    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • tlehman914T
      tlehman914
      @fredo6 said:
      I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
      Could you try the following
      • Open the Ruby Console
      • copy the following command in red and type Enter:
        UI.openURL LibFredo6.path + '/Ancillary'
      • This will open a subfolder of LibFredo6
      • Delete the file Colors_RAL_classic.txt
      • restart Sketchup to see if this improves the situation
      • Otherwise, delete all files with names beginning with Colors_ and extension txt.
      Then restart Sketchup to see if this improves the situation.
      I did try to copy the following command in red and type Enter:
      Result:
      false
      I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
      I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
      Error: #<ArgumentError: invalid byte sequence in UTF-8>
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
      /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
      • fredo6F
        What is left in the directory?
        Just type in the Ruby console:
        Dir[LibFredo6.path + '/Ancillary/*.*']
        • tlehman914T
          tlehman914
          Nothing is left in the directory...?
          No change after typing the above.
          • fredo6F
            Did you define a custom color file?
            If so, do you remember where you save it?
            In the Ruby Console, could you type
            Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
            This should be the list of custom color files.
            • tlehman914T
              tlehman914
              {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
              • tlehman914T
                tlehman914
                I deleted the material 'Tree Tex8.jpg', and all is working!!!! 👍 😎 🎉
                THANK YOU!!!!
                • fredo6F
                  In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                  • tlehman914T
                    tlehman914
                    Understood. I didn't even know that I had done that...!? Thanks again!
                      Robotopera
                      @fredo6 said:
                      How did you install LibFredo6?
                      • Copying files?
                      • Sketchup Extension manager from a rbz
                      • Sketchucation ExtensionStore?
                      It seems one file is altered.
                      Tried all 3 with full uninstalls in between each. Sadly no luck.
                      Success! Running a repair on the sketchup installation seemed to fix it!
                        atrasnap
                        Bonjour à tous,
                        Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
                        Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
                        Je ne peut donc pas l'utiliser.
                        Il ya t-il une raison ou une manip particulière à effectuer ?
                        Je suis sur SketchUp 21pro
                        Merci d'avance
                          Have you also installed LibFredo ?
                          Have you restarted SketchUp ?
                          Have you looked in the Tools menu's submenus ?
                          Avez-vous également installé LibFredo?
                          Avez-vous redémarré SketchUp?
                          Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
                            martychristoffel
                            I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
                            I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
                            Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
                            Please see image examples.
                            Thanks.
                            • fredo6F
                              @martychristoffel
                              Thanks for signaling this problem. You are the first one.
                              Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
                              I will see if I can find a workaround in a next version of LibFredo6.
                                Dekorte
                                Hello LibFredo6,
                                I recieved your message showing me your Pic2Shape plugin.
                                I tried it with a couple of images and it works great.
                                However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
                                And here I ran into some troubles.
                                For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
                                I wonder if you could help me with the right filter settings so that the plugin can still work ?
                                I attached a tree (png) that doesn't generate a boundary when using the plugin.
                                All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
                                Many thanks in advance !
                                Boris
                                example tree png
                                • fredo6F
                                  Since this thread is about LibFredo6, I created a dedicated thread here.
                                  • T
                                    Tibonator
                                    Very efficient plugin thank you.
                                    The only issue is that the colour of action icons are extremely difficult to read against the white background.
                                    I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.
                                    Is it just me or a common issue that could be resolved easily on the developer's end?
                                    Thank you.
                                    T
                                    Icons colour (dotted in red) unreadable against white background.
                                    • fredo6F
                                      This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v11.7a - 12 May 21
                                        LibFredo6 11.7a includes
                                        • bug fixing and various technical adjustments
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v11.7c - 16 May 21
                                          LibFredo6 11.7c includes
                                          • bug fixing and various technical adjustments, mainly for Mac
                                          • G
                                            GregorS
                                            I get no confirmation that my installation of updates (through the Extension Manager) does anything.
                                            Is this to be expected?
                                            SU Make 2017
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 113
                                            • 114
                                            • 88 / 114
