    [Plugin] Purge All
    65 Posts 32 Posters 151.2k Views 32 Watching
    • K
      kaas
      Suggestion: to really purge a file to its bare minimum, maybe add an option to remove attributes (set by some plugins), ifc info etc?
        I was thinking about offering to delete the IFC stuff as that can bloat a file and slow it down.
        However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
        • K
          kaas
          @tig said:
          ...However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
          Good point. Maybe make a combo box with several options for cleaning the attributes: remove all, preserve @ components, ...
            argenario
            I,ve just downloaded it and purged 368 materials that were not in use and making my drawing sooo slow(sketchup 2015).... THANK U! THANK U! THANK U! THANKS A LOT!
              Here's v2.0 http://sketchucation.com/pluginstore?pln=PurgeAll It is now signed for full compatibility with v2016/2017 in all loading-policies.
              • F
                feodos
                Can I ask you to make an icon for this plugin?
                http://f21.ifotki.info/org/6feee38364657529bba52278e94868bfbca241272661627.png
                  No need to make the plugin more complex. Just make a keyboard shortcut for it.
                    Here's v3.0
                    https://sketchucation.com/pluginstore?pln=PurgeAll
                    It's now signed for full compatibility with all current SketchUp versions, in all extension-loading-policies.
                    It also has the annoying display glitch fixed - where the report's formatting for materials tabbed over to the right too much !
                    • boofredlayB
                      boofredlay
                      Thanks TIG
                        Here's v4.0
                        It's now made fully compatible with v2020 - replacing 'Layers' with 'Tags' when prompting/reporting...
                          Thank you sir.
                            Here's v5.0
                            It fixes the sometimes confusing reporting of groups getting included in the end components list [groups are component-definitions, but they are never purge-able].
                            It also address the log-file not opening on MAC's using newer versions of SketchUp...
                              rv1974
                              @TIG Could it be non-modal please - what exactly is the point of hitting OK?
                              TIGT 1 Reply Last reply
                                TIG Moderator @rv1974
                                @rv1974
                                It can't be non-modal because it uses the UI.inputbox which is always modal.
                                Thre has to be a way of closing the window - in this case it's OK or Cancel...
                                R 1 Reply Last reply
                                  rv1974 @TIG
                                  @TIG How TT's Cleanup manages to be silent?
                                    @rv1974
                                    It doesn't use the simplae SUp UI.inputbox method, it uses TT's own HTMLdialog to make the interface.
                                    • C
                                      charevir56
                                      @TIG if it's possible, I would love that add "purge environment" in your plugin.
                                        TIG Moderator @charevir56
                                        @charevir56
                                        I have looked at this in the past, and decided that the current limitations of the API / v2025 make it too awkward / too unstable to safely implement.
                                        At the moment using Environments can be flaky, and is known to cause BugSplats, so although I have a working code set I won't be releasing it any time soon...
                                        • C
                                          charevir56
                                          @TIG Good and not-so-good news in your response: It's good to know you're already working on this, although a little sad because it won't be out anytime soon. I use this plugin in my modeling routine and enjoy seeing the report. Thanks for your response and great admiration for your work.
                                          • 3 / 4
