    [Plugin] Purge All
    65 Posts 32 Posters 149.9k Views 32 Watching
    • boofredlayB
      boofredlay
      Thanks TIG
        Here's v4.0
        https://sketchucation.com/pluginstore?pln=PurgeAll
        It's now made fully compatible with v2020 - replacing 'Layers' with 'Tags' when prompting/reporting...
          Thank you sir.
            Here's v5.0
            It fixes the sometimes confusing reporting of groups getting included in the end components list [groups are component-definitions, but they are never purge-able].
            It also address the log-file not opening on MAC's using newer versions of SketchUp...
              rv1974
              @TIG Could it be non-modal please - what exactly is the point of hitting OK?
              TIGT 1 Reply Last reply
                TIG Moderator @rv1974
                @rv1974
                It can't be non-modal because it uses the UI.inputbox which is always modal.
                Thre has to be a way of closing the window - in this case it's OK or Cancel...
                R 1 Reply Last reply
                  rv1974 @TIG
                  @TIG How TT's Cleanup manages to be silent?
                    @rv1974
                    It doesn't use the simplae SUp UI.inputbox method, it uses TT's own HTMLdialog to make the interface.
                    • C
                      charevir56
                      @TIG if it's possible, I would love that add "purge environment" in your plugin.
                        TIG Moderator @charevir56
                        @charevir56
                        I have looked at this in the past, and decided that the current limitations of the API / v2025 make it too awkward / too unstable to safely implement.
                        At the moment using Environments can be flaky, and is known to cause BugSplats, so although I have a working code set I won't be releasing it any time soon...
                        • C
                          charevir56
                          @TIG Good and not-so-good news in your response: It's good to know you're already working on this, although a little sad because it won't be out anytime soon. I use this plugin in my modeling routine and enjoy seeing the report. Thanks for your response and great admiration for your work.
                          • 4 / 4
