking about.. that plugin just splits existing geometry in quads.
                            I rather need the existing non-planar quads in obj coming from 3dsmax, blender, maya etc to be preserved.
                            most of those softwares have an option to preserve quads in obj and fbx exporters, here is 3dsmax
                            https://help.autodesk.com/cloudhelp/2019/ENU/3DSMax-Data-Exchange/images/GUID-1137FB0B-61E0-443D-8724-01DEDE7E2488.png
                            here are some good reasons to care about this in objects and characther modeling workflow
                            https://www.turbosquid.com/3d-modeling/training/modeling/quad-based-topology/
                            https://topologyguides.com/
                            Thomthom wrote an implementation of non-planar quads in sketchup wich is really handy for modeling complex stuff and makes for a better integration of sketchup with most 3d-modeling packages used to produce fbx and obj files
                            https://github.com/thomthom/quadface-tools/wiki
                            maybe there is a way to read the "quad property" set from those eporters and translate it to thomthom's diagonals while converting obj and fbx files?
                            • E Offline
                              Einstein
                              I support your request, panixia. I would also buy this plugin with ability to read quad-based topology. Then we wouldn't probably need Transmutr, which is an expensive tool.
                              There's a toolbar called AMS Soften Edges. I don't know if you know about it. It has a smart button "Reveal quadrants" that can sometimes be helpful. It finds quads automatically, though often not the way you wish.
                              Here you can watch how it works:
                              https://www.youtube.com/watch?v=JHc4ySzEhxs
                              • panixiaP Offline
                                panixia
                                I don't know how expensive this tool is, but as far as I saw, this doesn't supports quads from other modeling pakages.
                                If it does, I would pay for it no problem at all. Now. The "shut up and take my moneys!" style.
                                If you look at the example of the car, in the video you linked, looks like it has an auto-detect for quads, like other algorithms do. Let'say the "original" quadface tool's "convert triangulated mesh to quads" wich is really similar to 3dsmax quadrify or similar tool i saw in c4d.
                                All of this tools work fine on pretty regular meshes, but when they find lot of poles, as in the car example, they are not able to predict properly where the next quad should be.
                                Moreover, they tend to ruin uv's of meshes.
                                What I'm talking about is to just preserve the quads already present in the obj created in other apps, marking quad diagonals in obj with soft + smooth + don't cast shadows when rebuilding the model in sketchup.
                                Not to create or find new quads, just "preserve".
                                As The importer in quadface tools already does, but with the speed and the textures mangement that this importer has.
                                  Khai
                                  eh?
                                  I'm importing mesh made in trueSpace... in Quads. also OBJs... again in Quads..
                                  not sure why your not getting Quads preserved...
                                  the only thing I'm losing is Grouping... it all comes in as one mesh... which is a pain but I can work round it... getting the old tS models back is enough..
                                    pibuz
                                    Hi! First of all thanks for your wonderful plugin and great work!
                                    I have issues trying to import objs....
                                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    • samuel_tS Offline
                                      samuel_t
                                      https://sketchucation.com/forums/download/file.php?id=158592
                                      Hi! Try to run SketchUp as Administrator then import a model again. Let me know if problem persists.
                                        pibuz
                                        ๐Ÿ˜’ THAT WORKED..
                                        Is there the hell of a way to tell sketchup to ALWAYS run as admin?
                                        I thought I already did this but seems like I couldn't do it.....
                                        • samuel_tS Offline
                                          samuel_t
                                          @pibuz said:
                                          :roll: THAT WORKED..
                                          There is a way... Check this guide.
                                          • Z Offline
                                            zuzca
                                            Helo,
                                            unfortunatelly for me does not work, I dont know why, bug screenshot attached..
                                            Thank you for any help.
                                            Zuzana
                                            • 11
                                            • 22
                                            • 23
                                            • 9 / 23
