    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • I
      ironjenn
      Hi everyone, I'm an amateur sketchup user, so apologies in advance for not knowing what I'm talking about... I have been using FredoCorner and recently purchased a license, but I have been experiencing issues with functionality. This is the error that most recently popped up in Rubyconsole when I tried to apply round to edges of a fairly simple face. Some version of this happens almost every time I try to use the extension, no matter what the shape. I also encountered an issue where it seemed to be finally working, and the preview looked ok, but when I generated the geometry it deleted the top face and created another crazy face shooting out into the abyss. (I tried to recreate the problem just now so I could take a screen shot, but now of course it isn't happening anymore - also, the forum won't let me upload my screenshots anyway bc they are too small? soooo...) Any ideas what could be going on here and/or how to fix it?
      Date: 09-Mar-21 20:00:04
      An error occurred in FredoCorner
      An error occured in the Ruby code
      undefined method `edges' for nil:NilClass
      fredocornerchemin.rbe:: 430 -- next_face_direction
      fredocorneralgo.rbe:: 2317 -- brane_free_chemin
      fredocorneralgo.rbe:: 2057 -- block in catena_process_branes_protected
      fredocorneralgo.rbe:: 2047 -- each
      fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
      fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
      fredocorneralgo.rbe:: 2008 -- catch
      fredocorneralgo.rbe:: 2008 -- catena_process_branes
      fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
      fredocorneralgo.rbe:: 964 -- each
      fredocorneralgo.rbe:: 964 -- solid_construct_branes
      fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
      fredocorneralgo.rbe:: 918 -- each
      fredocorneralgo.rbe:: 918 -- solid_reconstruction
      fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
      fredocornertool.rbe:: 1845 -- selection_change
      fredocornertool.rbe:: 1833 -- selection_add_remove_edges
      fredocornertool.rbe:: 1856 -- selection_set
      fredocornertool.rbe:: 1538 -- block in preselection_instantiate
      fredocornertool.rbe:: 1535 -- each
      fredocornertool.rbe:: 1535 -- preselection_instantiate
      fredocornertool.rbe:: 1530 -- preselection_analyze
      fredocornertool.rbe:: 766 -- true_activate
      fredocornertool.rbe:: 751 -- block in activate
      lib6plugin.rbe:: 1568 -- tem_context
      fredocornertool.rbe:: 751 -- activate
      fredocornertool.rbe:: 194 -- select_tool
      fredocornertool.rbe:: 194 -- launch
      fredocornertool.rbe:: 176 -- action__mapping
      lib6plugin.rbe:: 129 -- call
      lib6plugin.rbe:: 129 -- launch_action
      lib6plugin.rbe:: 227 -- launch_action
      bootstrap_fredocorner.rbe:: 103 -- launch_action
      bootstrap_fredocorner.rbe:: 118 -- block in startup
      lib6plugin.rbe:: 1347 -- command_invoke
      lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
      lib6traductor.rbe:: 1377 -- block in add_command
        Which version of SketchUp are you actually using? Your profile says you are using 2021 Make which doesn't exist.
        Can you share the .skp file where this problem occurs?
        • tlehman914T
          tlehman914
          Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
          SketchUp Pro 2021
          iMac (Retina 5K, 27-inch, 2019) macOS Big Sur
          Error: #<ArgumentError: invalid byte sequence in UTF-8>
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:1768:in draw'
          • fredo6F
            Could you check the version of LibFredo6 you have installed.
            Did you play with FredoTools ColorPaint?
              Ski_Bird
              Hello,
              I may have found a bug in your DrawAlong tool. I have a JPG image that I'm adding countours to. I'm drawing them in the negative direction or below the image. When I type 6' .8", it draws a line not on the blue axis and at an angle towards the corner of the image. Trying to narrow down the error, 6' 1.8" works fine as does 6' 0.8". Very minor and easy to workaround but thought I'd share.
              Amazing work!
              • fredo6F
                @ski_bird said:
                Hello,
                Amazing work!
                I did not know that 6' .8" would be valid. Surprises everyday with these imperial units...!
                I will fix that in a next release.
                  If you type 6'.8 and hit Enter or type 6'.8" and hit Enter you'll get a line that is 72.8 inches long. It's correct and expected behavior as far as I am seeing here. Fredo, I don't see that any change is needed.
                  Units set to decimal inches to show the .8.
                  Click on the picture
                  • tlehman914T
                    tlehman914
                    Screen Shot 2021-03-23 at 2.36.33 PM.jpgLibFredo6
                    11.6a
                    23 Jan 21
                    ColorPaint will not open.
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in color_palette_init' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in prepare_html'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in reload_html' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in dialog_create'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in dialog_invoke' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in dialog_launch'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in new'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in initialize' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in new'
                    /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in _execution' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in execute_command'
                      Robotopera
                      Getting this error when installing on 2021.
                      Error Loading File Fredo6_!LibFredo6.rb
                      c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in match' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in block (2 levels) in load_from_config'
                      c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in each' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in block in load_from_config'
                      c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in foreach' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in load_from_config'
                      c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in block in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in each'
                      c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in load_all_plugins' c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:302:in startup'
                      C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in process' C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in module:LibFredo6_Loader'
                      C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                      • fredo6F
                        How did you install LibFredo6?
                        • Copying files?
                        • Sketchup Extension manager from a rbz
                        • Sketchucation ExtensionStore?
                        It seems one file is altered.
                        • tlehman914T
                          tlehman914
                          I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
                          /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
                          • fredo6F
                            I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
                            Could you try the following
                            • Open the Ruby Console
                            • copy the following command in red and type Enter:
                              UI.openURL LibFredo6.path + '/Ancillary'
                            • This will open a subfolder of LibFredo6
                            • Delete the file Colors_RAL_classic.txt
                            • restart Sketchup to see if this improves the situation
                            • Otherwise, delete all files with names beginning with Colors_ and extension txt.
                            Then restart Sketchup to see if this improves the situation.
                            • tlehman914T
                              tlehman914
                              I did try to copy the following command in red and type Enter:
                              Result:
                              false
                              I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
                              I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
                              • fredo6F
                                What is left in the directory?
                                Just type in the Ruby console:
                                Dir[LibFredo6.path + '/Ancillary/*.*']
                                • tlehman914T
                                  tlehman914
                                  Nothing is left in the directory...?
                                  No change after typing the above.
                                  • fredo6F
                                    Did you define a custom color file?
                                    If so, do you remember where you save it?
                                    In the Ruby Console, could you type
                                    Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
                                    This should be the list of custom color files.
                                    • tlehman914T
                                      tlehman914
                                      {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
                                      • tlehman914T
                                        tlehman914
                                        I deleted the material 'Tree Tex8.jpg', and all is working!!!! πŸ‘ 😎 πŸŽ‰
                                        THANK YOU!!!!
                                        • fredo6F
                                          In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                                          • tlehman914T
                                            tlehman914
                                            Understood. I didn't even know that I had done that...!? Thanks again!
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 113
                                            • 114
                                            • 88 / 114
