    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
    • fredo6F
      @tlehman914 said:
      Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
      Could you check the version of LibFredo6 you have installed.
      Did you play with FredoTools ColorPaint?
        Ski_Bird
        Hello,
        I may have found a bug in your DrawAlong tool. I have a JPG image that I'm adding countours to. I'm drawing them in the negative direction or below the image. When I type 6' .8", it draws a line not on the blue axis and at an angle towards the corner of the image. Trying to narrow down the error, 6' 1.8" works fine as does 6' 0.8". Very minor and easy to workaround but thought I'd share.
        Amazing work!
        • fredo6F
          @ski_bird said:
          Hello,
          Amazing work!
          I did not know that 6' .8" would be valid. Surprises everyday with these imperial units...!
          I will fix that in a next release.
            If you type 6'.8 and hit Enter or type 6'.8" and hit Enter you'll get a line that is 72.8 inches long. It's correct and expected behavior as far as I am seeing here. Fredo, I don't see that any change is needed.
            Units set to decimal inches to show the .8.
            Click on the picture
            • tlehman914T
              tlehman914
              Screen Shot 2021-03-23 at 2.36.33 PM.jpgLibFredo6
              11.6a
              23 Jan 21
              ColorPaint will not open.
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in color_palette_init' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in prepare_html'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in reload_html' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in dialog_create'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in dialog_invoke' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in dialog_launch'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in new'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in new'
              /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in _execution' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in execute_command'
                Robotopera
                Getting this error when installing on 2021.
                Error Loading File Fredo6_!LibFredo6.rb
                c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in match' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block (2 levels) in load_from_config'
                c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in each' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in block in load_from_config'
                c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in foreach' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in load_from_config'
                c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in block in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in each'
                c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:302:in startup'
                C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in process' C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in module:LibFredo6_Loader'
                C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                • fredo6F
                  How did you install LibFredo6?
                  • Copying files?
                  • Sketchup Extension manager from a rbz
                  • Sketchucation ExtensionStore?
                  It seems one file is altered.
                  • tlehman914T
                    tlehman914
                    I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
                    • fredo6F
                      I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
                      Could you try the following
                      • Open the Ruby Console
                      • copy the following command in red and type Enter:
                        UI.openURL LibFredo6.path + '/Ancillary'
                      • This will open a subfolder of LibFredo6
                      • Delete the file Colors_RAL_classic.txt
                      • restart Sketchup to see if this improves the situation
                      • Otherwise, delete all files with names beginning with Colors_ and extension txt.
                      Then restart Sketchup to see if this improves the situation.
                      • tlehman914T
                        tlehman914
                        I did try to copy the following command in red and type Enter:
                        Result:
                        false
                        I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
                        I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
                        • fredo6F
                          What is left in the directory?
                          Just type in the Ruby console:
                          Dir[LibFredo6.path + '/Ancillary/*.*']
                          • tlehman914T
                            tlehman914
                            Nothing is left in the directory...?
                            No change after typing the above.
                            • fredo6F
                              Did you define a custom color file?
                              If so, do you remember where you save it?
                              In the Ruby Console, could you type
                              Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
                              This should be the list of custom color files.
                              • tlehman914T
                                tlehman914
                                {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
                                • tlehman914T
                                  tlehman914
                                  I deleted the material 'Tree Tex8.jpg', and all is working!!!! 👍 😎 🎉
                                  THANK YOU!!!!
                                  • fredo6F
                                    In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                                    • tlehman914T
                                      tlehman914
                                      Understood. I didn't even know that I had done that...!? Thanks again!
                                        Robotopera
                                        • Copying files?
                                        Tried all 3 with full uninstalls in between each. Sadly no luck.
                                        Success! Running a repair on the sketchup installation seemed to fix it!
                                          atrasnap
                                          Bonjour à tous,
                                          Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
                                          Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
                                          Je ne peut donc pas l'utiliser.
                                          Il ya t-il une raison ou une manip particulière à effectuer ?
                                          Je suis sur SketchUp 21pro
                                          Merci d'avance
                                            Have you also installed LibFredo ?
                                            Have you restarted SketchUp ?
                                            Have you looked in the Tools menu's submenus ?
                                            Avez-vous également installé LibFredo?
                                            Avez-vous redémarré SketchUp?
                                            Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 115
                                            • 116
                                            • 88 / 116
