    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
      resetarionut
      Hi, I have a question regarding the plugin, I can't find an answer anywhere.
      I use the FredoScale plugin a lot for woodworking, and there is a feature that is bugging me. Every time the tool is used on a cabinet it automatically makes all components unique. This is good for most part but I would love to be able to toggle this on and off. What I am looking for is for the plugin to not make my cabinet sides components unique if I am only making a cabinet from 600 mm to 900mm in length, only to make them unique if I modify the depth or height but also recognize that is the same component and keep them linked together, creating only a new component definition for both sides.
      If this is already possible pls help me understand how to do that and if not could it be done ?
      • G
        GraemeGill
        FredoScale says it will run on Sketchup 6 or latter, but the current LibFredo6 only runs on SU2017 😞
        Is there a link to a version of LibFredo6 < 10 that I can use with FredoScale to be able to run on Sketchup 7 ?
        (No, I'm unable to update to a later version of Sketchup.)
        Thanks.
          There are legacy versions of Fredo's Lib and several of his extensions still available in the PluginStore.
          Labelled 'Prior'.
          https://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=prior&submit=%3F
          Not sure about FredoScale ?
          But the legacy Lib on it's own with an older FS might work...
            michael_kelso
            No toolbar after install.
              Did you install the required LibFredo6 as well? Did you quit and restart SketchUp? Did you look in the Tool Palettes for it?
              • fredo6F
                NEW RELEASE: FredoScale v3.2a - 30 Jan 22
                Requirement: LibFredo6 12.4a.
                IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
                FredoScale 3.2a provides a workaround to an annoying bug introduced by SU2022 which affects the dimension dialog box (called by TAB). Used this version, pending a fix by Sketchup.
                Home Page of FredoScale for information and Download.
                Main post of this FredoScale thread.
                • fredo6F
                  NEW RELEASE: FredoScale v3.3a - 13 Feb 22
                  FredoScale 3.3a provides compatibility with 3D mouse devices; in some cases, the visual display could be desynchronized from the view when set by the 3D mouse.
                    jonorman
                    When using the "Stretch to target tool" I get "invalid origin" no matter where i try to start from.. Is this a bug in the software or in the user ?? (read: Me)
                    • fredo6F
                      Obviously, there is a big bug here.
                      I will have a closer look and try to fix.
                      • fredo6F
                        NEW RELEASE: FredoScale v3.4a - 15 Feb 22
                        FredoScale 3.4a fixes a major bug whereby all tools 'To Target' were not usable and showed a message 'Invalid Origin'.
                        • fredo6F
                          @jonorman
                          I normally fixed the bug in FredoScale v3.4a.
                          Could you confirm this is OK with you.
                          Many thanks
                            jonorman
                            Uppdated, and all is back to normal... Phew.. Thank you for this quick fix 👍
                            • W
                              Wantao
                              Windows 11
                              Stretch can't snap object outside group.
                              • fredo6F
                                @wantao said:
                                Windows 11
                                [attachment=0:2wnbpg4f]<!-- ia0 -->20220311215448.jpg<!-- ia0 -->[/attachment:2wnbpg4f]
                                Not related to Windows 11, but more to a limitation of the Ruby API unfortunately.
                                  It does work for me.
                                  Click on the picture
                                  • fredo6F
                                    I think the problem is when you are within the group.
                                      Sorry. I forgot to open it. How about this?
                                      click on the picture
                                      • fredo6F
                                        The inference with the small orange point does not force alignment.
                                        I think that I did that to avoid that there are too many inferences when you work inside a container context.
                                        I think I can enable it.
                                        • fredo6F
                                          NEW RELEASE: FredoScale v3.4b - 11 Mar 22
                                          FredoScale 3.4b includes:
                                          • Inferences outside current context (see video below)
                                          • Updated Chinese translation by Arc
                                          • pascal1964P
                                            pascal1964
                                            Bonjour J'ai acheté hier matin le plugin fredoscale et je n'ai toujours pas l'accès est-ce normal?
                                            Merci de me donner la marche à suivre. Bonne journée, Pascal (skp 21 pro)
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 58
                                            • 59
                                            • 52 / 59
