    Ferrari F2004
    50 Posts 21 Posters 18.1k Views 21 Watching
    • panixiaP Online
      panixia
      During pandemic I choose to put togheter this humble tribute to one of the best racing car ever, as a pastime while I were forced to stay at home even in my spare time and weekends.
      Here's my entry for the infamous Ferrari F-2004 one of the most dominant and best looking formula one car which ever hit the tracks.
      100% of the modeling and UV's are done in Sketchup Pro 2020 + Quadface Tools + VertexTools2 + Sub-D + SplitTools + JointPushPull alongside other plugins.
      I did the UV unwrapping using the Wrap-r plugin.
      I only did the texturing outside of sketchup using Substance for direct texture painting and Photoshop to create all the decals/logo stuff.
      I hope you enjoy it.
      • panixiaP Online
        panixia
        More stuff πŸ˜„
        • panixiaP Online
          panixia
          And more β˜€
          • panixiaP Online
            panixia
            • panixiaP Online
              panixia
              Some view from the low poly unsubdivided stage 😎
              • panixiaP Online
                panixia
                More detailed views from low poly stage.
                • ntxdaveN Offline
                  ntxdave
                  Wow! Such detail. Great job! πŸ‘ πŸ‘ πŸ‘
                  Press F1...thank me later
                  • panixiaP Online
                    panixia
                    Some view from Substance Painter including the full car and a little texture-set breakdown.
                    Notice the double UDIM tile on the body, rejoined with the aero props and brake calipers with no wasted space.
                    • panixiaP Online
                      panixia
                      Each texture set have different resolution and optional channels (like opacity, emissive, AO) depending on what is needed.
                      • panixiaP Online
                        panixia
                        Finally I exported the model to 3dsMax using QFT obj exporter to render it in Vray, and imported as straight .skp into Unity3d where I plan to do animations and interactive stuff.
                        I then exported a GLTF from Unity and imported in Blender just to convert it in binary GLB which is more compact and convenient.
                        Below is a screnshot from Unity inspector:
                        Here's a short video of the first export/rendering test with Substance PBR textures reloaded (order of appearence in the YouTube description).
                        • Gus RG Offline
                          Gus R
                          Excellent work.
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                          • panixiaP Online
                            panixia
                            Here in this video is a first mockup/proof-of-concept for some animation I started to put toghther during lockdown. 🀒
                            Now that I'm done with the car I will reload it and continue to work on the scenes..
                            Stay tuned for more updates in the summer. β˜€
                            • boofredlayB Offline
                              boofredlay
                              https://i.pinimg.com/564x/b1/13/6c/b1136c912e6cfa93b3e1463db47bb508.jpg
                              • Bryan KB Offline
                                One of the greatest cars in history.
                                And this has to be one of the finest 3D models I've ever seen and a fitting tribute. Wow! πŸ‘
                                • ntxdaveN Offline
                                  ntxdave
                                  DITTO!
                                    @panixia said:
                                    For the main body I did some workaround to take advantage from Substance UDIM tile workflow.
                                    Can you expand on this?
                                    • O Offline
                                      optimaforever
                                      Amazing work ! I admit that the quadface tools+vertextools+subD workflow
                                      is something that I sometimes miss in Fusion360, as it allows some complex
                                      sculpting with ease, and this f2004 is a wonderful demonstration !!!
                                      How can you retrieve the second tile you made in wrapR?
                                      can it save several tiles for one mesh? or you need an workaround?
                                      UDIM workflow is possible in substance painter but I never thought of
                                      doing that with a sketchup-generated mesh.
                                      This is new for me, you’re a genius !
                                      • panixiaP Online
                                        panixia
                                        Adesso arriva. πŸ˜‰
                                        • panixiaP Online
                                          panixia
                                          Here we go.. My best attempt to explain it.
                                          The basic concept is that you export from a single-material model and then reload in another model with two separate materials. πŸ‘
                                          • panixiaP Online
                                            panixia
                                            No, it's not, but you select the faces for the second tile, create a new unique material for them and assign to it the textures from uv tile 2.
                                            That simply works because sketchup teoretically has actually both uv sets repeating overlapped (exactly like the psycoTemplate texture in the vid), but because you assigned each texture to the proper material/faces, you are sort of trolling the system, so it works.
                                            The difference with "official" UDIM workflow is that you are not able to manage this with a single material based on the texture set's naming convention only, but you have instead to manualy re-create (and reassign on the mesh) individual materials for each texture set.
                                            • 1 / 3
