    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • P
      pibuz
      Hi Fredo!
      What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!
      I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
      Thanks in advance!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • fredo6F
        This is a good idea, and I think this is manageable.
        • fredo6F
          NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
          LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
          • fredo6F
            NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
            LibFredo6 9.5e is a minor release
            • necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
            • For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
            • fredo6F
              This is now available in FredoTools::ReportLabelArea v3.2a, with
              • FredoTools v3.8b
              • LibFredo6 v9.5e
                rv1974
                For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
                  The Lib installs fine for me [same OS etc] and it is fully signed etc...
                    rv1974
                    Manual extract to plugins folder solved the issue.
                    • fredo6F
                      NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
                      LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
                      • fredo6F
                        NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
                        LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
                        • B
                          Beaver99
                          Thank you so much for creating these tools, extremely valuable to my work flow.
                          You are
                          Awesome & Amazing !
                            Jeff Mack Designs
                            can you use this plug in with sketch up for web? like the free version?
                            when I go to Window the options outlined are not there.
                            ty.
                              ty.
                              No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
                              • fredo6F
                                NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
                                LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v9.5h - 13 Feb 20
                                  LibFredo6 9.5h is a minor release necessary for Animator. It corrects a problem when Easing functions.
                                    Sunxl
                                    Hi Fredo,
                                    Do you know how to fix the problem shown as below,
                                    [img]file:///C:/Users/SUN/Desktop/%E9%98%BF%E9%87%8C%E6%97%BA%E6%97%BA%E5%9B%BE%E7%89%8720200303012702.jpg[/img]
                                    I tried the su2019 and 2020, But the SU still failed to load the Fredo6
                                    Please help
                                    Thank you
                                      The image is missing you cannot link to a file that is on your own PC !
                                      Try copy/paste ?
                                        Sunxl
                                        Try copy/paste ?
                                        Sorry,this is my first time to use this.
                                        载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
                                        Failed to read RBE/RBS file.
                                        载入文件 Fredo6_!LibFredo6.rb 时出错
                                        Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                        C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                        C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                        thank you
                                        • fredo6F
                                          This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
                                          Could you reinstall it, with 'run as administrator'.
                                            Sunxl
                                            Yes, I did. But the error still exist.
                                            I didn’t find any available solutions to deal with it.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 113
                                            • 114
                                            • 75 / 114
