    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • fredo6F Offline
      @stebbins said:
      Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
      I would need to have the model, and also to understand how you used the OffsetOnSurface tool.
      • jgbJ Offline
        jgb
        I take it that those roofs have the center raised a bit. The diagonal lines are the "hip" bends. Quite normal. You need to make then "soft" or hidden.
        Three ways, either select the line and change its attribute in Entity Attributes; or
        with the erase tool, press and hold "CTRL" and sweep over the line.
        The third way is to create a layer and move those lines into it. Make that layer visible or invisible as needed.
        jgb
          j40
          Hi, great plugin! ๐Ÿ‘ I have an issue on SketchUp 2020 version (Mac), it's not appearing in none of menus.
          on SU 2018 it's working perfectly though.
          Any idea why it happens?
          best regards
          Top3D Studio
            It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
              j40
              [attachment=0:880xdl1k]<!-- ia0 -->Screenshot - 5_3_2020 , 1_52_06 PM.png<!-- ia0 -->[/attachment:880xdl1k]
              Yes, I have. No luck. As if nothing was added/installed. Very odd.
              Top3D Studio
                How did you install it?
                  j40
                  Via: Extension Manager>Install Extension>ToolsOnSurface_v2.4a.rbz
                  Top3D Studio
                    Do you have the most current version of LibFredo6 installed, too?
                      j40
                      Indeed.
                      The same .rbz was successfully installed on SU 2018 though ๐Ÿ˜•
                      Top3D Studio
                        Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
                          j40
                          Yes, I have. Also updated to the most recent SU update (20.1.228 OS X).
                          Top3D Studio
                          • designerbursaD Offline
                            designerbursa
                            When will your update arrive?
                              rv1974
                              Fredo, is it possible 'Offset on surface tool' process multiple quads en mass, and not by double clicking quad by quad (this is what we currently have)?
                              • fredo6F Offline
                                This would impose a change in UI to have multiple offsets in one go. So possible, but not for now.
                                  rv1974
                                  OK thank you for reply, but it'd awesome to see it some day
                                  • fredo6F Offline
                                    NEW RELEASE: Tools on Surface 2.5a- 22 Apr 21
                                    Requirements
                                    • LibFredo6: v11.6a
                                    This maintenance release is for improving performance of the selection context menu.
                                    Please see main post for discussion
                                    See Plugin download page for download
                                      chapalee
                                      Hi, how are you.
                                      First of all I wanted to thank you for your work and collaboration.
                                      Second excuse my English, I only speak Spanish and the translator helped me.
                                      I wanted to ask you two things.
                                      1- Is there a way to offset only one edge.
                                      Currently the offset is done around the entire contour and many times it is only necessary to do it with one edge.
                                      I am attaching an image so that you understand me better.
                                      2- I am trying to make a line by selecting two points on the edges of the surface but the edge of the surface is curved.
                                      He draws the straight line and it is correct because it is a line, but if the line passes through a place where there is no surface he should give an option to draw the straight line or draw it on the surface.
                                      Well if there is any solution, I appreciate if you help me how to do it, if not, you should add these options, it would be very good.
                                      Offset edge
                                      Line by point
                                      • E Offline
                                        ethesaunde
                                        Hello,
                                        Do I need to purchase a license before getting access to the free trial? I just installed it for the first time and I am getting a "Free trial expired on March 25" error. Can you please advise?
                                        Thank you.
                                          Did you first install the current version of the Sketchucation ExtensionStore tool?
                                          • E Offline
                                            ethesaunde
                                            Yes, I did install v4.2.9
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
