    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.1m Views 582 Watching
    • BoxB Offline
      Hi Fredo,
      I just updated libfredo and it seems to have caused an issue with Curvizard.
      Any curve and any action creates stange edges between points.
      • fredo6F Offline
        @box said:
        Hi Fredo,
        Many thanks for signaling the problem.
        Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
          LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
          • BoxB Offline
            Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
            • BoxB Offline
              Thanks again Fredo.
                penumbra
                Hi Fredo
                Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback.
                  pibuz
                  Hi Fredo!
                  What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!
                  I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
                  Thanks in advance!
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                  • fredo6F Offline
                    This is a good idea, and I think this is manageable.
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
                      LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
                        LibFredo6 9.5e is a minor release
                        • necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
                        • For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
                        • fredo6F Offline
                          This is now available in FredoTools::ReportLabelArea v3.2a, with
                          • FredoTools v3.8b
                          • LibFredo6 v9.5e
                            rv1974
                            For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
                              The Lib installs fine for me [same OS etc] and it is fully signed etc...
                                rv1974
                                Manual extract to plugins folder solved the issue.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
                                  LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
                                    LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
                                      Beaver99
                                      Thank you so much for creating these tools, extremely valuable to my work flow.
                                      You are
                                      Awesome & Amazing !
                                        Jeff Mack Designs
                                        can you use this plug in with sketch up for web? like the free version?
                                        when I go to Window the options outlined are not there.
                                        ty.
                                          ty.
                                          No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
                                            LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 111
                                            • 112
                                            • 75 / 112
