    [Plugin] Purge All
    65 Posts 32 Posters 149.9k Views 32 Watching
      argenario
      I,ve just downloaded it and purged 368 materials that were not in use and making my drawing sooo slow(sketchup 2015).... THANK U! THANK U! THANK U! THANKS A LOT!
        Here's v2.0 http://sketchucation.com/pluginstore?pln=PurgeAll It is now signed for full compatibility with v2016/2017 in all loading-policies.
        • F
          feodos
          Can I ask you to make an icon for this plugin?
          http://f21.ifotki.info/org/6feee38364657529bba52278e94868bfbca241272661627.png
            No need to make the plugin more complex. Just make a keyboard shortcut for it.
              Here's v3.0
              https://sketchucation.com/pluginstore?pln=PurgeAll
              It's now signed for full compatibility with all current SketchUp versions, in all extension-loading-policies.
              It also has the annoying display glitch fixed - where the report's formatting for materials tabbed over to the right too much !
              • boofredlayB
                boofredlay
                Thanks TIG
                  Here's v4.0
                  It's now made fully compatible with v2020 - replacing 'Layers' with 'Tags' when prompting/reporting...
                    Thank you sir.
                      Here's v5.0
                      It fixes the sometimes confusing reporting of groups getting included in the end components list [groups are component-definitions, but they are never purge-able].
                      It also address the log-file not opening on MAC's using newer versions of SketchUp...
                        rv1974
                        @TIG Could it be non-modal please - what exactly is the point of hitting OK?
                        TIGT 1 Reply Last reply
                          TIG Moderator @rv1974
                          @rv1974
                          It can't be non-modal because it uses the UI.inputbox which is always modal.
                          Thre has to be a way of closing the window - in this case it's OK or Cancel...
                          R 1 Reply Last reply
                            rv1974 @TIG
                            @TIG How TT's Cleanup manages to be silent?
                              @rv1974
                              It doesn't use the simplae SUp UI.inputbox method, it uses TT's own HTMLdialog to make the interface.
                              • C
                                charevir56
                                @TIG if it's possible, I would love that add "purge environment" in your plugin.
                                  TIG Moderator @charevir56
                                  @charevir56
                                  I have looked at this in the past, and decided that the current limitations of the API / v2025 make it too awkward / too unstable to safely implement.
                                  At the moment using Environments can be flaky, and is known to cause BugSplats, so although I have a working code set I won't be releasing it any time soon...
                                  • C
                                    charevir56
                                    @TIG Good and not-so-good news in your response: It's good to know you're already working on this, although a little sad because it won't be out anytime soon. I use this plugin in my modeling routine and enjoy seeing the report. Thanks for your response and great admiration for your work.
                                    • 3 / 4
