    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      @einstein said:
      Is there any way/shortcut to force scaling box align to group's/ world axes?
      Normally, typing an arrow should force axis alignment
      @einstein said:
      Second one is a request:
      When we use shear tool for specific edges/faces, not for entire groups, it kind of "pulls" any edges/faces attached to transformed part of mesh. This is very nice behaviour because we can not only shear groups/ components but also fragments of meshes and they will keep continuity - they will stay "glued together" as they were originally. On the other hand, taper tool doesn't behave that nicely. Do you think you could change the plugin a little (if you have time) so that taper behaviour would be similar to shear tool?
      Here's a screenshot:
      That would be something more complex. Shear is a conform transformation (like Scale or Move). So I let Sketchup manage the deformation and folding of adjacent faces and edges.
      For Taper, I have to recompute the geometry and does not do this, because this is not trivial and not always wanted. It's possible however.
      • E Offline
        Einstein
        If this could be done in the future as an option/ toggle/ alternative, cuz really not everybody may want this, it would be super, super cool!
        • O Offline
          odd Byberg
          Thank you for a lovely plugin. In the box stretching tool I can set a plane that defines what geometry that is to be moved.
          What if this plane could be a box? So I could stretch everything inside that selection box?
          enormous use case for this I think. say you have 2 groups beside each other. All that is inside the stretch box would move in both groups.
          Say you have a wooden wall group that ends, and the rest of the wall is inside another group, because its different (brick)
          A stretch "selection box" could move all of those end faces from multiple groups all at the same time, effectively change where one wall ends and another begins, all in one stretch operation.
          This could be a tool I used all the time, more than the basic move tool in skechup. (Because so much geometry is grouped, and a wall is maybe three groups thick)
          Then its a lot of work to go into every group to lengthen all parts of one wall, and then shorten all parts of the other wall
          I know I can do this with your tool now, in two operations, stretching one wall at the time. πŸ˜„
          • pbacotP Offline
            Another question. Isn't possible to adjust the number of segments in a radial bend? I thought there was, but I'd like to get more segments in the bend, for a smoother curve.
              Select Radial Bend and hit Tab.
              • pbacotP Offline
                Thanks Dave! Yes, these plugins have all the bells and whistles if you know where to look.
                • pbacotP Offline
                  I'm trying to twist a plane with box twisting. All I've got so far is this (image). From the videos, I can't really figure out how to twist one end down and have an even twist along the length of the plane. This is a simple rectangular shape drawn on the incline.
                  Edit-- actually what I wanted to do is twist a rectangle with the axis along one side. I wondered if this could be done with the Fredoscale Twist tool. At least the first edge which is the center of rotation needs to stay straight. The face needs to be warped. The other edges could warp or not.
                  Edit 2-- I found one way to do it with the Twist tool. in the second picture: the group must be 3d so I added a rectangle centered on the side for the rotation axis. I added a copy of the long rectangle so the axis is the center of the group. In the image I want the red surface only. Blue lines added to show the axis (which remains straight and unmoved).
                    resetarionut
                    Hi, I have a question regarding the plugin, I can't find an answer anywhere.
                    I use the FredoScale plugin a lot for woodworking, and there is a feature that is bugging me. Every time the tool is used on a cabinet it automatically makes all components unique. This is good for most part but I would love to be able to toggle this on and off. What I am looking for is for the plugin to not make my cabinet sides components unique if I am only making a cabinet from 600 mm to 900mm in length, only to make them unique if I modify the depth or height but also recognize that is the same component and keep them linked together, creating only a new component definition for both sides.
                    If this is already possible pls help me understand how to do that and if not could it be done ?
                      GraemeGill
                      FredoScale says it will run on Sketchup 6 or latter, but the current LibFredo6 only runs on SU2017 😞
                      Is there a link to a version of LibFredo6 < 10 that I can use with FredoScale to be able to run on Sketchup 7 ?
                      (No, I'm unable to update to a later version of Sketchup.)
                      Thanks.
                        There are legacy versions of Fredo's Lib and several of his extensions still available in the PluginStore.
                        Labelled 'Prior'.
                        https://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=prior&submit=%3F
                        Not sure about FredoScale ?
                        But the legacy Lib on it's own with an older FS might work...
                          michael_kelso
                          No toolbar after install.
                            Did you install the required LibFredo6 as well? Did you quit and restart SketchUp? Did you look in the Tool Palettes for it?
                            • fredo6F Offline
                              NEW RELEASE: FredoScale v3.2a - 30 Jan 22
                              Requirement: LibFredo6 12.4a.
                              IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
                              FredoScale 3.2a provides a workaround to an annoying bug introduced by SU2022 which affects the dimension dialog box (called by TAB). Used this version, pending a fix by Sketchup.
                              Home Page of FredoScale for information and Download.
                              Main post of this FredoScale thread.
                              • fredo6F Offline
                                NEW RELEASE: FredoScale v3.3a - 13 Feb 22
                                FredoScale 3.3a provides compatibility with 3D mouse devices; in some cases, the visual display could be desynchronized from the view when set by the 3D mouse.
                                  jonorman
                                  When using the "Stretch to target tool" I get "invalid origin" no matter where i try to start from.. Is this a bug in the software or in the user ?? (read: Me)
                                  • fredo6F Offline
                                    Obviously, there is a big bug here.
                                    I will have a closer look and try to fix.
                                    • fredo6F Offline
                                      NEW RELEASE: FredoScale v3.4a - 15 Feb 22
                                      FredoScale 3.4a fixes a major bug whereby all tools 'To Target' were not usable and showed a message 'Invalid Origin'.
                                      • fredo6F Offline
                                        @jonorman
                                        I normally fixed the bug in FredoScale v3.4a.
                                        Could you confirm this is OK with you.
                                        Many thanks
                                          jonorman
                                          Uppdated, and all is back to normal... Phew.. Thank you for this quick fix πŸ‘
                                          • W Offline
                                            Wantao
                                            Windows 11
                                            Stretch can't snap object outside group.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 56
                                            • 57
                                            • 15 / 57
