    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.3k Views 121 Watching
    • E Offline
      edjul04
      If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
      How can I fix the mistake?
      • fredo6F Offline
        What is the error?
        • E Offline
          edjul04
          This is an example of what was happening.
          I re-installed sketchup and the plugin without success, I was using SketchUp2019. Yesterday I upgraded my license to SketchUp2020 and the problem was fixed.
          Example
          • fredo6F Offline
            Could you post or PM me the model so that I have a closer look.
            • designerbursaD Offline
              designerbursa
              fredo tools icon problems
              • fredo6F Offline
                This is a known problem with SU2020, not specific to my plugins.
                Apparently, the installation of SU2020 'forgets' to register itself to Internet Explorer and as a result, it does not display the SVG graphics. Not even sure this is fixed with a new installation.
                See this post for a kind of fix.
                P: Are you still on SU8, as indicated in your profile?
                  designerbursa
                  yes I switched to 2020, thanks for your help 👍
                    designerbursa
                    Windows Registry Editor Version 5.00
                    [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
                    "sketchup.exe"=dword:00002af8
                    I added regedit and it was improved thanks a lot
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v4.0a - 17 May 20
                      Requirement: LibFredo6 v10.4b or above
                      FredoTools 4.0a is a major release for ReportLabelArea, fixing visual display and resizing.
                      See FredoTools plugin home page for Download.
                      See also main post of this thread for User Discussion.
                        CTH1963
                        Since the 4.0a release I get an error when starting Sketchup (screenshot attached).
                        All other updates have been fine...
                        Fredo Tools 4.0a error doalog
                        • fredo6F Offline
                          @cth1963 said:
                          Please note that I do not support evolution for my plugins for versions prior to SU2017 (so up to SU2016). This is due to a change of policy in the releasing of extension by Trimble.
                          For convenience, I kept the legacy versions in this place.
                            CTH1963
                            @fredo6 said:
                            @cth1963 said:
                            Thanks, I was hoping to get a link to the prior version - much appreciated.
                              Ste34
                              Bonjour,
                              Je n'arrive pas Ă  lancer votre plugin, L'erreur ci-dessous s'affiche lors du lancement de sketchup :
                              Auriez vous une solution Ă  me proposer ?
                              Cordialement
                              Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                              Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LibFredo6Trace_17_1590444009629.txt>
                              c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in initialize' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in open'
                              c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in log' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:166:in startup'
                              C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:in process' C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in module:LibFredo6_Loader'
                              C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in -'
                              C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                              C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                              C:/Users/sTĂ©/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
                                Avex
                                Exactly the same over here...
                                  You have an accented character in your Windows user-name:
                                  c:/users/sté/appdata/...
                                  This used to be the kiss-of-death to older Ruby versions, but with the newer 'encode' methods most user's paths can be re-encoded into a 'Ruby-safe' format...
                                  Clearly something is going wrong !
                                  I'm sure that Fredo will have ideas, and a solution...
                                  Watch this space...
                                  Vous avez un caractÚre accentué dans votre nom d'utilisateur Windows:
                                  Auparavant, c'Ă©tait le baiser de la mort pour les anciennes versions de Ruby, mais avec les nouvelles mĂ©thodes d'encodage, la plupart des chemins de l'utilisateur peuvent ĂȘtre rĂ©-encodĂ©s au format 'Ruby-safe' ...
                                  De toute évidence, quelque chose ne va pas!
                                  Je suis sûr que Fredo aura des idées et une solution ...
                                  Surveillez cet endroit...
                                    CTH1963
                                    @cth1963 said:
                                    @fredo6 said:
                                    @cth1963 said:
                                    Ok, I've now installed LibFredo v9.5k from the Sketchucation store which says it's OK for SU versions up to 2016. When Skethcup restarts, I get a dialog saying:
                                    "This legacy version of LibFredo6 can ONLY be used for Sketchup version prior to SU2016"
                                    This implies: new LibFredo only for SU >=2017
                                    legacy LibFrdeo only for SU <= 2015
                                    No provision for SU2016?!?
                                    I look in Fredo6_!LibFredo6.rb and see one of the first the lines is:
                                    if Sketchup.version.to_i < 16
                                    Thinking this was a typo I edited it to test for '< 17' and now the result is:
                                    "Wrong installation: Folder Fredo6_!LibFredo6 is missing in <my plugins location>"
                                    I can confirm the folder is present in the location that it's complaining about.
                                    I'm not sure what's going on here - any help appreciated.
                                      What is your "plugins location"? What version of SketchUp are you using? Please complete your profile.
                                      • fredo6F Offline
                                        @CTH1963,
                                        Thanks for signaling this problem. I have updated the Prior2017 - LibFredo6 - Archived version on the Sketchucation Extension Store.
                                        Initially, I thought I could exclude SU2016 from legacy, but there are other elements that will be deprecated in Sketchup also in this version. So I ended up to consider Legacy all SU versions <= 2016.
                                          Avex
                                          @fredo6 said:
                                          @CTH1963,
                                          Fredo, I have 2019 and the problem remains.
                                          • fredo6F Offline
                                            @Avex
                                            Your problem is related to permission of Sketchup to access the AppData directories.
                                            Error; #<Errno;;EACCES; Permission denied @ rb_sysopen -
                                            C;/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LibFredo6Trace_17_1590444009629.txt>
                                            I guess this is related to setting the proper security parameters.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 23
                                            • 24
                                            • 12 / 24
