    [Plugin] Purge All
    65 Posts 32 Posters 145.4k Views 32 Watching
    • I Offline
      iamandrewalonzo
      guys i cant see the purgeall button...i paste it on the ruby folder under ASGVIS and when i open the SU(Sketch UP) i cant find it...help me guys
        If you have permissions to add files to your Plugins folder...
        Properties > Security > Edit... FULL for all listed...
        And you have indeed installed it properly...
        When you restart SketchUp the tool should now appear appear in the Plugins menu - there is no 'button' unless you have a 'doctored' version that adds a toolbar...
        If you have v2013 why not use the Preferences > Extensions > Install... button to install any RBZ format plugin downloaded from the SketchUcation PluginStore...
        http://sketchucation.com/resources/pluginstore?pln=PurgeAll
        Or why not get/use the SketchUcation Plugin Store toolset and then you can AutoInstall plugins from within SketchUp automatically.
        http://sketchucation.com/resources/plugin-store-download
        Now there's no need to mess on manually installing plugins - provided that you have FULL permission to the Plugins folder πŸ˜‰
          There's a new version available from the PluginStore.
          It contains some 'future-proofing'.
          The log-report format is also improved.
          It is now ready for the next generation of SketchUcationTools etc...
          http://sketchucation.com/pluginstore?pln=PurgeAll
            There's another new version available from the PluginStore.
            It contains some more 'future-proofing'.
            The log-report format is also improved yet again.
            It is now fully ready for the next generation of SketchUcationTools etc...
              There's yet another new version available from the PluginStore.
              It has some cosmetic tweaking and it is now fully ready for the next generation of SketchUcationTools etc...
              • cottyC Offline
                cotty
                Sounds like it is now fully ready for the next generation of SketchUcationTools... 😎
                my SketchUp gallery
                  There's a storm a brewin'
                    kaas
                    Suggestion: to really purge a file to its bare minimum, maybe add an option to remove attributes (set by some plugins), ifc info etc?
                      I was thinking about offering to delete the IFC stuff as that can bloat a file and slow it down.
                      However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
                        kaas
                        @tig said:
                        ...However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
                        Good point. Maybe make a combo box with several options for cleaning the attributes: remove all, preserve @ components, ...
                          argenario
                          I,ve just downloaded it and purged 368 materials that were not in use and making my drawing sooo slow(sketchup 2015).... THANK U! THANK U! THANK U! THANKS A LOT!
                            Here's v2.0 http://sketchucation.com/pluginstore?pln=PurgeAll It is now signed for full compatibility with v2016/2017 in all loading-policies.
                            • F Offline
                              feodos
                              Can I ask you to make an icon for this plugin?
                              http://f21.ifotki.info/org/6feee38364657529bba52278e94868bfbca241272661627.png
                                No need to make the plugin more complex. Just make a keyboard shortcut for it.
                                  Here's v3.0
                                  https://sketchucation.com/pluginstore?pln=PurgeAll
                                  It's now signed for full compatibility with all current SketchUp versions, in all extension-loading-policies.
                                  It also has the annoying display glitch fixed - where the report's formatting for materials tabbed over to the right too much !
                                  • boofredlayB Offline
                                    boofredlay
                                    Thanks TIG
                                      Here's v4.0
                                      It's now made fully compatible with v2020 - replacing 'Layers' with 'Tags' when prompting/reporting...
                                        Thank you sir.
                                          Here's v5.0
                                          It fixes the sometimes confusing reporting of groups getting included in the end components list [groups are component-definitions, but they are never purge-able].
                                          It also address the log-file not opening on MAC's using newer versions of SketchUp...
                                            rv1974
                                            @TIG Could it be non-modal please - what exactly is the point of hitting OK?
                                            TIGT 1 Reply Last reply Reply Quote 0
                                            • 3 / 4
