    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.2k Posts 346 Posters 2.9m Views 344 Watching
      michael_kelso
      No toolbar after install.
        Did you install the required LibFredo6 as well? Did you quit and restart SketchUp? Did you look in the Tool Palettes for it?
        • fredo6F Offline
          NEW RELEASE: FredoScale v3.2a - 30 Jan 22
          Requirement: LibFredo6 12.4a.
          IMPORTANT: FredoScale is no longer supported for Sketchup versions lower than SU2017.
          FredoScale 3.2a provides a workaround to an annoying bug introduced by SU2022 which affects the dimension dialog box (called by TAB). Used this version, pending a fix by Sketchup.
          Home Page of FredoScale for information and Download.
          Main post of this FredoScale thread.
          • fredo6F Offline
            NEW RELEASE: FredoScale v3.3a - 13 Feb 22
            FredoScale 3.3a provides compatibility with 3D mouse devices; in some cases, the visual display could be desynchronized from the view when set by the 3D mouse.
              jonorman
              When using the "Stretch to target tool" I get "invalid origin" no matter where i try to start from.. Is this a bug in the software or in the user ?? (read: Me)
              • fredo6F Offline
                Obviously, there is a big bug here.
                I will have a closer look and try to fix.
                • fredo6F Offline
                  NEW RELEASE: FredoScale v3.4a - 15 Feb 22
                  FredoScale 3.4a fixes a major bug whereby all tools 'To Target' were not usable and showed a message 'Invalid Origin'.
                  • fredo6F Offline
                    @jonorman
                    I normally fixed the bug in FredoScale v3.4a.
                    Could you confirm this is OK with you.
                    Many thanks
                      jonorman
                      Uppdated, and all is back to normal... Phew.. Thank you for this quick fix 👍
                      • W Offline
                        Wantao
                        Windows 11
                        Stretch can't snap object outside group.
                        • fredo6F Offline
                          @wantao said:
                          Windows 11
                          [attachment=0:2wnbpg4f]<!-- ia0 -->20220311215448.jpg<!-- ia0 -->[/attachment:2wnbpg4f]
                          Not related to Windows 11, but more to a limitation of the Ruby API unfortunately.
                            It does work for me.
                            Click on the picture
                            • fredo6F Offline
                              I think the problem is when you are within the group.
                                Sorry. I forgot to open it. How about this?
                                click on the picture
                                • fredo6F Offline
                                  The inference with the small orange point does not force alignment.
                                  I think that I did that to avoid that there are too many inferences when you work inside a container context.
                                  I think I can enable it.
                                  • fredo6F Offline
                                    NEW RELEASE: FredoScale v3.4b - 11 Mar 22
                                    FredoScale 3.4b includes:
                                    • Inferences outside current context (see video below)
                                    • Updated Chinese translation by Arc
                                    • pascal1964P Offline
                                      pascal1964
                                      Bonjour J'ai acheté hier matin le plugin fredoscale et je n'ai toujours pas l'accès est-ce normal?
                                      Merci de me donner la marche à suivre. Bonne journée, Pascal (skp 21 pro)
                                        Go to https://sketchucation.com/webshop/my-licences.php to retrieve your license files if the email has not arrived or is sitting in Spam
                                          pascal1964
                                          J'ai déjà vérifier il est nul part 😒
                                            There is no purchase history for your account. Can you send us info to support[at]sketchucation.com with Transaction ID, Username and Email associated to payment?
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 57
                                            • 58
                                            • 52 / 58
