    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      j40
      @tig said:
      Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
      Yes, I have. Also updated to the most recent SU update (20.1.228 OS X).
      Top3D Studio
      • designerbursaD
        designerbursa
        When will your update arrive?
          rv1974
          Fredo, is it possible 'Offset on surface tool' process multiple quads en mass, and not by double clicking quad by quad (this is what we currently have)?
          • fredo6F
            This would impose a change in UI to have multiple offsets in one go. So possible, but not for now.
              rv1974
              OK thank you for reply, but it'd awesome to see it some day
              • fredo6F
                NEW RELEASE: Tools on Surface 2.5a- 22 Apr 21
                Requirements
                • LibFredo6: v11.6a
                This maintenance release is for improving performance of the selection context menu.
                Please see main post for discussion
                See Plugin download page for download
                • C
                  chapalee
                  Hi, how are you.
                  First of all I wanted to thank you for your work and collaboration.
                  Second excuse my English, I only speak Spanish and the translator helped me.
                  I wanted to ask you two things.
                  1- Is there a way to offset only one edge.
                  Currently the offset is done around the entire contour and many times it is only necessary to do it with one edge.
                  I am attaching an image so that you understand me better.
                  2- I am trying to make a line by selecting two points on the edges of the surface but the edge of the surface is curved.
                  He draws the straight line and it is correct because it is a line, but if the line passes through a place where there is no surface he should give an option to draw the straight line or draw it on the surface.
                  Well if there is any solution, I appreciate if you help me how to do it, if not, you should add these options, it would be very good.
                  Offset edge
                  Line by point
                  • E
                    ethesaunde
                    Hello,
                    Do I need to purchase a license before getting access to the free trial? I just installed it for the first time and I am getting a "Free trial expired on March 25" error. Can you please advise?
                    Thank you.
                      Did you first install the current version of the Sketchucation ExtensionStore tool?
                      • E
                        ethesaunde
                        Yes, I did install v4.2.9
                        • E
                          ethesaunde
                            rv1974
                            Fredo, any chance to fix this 14 y.o. critical bug? even staying away from the borders the result is distressing
                            Maybe, as alternative, FredoSpline could work on surface? Especially 'Convert' command
                            • C
                              chrissfcs
                              Love the tools on surface tool, used it for years but have been getting this error in the attached image when sketch up opens. the menus do not show up the next time sketchup loads.
                              • L
                                leall
                                OlĂĄ,
                                Eu estou com problemas para ativar o plugin comprado. Segui todas os passos indicados por vocÊs, mas mesmo assim não deu certo.
                                Na aba "global status of plugins" não aparece minha licença.
                                Como eu poderia prosseguir? Obrigada
                                  Trnaslated by Google:
                                  @leall said:
                                  OlĂĄ,
                                  I'm having trouble activating the purchased plugin. I followed all the steps indicated by you, but it still didn't work.
                                  In the "global status of plugins" tab, my license does not appear.
                                  How could I proceed? Thanks
                                  Do you have the current version of LibFredo6 and the Sketchucation Tool installed? Have you restarted SketchUp? What version of SketchUp are you actually using? Your profile says 2021 Free/Make but there is no such version.
                                  • fredo6F
                                    VocĂȘ poderia ser mais explĂ­cito sobre qual Ă© o problema? VocĂȘ recebe uma mensagem?
                                      O que vocĂȘ fez com seus arquivos de licença?
                                      VocĂȘ os armazenou em seu computador e os 'validou' para a extensĂŁo relacionada usando o item de menu relevante?
                                      Mais informaçÔes são necessårias para estabelecer seu problema exato...
                                      What have you done with your license files ?
                                      Have you stored them on your computer and then 'validated' them for the related extension using the relevant menu item ?
                                      More info is needed to establish your exact problem...
                                        aiden
                                        When I draw a line on even a very simple surface, Tools on surface takes an enormous amount of time to complete the task. I'm running on a very powerful workstation with lots of ram, and the last test I ran had only two faces. Any idea what causes this behavior?
                                          @aiden said:
                                          I'm running on a very powerful workstation with lots of ram ...
                                          Still SketchUp 2018? What graphics card? Can you share you simple model?
                                            aiden
                                            Hi Dave - thanks for your response - Here's more specific info:
                                            Sketchup Pro 2021, 21.1.299 (classic perpetual license)
                                            Intel Core i9 10900K, 3.7GHz, 64GB ram,
                                            Windows 10 Pro. RTX 3090, (528.02 driver)
                                            LibFredo6 13.9a, Tools on Surface 2.5a. Fresh install.
                                            The plugin works fine on my workstation in a model with very little geometry.
                                            It also works fine on the somewhat less powerful workstation of my coworker,
                                            who is working on an identical copy of the file I am working on. (???)
                                            He is using a slightly older copy of Sketchup Pro 21.0.391. (Subscription plan)
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 31 / 32
