    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • fredo6F
      @jgb said:
      What do you mean "sharp borders"?
      Usual cases where you TOS algorithm has problem are those where the surface is a close shape and when you start from an edge which has a sharp angle.
        mrswissmaster
        Is it possible to place image on curved surface?
          Native tools can do that or you could look at Fredo's Thru Paint.
          • K
            keitheseymour
            I'm running Sketchup 2015, and have installed Fredo6: Tools On Surface v2.4a. I can see it installed in my extensions list, but it doesn't show up in the menus to use. Any ideas? Thanks in advance.
            • BoxB
              Did you install the Fredo Library that is required.
                Fredo's tools appear under the Tools menu, did you look there ?
                  stebbins
                  Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
                  Thanks in advance,
                  showing diagonal lines.
                  • fredo6F
                    I would need to have the model, and also to understand how you used the OffsetOnSurface tool.
                    • jgbJ
                      jgb
                      I take it that those roofs have the center raised a bit. The diagonal lines are the "hip" bends. Quite normal. You need to make then "soft" or hidden.
                      Three ways, either select the line and change its attribute in Entity Attributes; or
                      with the erase tool, press and hold "CTRL" and sweep over the line.
                      The third way is to create a layer and move those lines into it. Make that layer visible or invisible as needed.
                      jgb
                        j40
                        Hi, great plugin! πŸ‘ I have an issue on SketchUp 2020 version (Mac), it's not appearing in none of menus.
                        on SU 2018 it's working perfectly though.
                        Any idea why it happens?
                        best regards
                        Top3D Studio
                          It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
                            j40
                            [attachment=0:880xdl1k]<!-- ia0 -->Screenshot - 5_3_2020 , 1_52_06 PM.png<!-- ia0 -->[/attachment:880xdl1k]
                            Yes, I have. No luck. As if nothing was added/installed. Very odd.
                            Top3D Studio
                              How did you install it?
                                j40
                                Via: Extension Manager>Install Extension>ToolsOnSurface_v2.4a.rbz
                                Top3D Studio
                                  Do you have the most current version of LibFredo6 installed, too?
                                    j40
                                    Indeed.
                                    The same .rbz was successfully installed on SU 2018 though πŸ˜•
                                    Top3D Studio
                                      Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
                                        j40
                                        Yes, I have. Also updated to the most recent SU update (20.1.228 OS X).
                                        Top3D Studio
                                        • designerbursaD
                                          designerbursa
                                          When will your update arrive?
                                            rv1974
                                            Fredo, is it possible 'Offset on surface tool' process multiple quads en mass, and not by double clicking quad by quad (this is what we currently have)?
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 30 / 32
