    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
        j40
        [attachment=0:880xdl1k]<!-- ia0 -->Screenshot - 5_3_2020 , 1_52_06 PM.png<!-- ia0 -->[/attachment:880xdl1k]
        Yes, I have. No luck. As if nothing was added/installed. Very odd.
        Top3D Studio
          How did you install it?
            j40
            Via: Extension Manager>Install Extension>ToolsOnSurface_v2.4a.rbz
            Top3D Studio
              Do you have the most current version of LibFredo6 installed, too?
                j40
                Indeed.
                The same .rbz was successfully installed on SU 2018 though πŸ˜•
                Top3D Studio
                  Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
                    j40
                    Yes, I have. Also updated to the most recent SU update (20.1.228 OS X).
                    Top3D Studio
                    • designerbursaD
                      designerbursa
                      When will your update arrive?
                        rv1974
                        Fredo, is it possible 'Offset on surface tool' process multiple quads en mass, and not by double clicking quad by quad (this is what we currently have)?
                        • fredo6F
                          This would impose a change in UI to have multiple offsets in one go. So possible, but not for now.
                            rv1974
                            OK thank you for reply, but it'd awesome to see it some day
                            • fredo6F
                              NEW RELEASE: Tools on Surface 2.5a- 22 Apr 21
                              Requirements
                              • LibFredo6: v11.6a
                              This maintenance release is for improving performance of the selection context menu.
                              Please see main post for discussion
                              See Plugin download page for download
                              • C
                                chapalee
                                Hi, how are you.
                                First of all I wanted to thank you for your work and collaboration.
                                Second excuse my English, I only speak Spanish and the translator helped me.
                                I wanted to ask you two things.
                                1- Is there a way to offset only one edge.
                                Currently the offset is done around the entire contour and many times it is only necessary to do it with one edge.
                                I am attaching an image so that you understand me better.
                                2- I am trying to make a line by selecting two points on the edges of the surface but the edge of the surface is curved.
                                He draws the straight line and it is correct because it is a line, but if the line passes through a place where there is no surface he should give an option to draw the straight line or draw it on the surface.
                                Well if there is any solution, I appreciate if you help me how to do it, if not, you should add these options, it would be very good.
                                Offset edge
                                Line by point
                                • E
                                  ethesaunde
                                  Hello,
                                  Do I need to purchase a license before getting access to the free trial? I just installed it for the first time and I am getting a "Free trial expired on March 25" error. Can you please advise?
                                  Thank you.
                                    Did you first install the current version of the Sketchucation ExtensionStore tool?
                                    • E
                                      ethesaunde
                                      Yes, I did install v4.2.9
                                      • E
                                        ethesaunde
                                          rv1974
                                          Fredo, any chance to fix this 14 y.o. critical bug? even staying away from the borders the result is distressing
                                          Maybe, as alternative, FredoSpline could work on surface? Especially 'Convert' command
                                          • C
                                            chrissfcs
                                            Love the tools on surface tool, used it for years but have been getting this error in the attached image when sketch up opens. the menus do not show up the next time sketchup loads.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 31 / 32
