    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • tlehman914T
      tlehman914
      @fredo6 said:
      @tlehman914 said:
      Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
      Could you check the version of LibFredo6 you have installed.
      Did you play with FredoTools ColorPaint?
      Screen Shot 2021-03-23 at 2.36.33 PM.jpgLibFredo6
      11.6a
      23 Jan 21
      ColorPaint will not open.
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in color_palette_init' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in prepare_html'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in reload_html' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in dialog_create'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in dialog_invoke' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in dialog_launch'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in new'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in new'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in _execution' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in execute_command'
        Robotopera
        Getting this error when installing on 2021.
        Error Loading File Fredo6_!LibFredo6.rb
        c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in match' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block (2 levels) in load_from_config'
        c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in each' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in block in load_from_config'
        c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in foreach' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in load_from_config'
        c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in block in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in each'
        c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:302:in startup'
        C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in process' C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in module:LibFredo6_Loader'
        C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
        • fredo6F
          How did you install LibFredo6?
          • Copying files?
          • Sketchup Extension manager from a rbz
          • Sketchucation ExtensionStore?
          It seems one file is altered.
          • tlehman914T
            tlehman914
            I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
            /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
            • fredo6F
              I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
              Could you try the following
              • Open the Ruby Console
              • copy the following command in red and type Enter:
                UI.openURL LibFredo6.path + '/Ancillary'
              • This will open a subfolder of LibFredo6
              • Delete the file Colors_RAL_classic.txt
              • restart Sketchup to see if this improves the situation
              • Otherwise, delete all files with names beginning with Colors_ and extension txt.
              Then restart Sketchup to see if this improves the situation.
              • tlehman914T
                tlehman914
                I did try to copy the following command in red and type Enter:
                Result:
                false
                I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
                I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
                • fredo6F
                  What is left in the directory?
                  Just type in the Ruby console:
                  Dir[LibFredo6.path + '/Ancillary/*.*']
                  • tlehman914T
                    tlehman914
                    Nothing is left in the directory...?
                    No change after typing the above.
                    • fredo6F
                      Did you define a custom color file?
                      If so, do you remember where you save it?
                      In the Ruby Console, could you type
                      Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
                      This should be the list of custom color files.
                      • tlehman914T
                        tlehman914
                        {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
                        • tlehman914T
                          tlehman914
                          I deleted the material 'Tree Tex8.jpg', and all is working!!!! 👍 😎 🎉
                          THANK YOU!!!!
                          • fredo6F
                            In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                            • tlehman914T
                              tlehman914
                              Understood. I didn't even know that I had done that...!? Thanks again!
                                Robotopera
                                • Copying files?
                                Tried all 3 with full uninstalls in between each. Sadly no luck.
                                Success! Running a repair on the sketchup installation seemed to fix it!
                                  atrasnap
                                  Bonjour à tous,
                                  Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
                                  Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
                                  Je ne peut donc pas l'utiliser.
                                  Il ya t-il une raison ou une manip particulière à effectuer ?
                                  Je suis sur SketchUp 21pro
                                  Merci d'avance
                                    Have you also installed LibFredo ?
                                    Have you restarted SketchUp ?
                                    Have you looked in the Tools menu's submenus ?
                                    Avez-vous également installé LibFredo?
                                    Avez-vous redémarré SketchUp?
                                    Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
                                      martychristoffel
                                      I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
                                      I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
                                      Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
                                      Please see image examples.
                                      Thanks.
                                      • fredo6F
                                        @martychristoffel
                                        Thanks for signaling this problem. You are the first one.
                                        Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
                                        I will see if I can find a workaround in a next version of LibFredo6.
                                          Dekorte
                                          Hello LibFredo6,
                                          I recieved your message showing me your Pic2Shape plugin.
                                          I tried it with a couple of images and it works great.
                                          However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
                                          And here I ran into some troubles.
                                          For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
                                          I wonder if you could help me with the right filter settings so that the plugin can still work ?
                                          I attached a tree (png) that doesn't generate a boundary when using the plugin.
                                          All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
                                          Many thanks in advance !
                                          Boris
                                          example tree png
                                          • fredo6F
                                            Since this thread is about LibFredo6, I created a dedicated thread here.
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 115
                                            • 116
                                            • 88 / 116
