    Ferrari F2004
    50 Posts 21 Posters 22.9k Views 21 Watching
    • panixiaP
      panixia
      More stuff πŸ˜„
      • panixiaP
        panixia
        And more β˜€
        • panixiaP
          panixia
          • panixiaP
            panixia
            Some view from the low poly unsubdivided stage 😎
            • panixiaP
              panixia
              More detailed views from low poly stage.
              • ntxdaveN
                ntxdave
                Wow! Such detail. Great job! πŸ‘ πŸ‘ πŸ‘
                Press F1...thank me later
                • panixiaP
                  panixia
                  Some view from Substance Painter including the full car and a little texture-set breakdown.
                  Notice the double UDIM tile on the body, rejoined with the aero props and brake calipers with no wasted space.
                  • panixiaP
                    panixia
                    Each texture set have different resolution and optional channels (like opacity, emissive, AO) depending on what is needed.
                    • panixiaP
                      panixia
                      Finally I exported the model to 3dsMax using QFT obj exporter to render it in Vray, and imported as straight .skp into Unity3d where I plan to do animations and interactive stuff.
                      I then exported a GLTF from Unity and imported in Blender just to convert it in binary GLB which is more compact and convenient.
                      Below is a screnshot from Unity inspector:
                      Here's a short video of the first export/rendering test with Substance PBR textures reloaded (order of appearence in the YouTube description).
                      • Gus RG
                        Gus R
                        Excellent work.
                        www.instagram.com/gusrobatto/
                        www.facebook.com/gusrobatto
                        • panixiaP
                          panixia
                          Here in this video is a first mockup/proof-of-concept for some animation I started to put toghther during lockdown. 🀒
                          Now that I'm done with the car I will reload it and continue to work on the scenes..
                          Stay tuned for more updates in the summer. β˜€
                          • boofredlayB
                            boofredlay
                            https://i.pinimg.com/564x/b1/13/6c/b1136c912e6cfa93b3e1463db47bb508.jpg
                            • Bryan KB
                              One of the greatest cars in history.
                              And this has to be one of the finest 3D models I've ever seen and a fitting tribute. Wow! πŸ‘
                              • ntxdaveN
                                ntxdave
                                DITTO!
                                  @panixia said:
                                  For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
                                  Can you expand on this?
                                  • O
                                    optimaforever
                                    Amazing work ! I admit that the quadface tools+vertextools+subD workflow
                                    is something that I sometimes miss in Fusion360, as it allows some complex
                                    sculpting with ease, and this f2004 is a wonderful demonstration !!!
                                    How can you retrieve the second tile you made in wrapR?
                                    can it save several tiles for one mesh? or you need an workaround?
                                    UDIM workflow is possible in substance painter but I never thought of
                                    doing that with a sketchup-generated mesh.
                                    This is new for me, you’re a genius !
                                    • panixiaP
                                      panixia
                                      Adesso arriva. πŸ˜‰
                                      • panixiaP
                                        panixia
                                        Here we go.. My best attempt to explain it.
                                        The basic concept is that you export from a single-material model and then reload in another model with two separate materials. πŸ‘
                                        • panixiaP
                                          panixia
                                          No, it's not, but you select the faces for the second tile, create a new unique material for them and assign to it the textures from uv tile 2.
                                          That simply works because sketchup teoretically has actually both uv sets repeating overlapped (exactly like the psycoTemplate texture in the vid), but because you assigned each texture to the proper material/faces, you are sort of trolling the system, so it works.
                                          The difference with "official" UDIM workflow is that you are not able to manage this with a single material based on the texture set's naming convention only, but you have instead to manualy re-create (and reassign on the mesh) individual materials for each texture set.
                                          • panixiaP
                                            panixia
                                            Some Wrap-R views. For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
                                            I also added some minor props in the empty spaces left in the body double-unwrap
                                            (used the same trick to add minor props to other single-tile texture sets).
                                            I've also found a neat trick to unwrap flat strips of poligons in Wrap-r with a little aid of Thrupaint.
                                            Look at the tire tread and rim 😎
                                            • 1 / 3
