    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
      LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
      • fredo6F
        NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
        LibFredo6 9.5e is a minor release
        • necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
        • For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
        • fredo6F
          @pibuz said:
          is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component?
          This is now available in FredoTools::ReportLabelArea v3.2a, with
          • FredoTools v3.8b
          • LibFredo6 v9.5e
            rv1974
            For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
              The Lib installs fine for me [same OS etc] and it is fully signed etc...
                rv1974
                Manual extract to plugins folder solved the issue.
                • fredo6F
                  NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
                  LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
                  • fredo6F
                    NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
                    LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
                    • B
                      Beaver99
                      Thank you so much for creating these tools, extremely valuable to my work flow.
                      You are
                      Awesome & Amazing !
                        Jeff Mack Designs
                        can you use this plug in with sketch up for web? like the free version?
                        when I go to Window the options outlined are not there.
                        ty.
                          ty.
                          No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
                          • fredo6F
                            NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
                            LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
                            • fredo6F
                              NEW RELEASE: LibFredo6 v9.5h - 13 Feb 20
                              LibFredo6 9.5h is a minor release necessary for Animator. It corrects a problem when Easing functions.
                                Sunxl
                                Hi Fredo,
                                Do you know how to fix the problem shown as below,
                                [img]file:///C:/Users/SUN/Desktop/%E9%98%BF%E9%87%8C%E6%97%BA%E6%97%BA%E5%9B%BE%E7%89%8720200303012702.jpg[/img]
                                I tried the su2019 and 2020, But the SU still failed to load the Fredo6
                                Please help
                                Thank you
                                  The image is missing you cannot link to a file that is on your own PC !
                                  Try copy/paste ?
                                    Sunxl
                                    Try copy/paste ?
                                    Sorry,this is my first time to use this.
                                    载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
                                    Failed to read RBE/RBS file.
                                    载入文件 Fredo6_!LibFredo6.rb 时出错
                                    Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                    C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                    C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                    thank you
                                    • fredo6F
                                      This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
                                      Could you reinstall it, with 'run as administrator'.
                                        Sunxl
                                        Yes, I did. But the error still exist.
                                        I didn’t find any available solutions to deal with it.
                                          JDW Interiors
                                          Hi all,
                                          I've downloaded Fredoscale for my MacBook Pro 2018 but I can't seem to open it. I am running sketchup 2020.
                                          I firstly downloaded it from sketchUcation and then I went to 'Window>Extension manager>Install extension'
                                          In the extension manager it says the app is signed but I can't see how I can open the window and use the fredoscale tools.
                                          Can anyone help?
                                          Thanks in advance!
                                          Jack
                                            Have you quit out of SketchUp and reopened it to make sure both extensions load completely? After you do that you should be able to see the FredoScale tool palette in View>Tool palettes.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 112
                                            • 113
                                            • 75 / 113
