    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    617 Posts 155 Posters 590.8k Views 154 Watching
      a_pusen
      This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
        It should work OK.
        You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
        Note that the JPP Extension is separate from FredoTools Extension ???
        After installing them you'll also need to restart SketchUp to sync everything.
        When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
          Tymnastik
          Please I have installed fredo jpits shows on the tool bar but it won't work
            Did you also install LibFredo6?
            What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
              AISmebel
              hi Fredo.
              I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
              I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
              https://youtu.be/wCsli3Ps7xc
                slb_jwm
                Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model.
                In a separate model, both those forms work, but only extrude normal to the faces (as designed).
                Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon.
                Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user?
                Trying to thicken this radially from its origin.
                I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
                  Is this what you're trying to do?
                  Click on the picture
                  • fredo6F Offline
                    JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
                      Raimondo_Vincenti
                      Installed libfredo6 11.4f -> JointPushPull is not awailable and cannot be installed anymore.
                      Message(german): "JointPushPull_v4.4e.rbz konnte nicht installiert werden."
                        Where are you looking for it?
                        SketchUp Plugins | PluginStore | SketchUcation
                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                        (sketchucation.com)
                          If you have successfully downloaded Fredo's extension as an RBZ file, then you still need to 'Install' it... using the appropriate button on SketchUp's 'Extension Manager' dialog...
                          But note that, as explained in the extension's notes, it also requires you to download and install a suitable version of the Libfredo... RBZ... [>=8.7]
                          After that you will need to restart SketchUp to 'sync' the loading files...
                            Raimondo_Vincenti
                            Fredo6 Libfredo6 is installed (Version11.4f) is installed
                            Still cannot install JointPushPull - a Sketchup 2021 problem?
                            I could use JountPushPull in Sketchup 2020.
                            ErrorMessage
                            • E Offline
                              Einstein
                              Hello,
                              I got an error with joint push pull extrusion in SketchUp 2020.
                              Date: 10-Jan-21 15:59:27
                              An error occurred in Joint Push Pull
                              Error in generation of the geometry
                              undefined method `target' for nil:NilClass
                              jointpushpullgeometry.rbe: 447 -- block in geometry_create_top_face
                              jointpushpullgeometry.rbe: 445 -- collect
                              jointpushpullgeometry.rbe: 445 -- geometry_create_top_face
                              jointpushpullgeometry.rbe: 258 -- block in geometry_robot_prepare_mesh
                              jointpushpullgeometry.rbe: 257 -- each
                              jointpushpullgeometry.rbe: 257 -- each_with_index
                              jointpushpullgeometry.rbe: 257 -- geometry_robot_prepare_mesh
                              jointpushpullgeometry.rbe: 212 -- robot_call_action
                              jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                              jointpushpullgeometry.rbe: 166 -- geometry_robot
                              jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                              lib6operation.rbe: 369 -- step_geometry
                              lib6operation.rbe: 304 -- block in yield?
                              JPP error.skp
                              • fredo6F Offline
                                I guess you wish to push-pull all faces.
                                Then, you have a number of them which are ill-formed and there is nothing JPP can do about it. For instance, these group of buildings:
                                • E Offline
                                  Einstein
                                  Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed?
                                  Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
                                    Why not clean up the model before you add more geometry and potentially make more problems for yourself?
                                    • fredo6F Offline
                                      I concur with Dave. Better clean up the model if you wish to do something with it.
                                      Detecting and cleaning the problem is a whole big task in itself. It could deserve a plugin. This is not like Sketchup tells you the face is ill-formed or not. Actually, these faces are toplogically valid for Sketchup but they won't work with many transformations and operations.
                                      So, using a detection and fixing before operating JPP would be counterproductive and a big hit to performance in 99.9% of cases where the geometry is OK.
                                        Thom Thom's CleanUp3 could remove coplanar edges to merge faces although it may not remove the correct edges. In this particular model it would be difficult for an extension to identify which edges should be removed.
                                        • E Offline
                                          Einstein
                                          That's weird. I actually did a cleanup using ThomThom's plugin and JPP first threw an error. Then did a cleanup again and JPP worked fine.
                                          I don't know why it happened but sorry for bothering you.
                                            jpaine
                                            Hi everyone,
                                            Is project shape on a plane possible on a Mac? I can't seem to find this option.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
