    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.0k Views 122 Watching
    • V
      volker72
      Hello Fredo,
      is it possible to do the same with length as ReportLabelArea does with faces.
      Volker
      • fredo6F
        You need to tell which length...length of edges, length of object bounding boxes, ...
        • V
          volker72
          I am interested in the length of edges. The goal is to add up these lengths by layers. That would be wonderful.
            @jmdrla said:
            Unfortunately it is not in my extension menu and I cannot access the tools... What is the issue?
            First things first. FredoTools aren't supposed to show up in the Extension menu. They are supposed to show up in the Tools menu. Did you look there? Also did you restart SketchUp after installing the extensions?
            There's also a toolbar that can be made visible via View>Toolbars.
            @jmdrla said:
            I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020.
            Not so. FredoTools work just fine in SketchUp 2020. Here is a screen shot from SU2020 showing the menu.
            Out of curiosity, when you installed SketchUp 2020, did you right click on the downloaded installer file and choose Run as administrator? BTW, maybe you could update your profile. It still shows you are using SU2017.
              jmdrla
              I loaded the FredoTools-v3.8c this morning in my SketchUp Pro along with the required library. I have tried to add the tools to the program about ten times now and it is showing up in the extension manager as installed and activated. Unfortunately it is not in my extension menu and I cannot access the tools. When I look at the details for the tools on the extension manager I can see that it is signed but there is no other information in the details. I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020. What is the issue?
              OK I should have used the word tools instead of extensions. However the program is not in the tools menu. I did restart the SU2020 when I did the install and nothing appeared in my tools menu. I am uploading a screen shot so you can see what I have
              • E
                edjul04
                If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
                How can I fix the mistake?
                • fredo6F
                  What is the error?
                  • E
                    edjul04
                    This is an example of what was happening.
                    I re-installed sketchup and the plugin without success, I was using SketchUp2019. Yesterday I upgraded my license to SketchUp2020 and the problem was fixed.
                    Example
                    • fredo6F
                      Could you post or PM me the model so that I have a closer look.
                      • designerbursaD
                        designerbursa
                        fredo tools icon problems
                        • fredo6F
                          This is a known problem with SU2020, not specific to my plugins.
                          Apparently, the installation of SU2020 'forgets' to register itself to Internet Explorer and as a result, it does not display the SVG graphics. Not even sure this is fixed with a new installation.
                          See this post for a kind of fix.
                          P: Are you still on SU8, as indicated in your profile?
                          • designerbursaD
                            designerbursa
                            yes I switched to 2020, thanks for your help 👍
                            • designerbursaD
                              designerbursa
                              Windows Registry Editor Version 5.00
                              [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
                              "sketchup.exe"=dword:00002af8
                              I added regedit and it was improved thanks a lot
                              • fredo6F
                                NEW RELEASE: FredoTools v4.0a - 17 May 20
                                Requirement: LibFredo6 v10.4b or above
                                FredoTools 4.0a is a major release for ReportLabelArea, fixing visual display and resizing.
                                See FredoTools plugin home page for Download.
                                See also main post of this thread for User Discussion.
                                • C
                                  CTH1963
                                  Since the 4.0a release I get an error when starting Sketchup (screenshot attached).
                                  All other updates have been fine...
                                  Fredo Tools 4.0a error doalog
                                  • fredo6F
                                    @cth1963 said:
                                    Please note that I do not support evolution for my plugins for versions prior to SU2017 (so up to SU2016). This is due to a change of policy in the releasing of extension by Trimble.
                                    For convenience, I kept the legacy versions in this place.
                                    • C
                                      CTH1963
                                      @fredo6 said:
                                      @cth1963 said:
                                      Thanks, I was hoping to get a link to the prior version - much appreciated.
                                        Ste34
                                        Bonjour,
                                        Je n'arrive pas à lancer votre plugin, L'erreur ci-dessous s'affiche lors du lancement de sketchup :
                                        Auriez vous une solution à me proposer ?
                                        Cordialement
                                        Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                        Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LibFredo6Trace_17_1590444009629.txt>
                                        c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in initialize' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in open'
                                        c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in log' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:166:in startup'
                                        C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:in process' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in module:LibFredo6_Loader'
                                        C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in -'
                                        C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                        C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                        C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
                                          Avex
                                          Exactly the same over here...
                                            You have an accented character in your Windows user-name:
                                            c:/users/sté/appdata/...
                                            This used to be the kiss-of-death to older Ruby versions, but with the newer 'encode' methods most user's paths can be re-encoded into a 'Ruby-safe' format...
                                            Clearly something is going wrong !
                                            I'm sure that Fredo will have ideas, and a solution...
                                            Watch this space...
                                            Vous avez un caractère accentué dans votre nom d'utilisateur Windows:
                                            Auparavant, c'était le baiser de la mort pour les anciennes versions de Ruby, mais avec les nouvelles méthodes d'encodage, la plupart des chemins de l'utilisateur peuvent être ré-encodés au format 'Ruby-safe' ...
                                            De toute évidence, quelque chose ne va pas!
                                            Je suis sûr que Fredo aura des idées et une solution ...
                                            Surveillez cet endroit...
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 20 / 24
