    [Plugin] Purge All
    65 Posts 32 Posters 151.2k Views 32 Watching
      rv1974 @TIG
      @TIG How TT's Cleanup manages to be silent?
      TIGT 1 Reply Last reply
        TIG Moderator @rv1974
        @rv1974
        It doesn't use the simplae SUp UI.inputbox method, it uses TT's own HTMLdialog to make the interface.
        • C
          charevir56
          @TIG if it's possible, I would love that add "purge environment" in your plugin.
            TIG Moderator @charevir56
            @charevir56
            I have looked at this in the past, and decided that the current limitations of the API / v2025 make it too awkward / too unstable to safely implement.
            At the moment using Environments can be flaky, and is known to cause BugSplats, so although I have a working code set I won't be releasing it any time soon...
            • C
              charevir56
              @TIG Good and not-so-good news in your response: It's good to know you're already working on this, although a little sad because it won't be out anytime soon. I use this plugin in my modeling routine and enjoy seeing the report. Thanks for your response and great admiration for your work.
