    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @rv1974 said:
      :lol: you just exactly reproduced the way I created the 'wanted' model.
      Originally I just wanted clarity (or request πŸ˜‰) maybe there's some combination of settings that allows to achieve the 'wanted' result without tedious 'one by one' clicking
      Many things can be done, but it would make the UI more complex...
        rv1974
        something like this
          rv1974
          Ok, I'm just suggesting to tweak the plugin's behavior without UI changing:
          If face selection = surface,
          molding not equal 0,
          borders = grid,
          Then
          'moldings' to be created between surfaces (and not along contour only)?
            a_pusen
            This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
              It should work OK.
              You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
              Note that the JPP Extension is separate from FredoTools Extension ???
              After installing them you'll also need to restart SketchUp to sync everything.
              When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
              • T
                Tymnastik
                Please I have installed fredo jpits shows on the tool bar but it won't work
                  Did you also install LibFredo6?
                  What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
                    AISmebel
                    hi Fredo.
                    I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
                    I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
                    https://youtu.be/wCsli3Ps7xc
                      slb_jwm
                      Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model.
                      In a separate model, both those forms work, but only extrude normal to the faces (as designed).
                      Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon.
                      Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user?
                      Trying to thicken this radially from its origin.
                      I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
                        Is this what you're trying to do?
                        Click on the picture
                        • fredo6F
                          JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
                            Raimondo_Vincenti
                            Installed libfredo6 11.4f -> JointPushPull is not awailable and cannot be installed anymore.
                            Message(german): "JointPushPull_v4.4e.rbz konnte nicht installiert werden."
                              Where are you looking for it?
                              SketchUp Plugins | PluginStore | SketchUcation
                              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                              (sketchucation.com)
                                If you have successfully downloaded Fredo's extension as an RBZ file, then you still need to 'Install' it... using the appropriate button on SketchUp's 'Extension Manager' dialog...
                                But note that, as explained in the extension's notes, it also requires you to download and install a suitable version of the Libfredo... RBZ... [>=8.7]
                                After that you will need to restart SketchUp to 'sync' the loading files...
                                  Raimondo_Vincenti
                                  Fredo6 Libfredo6 is installed (Version11.4f) is installed
                                  Still cannot install JointPushPull - a Sketchup 2021 problem?
                                  I could use JountPushPull in Sketchup 2020.
                                  ErrorMessage
                                  • E
                                    Einstein
                                    Hello,
                                    I got an error with joint push pull extrusion in SketchUp 2020.
                                    Date: 10-Jan-21 15:59:27
                                    An error occurred in Joint Push Pull
                                    Error in generation of the geometry
                                    undefined method `target' for nil:NilClass
                                    jointpushpullgeometry.rbe: 447 -- block in geometry_create_top_face
                                    jointpushpullgeometry.rbe: 445 -- collect
                                    jointpushpullgeometry.rbe: 445 -- geometry_create_top_face
                                    jointpushpullgeometry.rbe: 258 -- block in geometry_robot_prepare_mesh
                                    jointpushpullgeometry.rbe: 257 -- each
                                    jointpushpullgeometry.rbe: 257 -- each_with_index
                                    jointpushpullgeometry.rbe: 257 -- geometry_robot_prepare_mesh
                                    jointpushpullgeometry.rbe: 212 -- robot_call_action
                                    jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
                                    jointpushpullgeometry.rbe: 166 -- geometry_robot
                                    jointpushpullgeometry.rbe: 81 -- block in geometry_execute
                                    lib6operation.rbe: 369 -- step_geometry
                                    lib6operation.rbe: 304 -- block in yield?
                                    JPP error.skp
                                    • fredo6F
                                      I guess you wish to push-pull all faces.
                                      Then, you have a number of them which are ill-formed and there is nothing JPP can do about it. For instance, these group of buildings:
                                      • E
                                        Einstein
                                        Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed?
                                        Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
                                          Why not clean up the model before you add more geometry and potentially make more problems for yourself?
                                          • fredo6F
                                            I concur with Dave. Better clean up the model if you wish to do something with it.
                                            Detecting and cleaning the problem is a whole big task in itself. It could deserve a plugin. This is not like Sketchup tells you the face is ill-formed or not. Actually, these faces are toplogically valid for Sketchup but they won't work with many transformations and operations.
                                            So, using a detection and fixing before operating JPP would be counterproductive and a big hit to performance in 99.9% of cases where the geometry is OK.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 30
                                            • 31
                                            • 23 / 31
