    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
      penumbra
      On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
      (Correction) posted in wrong forum, this comment was meant for Fredo Guides.
      • fredo6F Offline
        Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
          penumbra
          Annotation 2020-01-09 132839.pngruby console is blank, doesn't show any activity.
          • fredo6F Offline
            @penumbra said:
            [attachment=0:v3qajxdy]<!-- ia0 -->Annotation 2020-01-09 132839.png<!-- ia0 -->[/attachment:v3qajxdy]ruby console is blank, doesn't show any activity.
            Does the problem happens with any model?
              penumbra
              Annotation 2020-01-09 164744.pnginterestingly, no it does not. starting a fresh model the plugin works fine.
              but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work.
              • fredo6F Offline
                Could you post or PM me the model.
                Because of this error, the process of protection does not start and thus is not active for this model.
                • BoxB Offline
                  Hi Fredo,
                  I just updated libfredo and it seems to have caused an issue with Curvizard.
                  Any curve and any action creates stange edges between points.
                  • fredo6F Offline
                    @box said:
                    Hi Fredo,
                    Many thanks for signaling the problem.
                    Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
                      LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
                      • BoxB Offline
                        Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
                        • BoxB Offline
                          Thanks again Fredo.
                            penumbra
                            Hi Fredo
                            Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback.
                              pibuz
                              Hi Fredo!
                              What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!
                              I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
                              Thanks in advance!
                              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                              • fredo6F Offline
                                This is a good idea, and I think this is manageable.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
                                  LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
                                    LibFredo6 9.5e is a minor release
                                    • necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
                                    • For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
                                    • fredo6F Offline
                                      This is now available in FredoTools::ReportLabelArea v3.2a, with
                                      • FredoTools v3.8b
                                      • LibFredo6 v9.5e
                                        rv1974
                                        For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
                                          The Lib installs fine for me [same OS etc] and it is fully signed etc...
                                            rv1974
                                            Manual extract to plugins folder solved the issue.
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 111
                                            • 112
                                            • 75 / 112
