    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.3m Views 585 Watching
      If you type 6'.8 and hit Enter or type 6'.8" and hit Enter you'll get a line that is 72.8 inches long. It's correct and expected behavior as far as I am seeing here. Fredo, I don't see that any change is needed.
      Units set to decimal inches to show the .8.
      Click on the picture
      • tlehman914T
        tlehman914
        @fredo6 said:
        @tlehman914 said:
        Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
        Could you check the version of LibFredo6 you have installed.
        Did you play with FredoTools ColorPaint?
        Screen Shot 2021-03-23 at 2.36.33 PM.jpgLibFredo6
        11.6a
        23 Jan 21
        ColorPaint will not open.
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in color_palette_init' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in prepare_html'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in reload_html' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in dialog_create'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in dialog_invoke' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in dialog_launch'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in new'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in new'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in _execution' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in execute_command'
          Robotopera
          Getting this error when installing on 2021.
          Error Loading File Fredo6_!LibFredo6.rb
          c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in match' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block (2 levels) in load_from_config'
          c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in each' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in block in load_from_config'
          c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in foreach' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in load_from_config'
          c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in block in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in each'
          c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:302:in startup'
          C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in process' C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in module:LibFredo6_Loader'
          C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
          • fredo6F
            How did you install LibFredo6?
            • Copying files?
            • Sketchup Extension manager from a rbz
            • Sketchucation ExtensionStore?
            It seems one file is altered.
            • tlehman914T
              tlehman914
              I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
              • fredo6F
                I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
                Could you try the following
                • Open the Ruby Console
                • copy the following command in red and type Enter:
                  UI.openURL LibFredo6.path + '/Ancillary'
                • This will open a subfolder of LibFredo6
                • Delete the file Colors_RAL_classic.txt
                • restart Sketchup to see if this improves the situation
                • Otherwise, delete all files with names beginning with Colors_ and extension txt.
                Then restart Sketchup to see if this improves the situation.
                • tlehman914T
                  tlehman914
                  I did try to copy the following command in red and type Enter:
                  Result:
                  false
                  I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
                  I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
                  • fredo6F
                    What is left in the directory?
                    Just type in the Ruby console:
                    Dir[LibFredo6.path + '/Ancillary/*.*']
                    • tlehman914T
                      tlehman914
                      Nothing is left in the directory...?
                      No change after typing the above.
                      • fredo6F
                        Did you define a custom color file?
                        If so, do you remember where you save it?
                        In the Ruby Console, could you type
                        Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
                        This should be the list of custom color files.
                        • tlehman914T
                          tlehman914
                          {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
                          • tlehman914T
                            tlehman914
                            I deleted the material 'Tree Tex8.jpg', and all is working!!!! 👍 😎 🎉
                            THANK YOU!!!!
                            • fredo6F
                              In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                              • tlehman914T
                                tlehman914
                                Understood. I didn't even know that I had done that...!? Thanks again!
                                  Robotopera
                                  • Copying files?
                                  Tried all 3 with full uninstalls in between each. Sadly no luck.
                                  Success! Running a repair on the sketchup installation seemed to fix it!
                                    atrasnap
                                    Bonjour à tous,
                                    Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
                                    Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
                                    Je ne peut donc pas l'utiliser.
                                    Il ya t-il une raison ou une manip particulière à effectuer ?
                                    Je suis sur SketchUp 21pro
                                    Merci d'avance
                                      Have you also installed LibFredo ?
                                      Have you restarted SketchUp ?
                                      Have you looked in the Tools menu's submenus ?
                                      Avez-vous également installé LibFredo?
                                      Avez-vous redémarré SketchUp?
                                      Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
                                        martychristoffel
                                        I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
                                        I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
                                        Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
                                        Please see image examples.
                                        Thanks.
                                        • fredo6F
                                          @martychristoffel
                                          Thanks for signaling this problem. You are the first one.
                                          Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
                                          I will see if I can find a workaround in a next version of LibFredo6.
                                            Dekorte
                                            Hello LibFredo6,
                                            I recieved your message showing me your Pic2Shape plugin.
                                            I tried it with a couple of images and it works great.
                                            However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
                                            And here I ran into some troubles.
                                            For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
                                            I wonder if you could help me with the right filter settings so that the plugin can still work ?
                                            I attached a tree (png) that doesn't generate a boundary when using the plugin.
                                            All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
                                            Many thanks in advance !
                                            Boris
                                            example tree png
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 112
                                            • 113
                                            • 88 / 113
