    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 817.7k Views 121 Watching
      bharralure
      Bonjour Fredo,
      Merci pour cette mise à jour rapide et efficace.
      Je viens de tester sur SU19 et SU20, et tout est rentré dans l'ordre, parfait.
      • V Offline
        volker72
        Hello Fredo,
        is it possible to do the same with length as ReportLabelArea does with faces.
        Volker
        • fredo6F Offline
          You need to tell which length...length of edges, length of object bounding boxes, ...
          • V Offline
            volker72
            I am interested in the length of edges. The goal is to add up these lengths by layers. That would be wonderful.
              @jmdrla said:
              Unfortunately it is not in my extension menu and I cannot access the tools... What is the issue?
              First things first. FredoTools aren't supposed to show up in the Extension menu. They are supposed to show up in the Tools menu. Did you look there? Also did you restart SketchUp after installing the extensions?
              There's also a toolbar that can be made visible via View>Toolbars.
              @jmdrla said:
              I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020.
              Not so. FredoTools work just fine in SketchUp 2020. Here is a screen shot from SU2020 showing the menu.
              Out of curiosity, when you installed SketchUp 2020, did you right click on the downloaded installer file and choose Run as administrator? BTW, maybe you could update your profile. It still shows you are using SU2017.
                jmdrla
                I loaded the FredoTools-v3.8c this morning in my SketchUp Pro along with the required library. I have tried to add the tools to the program about ten times now and it is showing up in the extension manager as installed and activated. Unfortunately it is not in my extension menu and I cannot access the tools. When I look at the details for the tools on the extension manager I can see that it is signed but there is no other information in the details. I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020. What is the issue?
                OK I should have used the word tools instead of extensions. However the program is not in the tools menu. I did restart the SU2020 when I did the install and nothing appeared in my tools menu. I am uploading a screen shot so you can see what I have
                • E Offline
                  edjul04
                  If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
                  How can I fix the mistake?
                  • fredo6F Offline
                    What is the error?
                    • E Offline
                      edjul04
                      This is an example of what was happening.
                      I re-installed sketchup and the plugin without success, I was using SketchUp2019. Yesterday I upgraded my license to SketchUp2020 and the problem was fixed.
                      Example
                      • fredo6F Offline
                        Could you post or PM me the model so that I have a closer look.
                        • designerbursaD Offline
                          designerbursa
                          fredo tools icon problems
                          • fredo6F Offline
                            This is a known problem with SU2020, not specific to my plugins.
                            Apparently, the installation of SU2020 'forgets' to register itself to Internet Explorer and as a result, it does not display the SVG graphics. Not even sure this is fixed with a new installation.
                            See this post for a kind of fix.
                            P: Are you still on SU8, as indicated in your profile?
                              designerbursa
                              yes I switched to 2020, thanks for your help 👍
                                designerbursa
                                Windows Registry Editor Version 5.00
                                [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
                                "sketchup.exe"=dword:00002af8
                                I added regedit and it was improved thanks a lot
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v4.0a - 17 May 20
                                  Requirement: LibFredo6 v10.4b or above
                                  FredoTools 4.0a is a major release for ReportLabelArea, fixing visual display and resizing.
                                  See FredoTools plugin home page for Download.
                                  See also main post of this thread for User Discussion.
                                    CTH1963
                                    Since the 4.0a release I get an error when starting Sketchup (screenshot attached).
                                    All other updates have been fine...
                                    Fredo Tools 4.0a error doalog
                                    • fredo6F Offline
                                      @cth1963 said:
                                      Please note that I do not support evolution for my plugins for versions prior to SU2017 (so up to SU2016). This is due to a change of policy in the releasing of extension by Trimble.
                                      For convenience, I kept the legacy versions in this place.
                                        CTH1963
                                        @fredo6 said:
                                        @cth1963 said:
                                        Thanks, I was hoping to get a link to the prior version - much appreciated.
                                          Ste34
                                          Bonjour,
                                          Je n'arrive pas à lancer votre plugin, L'erreur ci-dessous s'affiche lors du lancement de sketchup :
                                          Auriez vous une solution à me proposer ?
                                          Cordialement
                                          Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                          Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LibFredo6Trace_17_1590444009629.txt>
                                          c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in initialize' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in open'
                                          c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in log' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:166:in startup'
                                          C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:in process' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in module:LibFredo6_Loader'
                                          C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in -'
                                          C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                          C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
                                            Avex
                                            Exactly the same over here...
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 19 / 24
